Old Apr 05, 2013, 05:56 PM
rock11 is offline
Find More Posts by rock11
Joined Apr 2005
I think a front mount for the TBS Discovery would be pretty sweet. A lot of people have the Discovery frame and your first design looks like it might work with a little tweaking.
rock11 is offline Find More Posts by rock11
Old Apr 06, 2013, 08:23 AM
ed_jza80 is offline
Find More Posts by ed_jza80
Joined Dec 2007
ok, ill preface this with 'ive never seen a TBS frame' and am just spitballing an idea based on a quick google image search...
the TBS has an upper and lower deck -in blue- with 2 vertical struts/standoffs - in red- (?? dimensions anyone?). forward to the two stuts is the lower plate (again, dimension?) on which you solid mount your gopro. there is no vibration isolation.
so using these few existing components, i spent 2 mins to come up with this idea for a possible mounting configuration...
use the two rear struts to support a rear plate onto which x2 vibration isolators in black can be mounted (horizontally). drill x2 9mm holes at the front of the lower plate, and mount a further 2 vibration isolators (vertical) there.
conjure up some sort of 90deg angle piece -in white- between the two to which the roll-motor mount is integrated... and bam, isolated forward facing mount for theTBS ??
would naturally be more blended, integrated, and loadoptimised, but you get the idea...
ed_jza80 is offline Find More Posts by ed_jza80
Old Apr 06, 2013, 08:43 AM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Originally Posted by ed_jza80 View Post
ha! thats what im talking about!
awesome that youve picked it up and taken it another direction
also jealous youve got a hero 3 to play with
Lupus - sent you a PM re: updating parts if required
EDIT: you 'front mounted' guys... what frame specifically? and what potential mounting positions/holes/options are there to accommodate a mount for the roll motor. or if thinking non 'frame specific', what kind of 'generic' forward pointing mount would be desirable?
For a frame the Dialfonzo fpv quad, his blackwidow quad and blackwidow hex.
NaterPin is offline Find More Posts by NaterPin
Old Apr 06, 2013, 10:45 AM
fireslayer26 is offline
Find More Posts by fireslayer26
My Karma ran over my Dogma
fireslayer26's Avatar
United States, FL, Jacksonville
Joined Feb 2010
Will this not work with the Gopro Hero 1?
Are these the motors your talking about?
fireslayer26 is offline Find More Posts by fireslayer26
Old Apr 06, 2013, 11:21 AM
AlanGold is offline
Find More Posts by AlanGold
AlanGold's Avatar
Joined Oct 2012
I have no capability to make one of these myself but was considering all options to mount a gimbal to the front of my Discovery. The drawing here might work but it will require some adjustments for vibration isolation mounting and balance I think. I think all that weight pushed forward will at least require an extension to move the battery farther back on the Disco. In looking at the photos of the Spidex, it seems that they have an excellent layout design... building on the Disco and Scarab styles somewhat. (I have no way of knowing if their vibration isolation works well or if the frame is well made.)
Now I can see why some would like to build a project from scratch. But the Spidex is very inexpensive and seems like a good solution for me to get going quickly... assuming I don't have to wait too long for it. I am going on faith from their single test video that this will work well.
What I did is I ordered a Spidex gimbal ($225) that is designed to be mounted on the front of their Spidex V2 frame. I also ordered the entire frame for another $75. I may try to adapt the Spidex gimbal to my Discovery frame, move the mounting system from the Spidex to the Disco, or switch over to the Spidex frame entirely. I can't say until I have it but maybe this photo will give people the idea of various directions to go with their home made projects. I'm certainly open to suggestions for mounting too.
Considering the frame is only $75 it is surely a reasonably priced solution rather than spending a lot of time and effort trying to mount this gimbal onto my Disco. So I may have a Disco frame available for cheap soon.
AlanGold is offline Find More Posts by AlanGold
Old Apr 06, 2013, 11:27 AM
NaterPin is offline
Joined Dec 2009
How soon is the camera gimbal going to be ready
Old Apr 06, 2013, 11:45 AM
AlanGold is offline
AlanGold's Avatar
Joined Oct 2012
Yesterday, they accepted orders for 15 units to be "delivered" with in 2 weeks. But I don't think that is guaranteed because they are assuming all goes well from prototype to limited production. But since nothing else was available, I figured, why not.
I looked on their website and see they are accepting new orders but now say it is "back ordered for 2-3 weeks." I really have no idea and bought it very impulsively yesterday once I saw the price and that they were taking pre-orders... since it looks exactly like what I wanted. Other gimbals, which also are not available, would have forced me to add the weight of landing gear to the Disco and that LG might have been more expensive than this entire frame.
