Old Apr 04, 2013, 12:27 PM
dubzn1 is offline
Find More Posts by dubzn1
Joined Feb 2013
multiwii pro with gps - help loading a sketch
so i got my hand on a multiwii pro inc gps
i got it in quad mode
i did an eeprom clear ino then tried re loading a new sketch but it keeps coming back with
initsensors was not declared in this scope
im a total noob at all this so please be gentle
multiwii.com forums are quite nasty and have been told that if i dont understand code , i shouldnr be playing
any help ?
dubzn1 is offline Find More Posts by dubzn1
Old Apr 04, 2013, 12:35 PM
RTRyder is offline
Find More Posts by RTRyder
Registered Lunatic
RTRyder's Avatar
Boston, MA
Joined Jul 2010
Without knowing exactly what application you're using to do the load all I can do is guess, but it sounds like if you're using Arduino it can't find the correct library for the functions. In Arduino under file, preferences, you need to set the sketchbook location to the directory containing the Multiwii files you're trying to compile and load, if it's set to some other location you can get errors like you're seeing.
RTRyder is offline Find More Posts by RTRyder
Old Apr 04, 2013, 01:00 PM
dubzn1 is offline
Joined Feb 2013
sorry yes its arduino
im using the open tab to open where the ino file is and doing it that way
Old Apr 04, 2013, 02:20 PM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
try multiwii 2.1 see if it loads..
load this first from ardiuno to the board
http://sdrv.ms/TYWOB1
then check the gui for gps working(you will see gps flashing in the gui)
this configs the gps..
next you need upload this..
this is the flight firmware..
http://sdrv.ms/UmytGv
thats it, all codes are ready made just select com port on tools and correct board =
ardiuno mega 2560 or mega adk...
hit upload job done..
dazza44 is offline Find More Posts by dazza44
Old Apr 04, 2013, 04:11 PM
dubzn1 is offline
Joined Feb 2013
super !!! after a while i thought right ill download the ino fresh and it worked
but now none of the sensors work lol
dazza am i better of scrapping the progress and using the above info and script?
sorry i got a bit excited
Old Apr 04, 2013, 04:59 PM
JoeCool87TC is offline
Find More Posts by JoeCool87TC
United States, TX, Hawkins
Joined Nov 2012
"initsensors was not declared in this scope"
The compiler is telling you that the variable "initsensors" is being used outside the function/routine where it was declared.
This and other funky errors can also be caused by missing semicolons and/or incorrect syntax somewhere prior to the error point.
You need to learn Arduino programming to fix this, or find someone who knows.
HTH
JoeCool87TC is offline Find More Posts by JoeCool87TC
Old Apr 04, 2013, 05:37 PM
dubzn1 is offline
Joined Feb 2013
ive been a bit of an eager fool
used dazzas second script and .... booooom it all works except for gps but i think thats down to the wirring
there is 6 wires
ive wired as per hobbykings pic but 2 wires are left
do they need to go somewhere?
actually excited i have progress
Old Apr 04, 2013, 06:06 PM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
did you go as in the post.
load 1st one then do second one as gps will not work otherwise.
wiring like this for mtk gps
http://static.rcgroups.net/forums/at...g?d=1364932836
yes wire both ends not used
Old Apr 04, 2013, 06:48 PM
dubzn1 is offline
Joined Feb 2013
the anza youre awesome
answers ive been looking for have been found !!!! cheers dazza
the gps pkt is flashing now so i presume thats working ????
should it show my position on the map? and the number of satalites?
so excited even more !!!!!!
Old Apr 04, 2013, 07:26 PM
dubzn1 is offline
Joined Feb 2013
right an update
ive had this board on a model since febuary and spent many hours trying to sort it
at first i thought i had blown the board when servos kept on smouldering
but
i persisted and im no computer nerd , i struggle to send an email
and
being partially blind doesnt help
but thanks to you guys , espially dazza , im blown away
all the things that should work DO !!!!!!
im blown away and sooo happy !!!!
dazza , how do i lower the start rpm's ?
there a bit high and is nearly ready to take off
so so so happy !!!!
Old Apr 04, 2013, 07:33 PM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
look in the config-h file youll find....motor stop, uncomment it- remove the //
your motors wont start now till you apply throttle..
Old Apr 04, 2013, 07:59 PM
dubzn1 is offline
Joined Feb 2013
ah yes
its a bit lower on start up but not much
Old Apr 05, 2013, 06:12 PM
dubzn1 is offline
Joined Feb 2013
just going to calibrate all the esc's thwn its ngood to go
Old Jun 08, 2013, 07:45 AM
dubzn1 is offline
Joined Feb 2013
well i broke my original board and ive just replaced it
i did the eprom cleaar and tried loading my original sketch but nothing is working
it says
readeprom was not declared
any pointers ??
Build Log NEW: whitespy MWC Pro 2.0 FC +MTEK GPS for MultiWii (now w/UBlox GPS) kinderkram Multirotor Electronics 2500 Dec 26, 2015 11:29 AM
Discussion Aerosky H-100 with HK Multiwii Pro Running MegaPirates with GPS and Mission Planner snorkrc Multirotor Talk 9 Aug 19, 2013 10:05 PM
Discussion need help with multiwii pro 3dx450 Multirotor Electronics 4 Apr 05, 2013 05:14 PM
Discussion Need help with HK multiwii SE v2.0 with v2.1 firmware rahul1991 Multirotor Talk 4 Apr 02, 2013 07:31 AM
For Sale MultiWii PRO with GPS alwaysconfused Aircraft - Electric - Multirotor (FS/W) 5 Jan 29, 2013 02:14 PM
