Old Apr 03, 2013, 08:27 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Build Log
TWISTED HOBBYS 32" Crack Laser!
Greetings again fellow Twisted fans!
Well, since the Crack Yak debuted a little over a year ago we have come a long way. We have done the revised Extra Slick for sharp, wood-like performance, the Crack Pitts for stable performance and the flair of a bipe, the Crack Yak Lite for depron floatiness at EPP prices and convenience, and the Crack Yak Mini for flying hard in smaller spaces.
However, the very first Crack Yak hit a note in this industry. What everybody wanted was an extreme EPP foamy to help you take your flying to the next level, and the Crack Yak delivered. We aren’t content to rest on our laurels at Twisted, so when Brad gave me carte blanche to design the next Twisted airplane I just had to design another model that was capable of scratching that itch that every extreme pilot has…fast roll rates, locked-in precision, and unlimited capability.
Presenting the Crack Laser!
This is a “Cracked-out” model of the full scale Laser, incorporating the same stealth styling cues and design philosophy of the Crack Yak and Crack Pitts. The Laser is one of the most recognizable and classic aerobatic designs, and makes a refreshing change from all of the Extras, Edges, and other more modern designs on the market now. Additionally, the fuselage shape, canopy placement, wing shape, and tail shape of the Laser can make for an incredibly locked-in and capable model…owners of the Extreme Flight Laser EXP can attest to this! The Crack Laser is part of the Lite series, designed for indoor use or outdoor use in light wind with 2S 300-450 mah batteries and the Twisted Lite Power Combo.
The Crack Laser was designed to take full advantage of the lower wing loading that we could achieve with the thinner construction and lighter components of the Lite series. For example, the wing planform of the Crack Yak makes for silky smooth harriers at a slightly higher wing loading. We found that on the Lite series of aircraft, the lower wing loading made for great harrier performance…so we could add a little bit of sweep to the wings for better rolling and precision without sacrificing harriers. We also added some other important improvements… the T-canalizer makes for a silky-smooth rudder response, and the SFG’s on the elevator and ailerons not only make for a crisp response, but add stiffness. Additionally, there are certain things that I like in an airplane that I wanted to incorporate into this. The Crack Yak was designed by Chris J. for his tastes, and the Crack Laser is designed by myself for mine!
The result is the absolute smoothest, most precise EPP foamy you’ve ever flown, with the absolute best rolling performance on the market. Slow rolls and rolling circles are as easy and forgiving as the Crack Pitts, and the elevator and rudder response are smooth and crisp. I have never felt more precise flying a foamy than with the Crack Laser. But when you peg the sticks this thing rolls even faster than the Crack Yak! In fact, it’s about the only thing out there that can keep up with the Crack Yak Mini. What’s most impressive though is how stable and consistent it is. It’s extremely predictable and always rolls at the same rate, and tracks on a wire as it drills along. All of this occurs at remarkably slow and predictable airspeeds. This is the best plane I’ve ever flown for fast point and rifle roll practice! Don’t let that capability scare you, though. It’s floaty and forgiving around center and is just as easy to fly as any other foamy.
Important notes about this build:
The Crack Laser builds almost exactly the same as the Crack Yak Lite. About the only difference is the addition of the SFG's on the ailerons and elevator, and the T-canalizer. However, we have found some new construction and assembly techniques which will really increase the durability and longevity of this airplane and get it even closer to a standard 32" plane. If you get confused you can always refer to the manual and the Crack Yak Lite build thread.
Without further ado, let's build it!
Twisted Hobbys 32" Crack Laser (3 min 49 sec)
CG is 1" back from the spar
Last picture caption has been truncated. It should read: And one final trick: we have found that it's best to cut a slot for the batteries with these planes. They roll more axially and stay more true during pushes and pulls. However, since you will likely want to fool with CG a bit, you only have one shot to mount it correctly once you cut the slot. So for a few test flights, mount the battery to the fuse with T-pins. This will allow you to move it around a bit and then cut the slot.
UPDATE: The kit has been updated and no longer includes Z-bends. Please, follow the manual, not the build thread! The manual can be found here
cwojcik is offline Find More Posts by cwojcik
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
Reserved for build info and videos...
Old Apr 03, 2013, 08:28 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
MANUAL LINK
http://www.twistedhobbys.com/media/M...ies%20002a.pdf
v002a - updated April 11th, 2015
cdee is offline Find More Posts by cdee
Old Apr 03, 2013, 08:47 PM
Twister 72 is offline
Find More Posts by Twister 72
Team AW
United States, NH, Sandown
Joined Sep 2009
Looks sweet Cody! Awesome design and color scheme.