Best I can tell this comes with commonly available motors and the Martinez Arduino open source board. (I haven't looked into the software for it yet.) I really like the way the camera mounts to it and it is protected in a frame behind a glass or plastic "lens protector" of some sort. (Information is pretty scarce at this time.) It looks like it has room on the side for a video out FPV cable.
Here is the link to the gimbal/frame package for $300.98 or 230 Euros.
http://quaternium.es/product.php?id_product=45
I have a question for you guys who are making these. Since people worry about the mechanical resistance of the cables is there any way that ribbon connectors - the kind used connecting the heads of inkjet printers and scanners, can be used on these? Or is the current demand too high?
Old Apr 06, 2013, 12:19 PM
NaterPin is offline
Joined Dec 2009
I have been looking at this frame for a while. But I would like a folding one. I will end up getting one from Dialfonzo. Eric has a fpv quad and a Blackwidow. quad and hex.
Old Apr 06, 2013, 01:59 PM
willardj is offline
Find More Posts by willardj
Joined Mar 2013
I was also one of the lucky 15. I don't thing it is risky. Judging by their expertise, both flying skills and designing skills, I can hardly think that they would release something that is not 100%. Al depends on the controller I guess, which is still a mistery to me. the gimbal itself looks pretty straightforward.
willardj is offline Find More Posts by willardj
Old Apr 06, 2013, 02:46 PM
ed_jza80 is offline
Joined Dec 2007
and in reality, this is not rocket science
as said, it'll come down to the controller. i stumped up the cash for the alex mos one becuase we know it works, and the firmware seems to put out consistently better results than the open source (martinez) version, but i reckon itll level out pretty quickly aftr a few updates.
i just like designing stuff, and if someone can use this design, and better still, if it can go 'open source' and be improved, extended across platforms, or whatever, great!
(ps - i have a v2 spidex myself ... might make a mount for this to fit! haha!)
Old Apr 08, 2013, 08:11 AM
badlands is online now
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
& you rock for sharing it!
badlands is online now Find More Posts by badlands
Old Apr 08, 2013, 08:30 AM
ed_jza80 is offline
Joined Dec 2007
cheers
FYI - all parts just updated to 1.07 BETA
now simply listed as individual parts, rather than as a group.
updates in 1.07:
- cleaned up the files a bit (had some strange internal wall / manifold problems)
- separeted files into individual components
all .stl files downloadable directly from here:
http://www.shapeways.com/shops/RapidSequence
Old Apr 08, 2013, 09:41 AM
badlands's Avatar
Joined Mar 2010
@ ed_jza80 - my buddy has offered to print this.
He says the scale is wrong in UP software?
Old Apr 08, 2013, 09:43 AM
FITandFUEL is offline
Find More Posts by FITandFUEL
Joined Jan 2013
I thought this might work for the H3, probably needs some more tweaking but the USB cable would be reachable like this and the sensor should be centered with the two axis. I figured the plate on the front of the camera could have a little notch in the bottom for a rubber-band to hold the camera securely.
Sorry, only have sketchup to play with so the results look a little rough.
FITandFUEL is offline Find More Posts by FITandFUEL
Old Apr 08, 2013, 09:48 AM
ed_jza80 is offline
Joined Dec 2007
two things
whoever just *bought* x4 parts through shapeways, i suggest you cancel your order, as i just uploaded an error, and need to upload it all again (revision 1.08... ill let you know, ill update it here) - you were too quick!
(ps - i dont make anything from the shapeways print orders!)
regarding scaling : it did something funky in conversion to .stl format...
its a metric design, but it appears to have go through an 'inches' conversion somewhere, and need to be converted back to 'milimeters'. so a factor of 25.4 should be in there, give or take a few zeros
basic dimensions of the 5 files:
part A: approx 52mm tall x 85mm wide
part B: approx 51mm tall, 35mm wide
part C: approx 51mm tall, 35mm wide
part D: approx 32mm tall, 54wide, 78mm deep
part E: approx 75mm tall, 65mm wide, 84mm deep
give or take. but if you find the right conversion metric/imperial/whatever, that should be enough to confirm you got it correct
Discussion Open Source Brushless Gimbal edge0xc Multirotor Electronics 3073 Dec 11, 2015 03:16 PM
Help! 3D printable open-source RC Truggy - RC minds needed to finish project remondo Off-road Cars 21 Sep 16, 2014 12:35 AM
Sold open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 57 Mar 26, 2013 07:02 PM
Sold [closed] open source brushless gimbal controller jy0933 Aircraft - Electric - Multirotor (FS/W) 16 Feb 26, 2013 09:19 AM