Twister 72 is offline Find More Posts by Twister 72
Old Apr 03, 2013, 08:55 PM
ForsheeMS is offline
Find More Posts by ForsheeMS
ForsheeMS's Avatar
United States, NC, Lexington
Joined Jul 2012
Oh great! Just when I told my wife I wouldn't be buying any more planes for a while you do this to me! I absolutely love the Crack Yak and will probably end up with a Laser.............and possibly a divorce!
ForsheeMS is offline Find More Posts by ForsheeMS
Old Apr 03, 2013, 09:07 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
Awww heck, thanks for all the hard work on delivering these excellent planes bro! Sweet looking plane for sure. Can't wait to get Aaron to check it out. Very proud of you. Fly soon! Won't be long now!
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Latest blog entry: The Crack Pitts - revisited :)
Old Apr 03, 2013, 10:10 PM
bighead93 is offline
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Looks good guys!
bighead93 is offline Find More Posts by bighead93
Old Apr 04, 2013, 12:38 AM
joemi is offline
Find More Posts by joemi
joemi's Avatar
United States, WA, Kent
Joined Sep 2001
Looks awesome. I wonder what the chances are of a Laser "Mini" in the future? I'd pre-order that in an instant.
joemi is offline Find More Posts by joemi
Old Apr 04, 2013, 12:54 AM
kohersh is offline
Find More Posts by kohersh
PA Team Pilot
kohersh's Avatar
United States, FL, West Palm Beach
Joined Apr 2011
Jeeeez, a total of 3 guys at my field bought slicks in the last 30 days because they saw how well mine flew, guess I'm a crack ambassador (where is my discount TH...I'm pushing your product real good)....now I have to one up them with this new bad boy. Any videos of it getting tossed around yet?
Am i right that its about 2 oz. lighter than my slick? Wonder how it would fly with the heavier 450mah batts I already have
kohersh is offline Find More Posts by kohersh
Old Apr 04, 2013, 01:39 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Looking forward to the vid Cody
Kris... is offline Find More Posts by Kris...
Old Apr 04, 2013, 03:07 AM
wishawhunk is offline
Find More Posts by wishawhunk
scotland uk
Joined Jan 2005
Looks nice!!
wishawhunk is offline Find More Posts by wishawhunk
Old Apr 04, 2013, 05:27 AM
rcguy1958 is offline
Find More Posts by rcguy1958
USA, NY, Poughkeepsie
Joined Mar 2010
Man, just when you think you don't have to spend anymore money on planes, twisted goes and does something like this
rcguy1958 is offline Find More Posts by rcguy1958
Old Apr 04, 2013, 06:55 AM
Dan5.0 is offline
Find More Posts by Dan5.0
Dan5.0's Avatar
Joined Dec 2008
Originally Posted by kris... View Post
looking forward to the vid cody
+1
Dan5.0 is offline Find More Posts by Dan5.0
Old Apr 04, 2013, 07:51 AM
3flyguy3 is online now
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Sub'd
3flyguy3 is online now Find More Posts by 3flyguy3
Old Apr 04, 2013, 07:56 AM
Twisted Realm is offline
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
This is exciting! The Laser is one of those models we are anxious to hear flight reports on, she's an amazing ship! It’s been asked before, what model design could we think of next after the Crack Yak-55??... we bring you the Crack Laser.
Proper respect go to Cody for crafting our new Crack Laser Lite model. His amazing flying style along with his vision for flight design has immensely impressed all of us here at Twisted Hobbys. We are honored to release his new design in our Lite-Series line up along side the Crack Yak-55 Lite. What also makes this project very special to us is not only did Cody design the Laser he also created the artwork as well. The scheme gives a visually bold presence while having the desired ability to orientate the model (this is a must )
There are a few new added features which set the Laser apart from our other models. This including inter-counter balance ailerons, outer control surface sfg's along with a T-canalizer which gives the Laser remarkable tracking and precision. I will let Cody express more of the flight characteristics for you guys but all I will say is she’s simply that good. Enjoy this one guys!
Brad
T.H.
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6697 Jul 17, 2016 11:17 AM
For Sale Twisted Hobbys TH 32" EPP Crack Yak-55 with (2) 3s 450mah packs justinlee1 Aircraft - Electric - Airplanes (FS/W) 4 Feb 15, 2013 09:05 AM
Wanted Twisted Hobbied Crack Series 32" anything dskuro95 Aircraft - Electric - Airplanes (FS/W) 0 Feb 10, 2013 02:37 PM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
