Old Mar 31, 2013, 05:39 PM
gquiring is offline
Find More Posts by gquiring
Sailplane Mafia
gquiring's Avatar
United States, SC, Summerville
Joined Jun 2001
YEP ESC help
I have a YEP 60A (my first YEP) with a KD 36-10XL 900kv from Hobby King (link below) that is being used in a sailplane. I am using a 12x6 folding prop with a 3s 3000 pack. The same setup with an ICE 50 controller gets 492 watts at 42amps. With the YEP ESC I am only getting 345 watts at 29amps. The ICE and YEP are set for auto timing. Can someone explain how to calculate what the timing should be if I use manual timing?
Motor link:
http://www.hobbyking.com/hobbyking/s...ner_900Kv.html
gquiring is offline Find More Posts by gquiring
Old Mar 31, 2013, 08:58 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Lower timing should yield lower RPM, but also fewer amps. Higher timing = more RPM, more amps.
Before writing off the YEP, check RPM (or thrust). Then you'll be able to decide the ideal timing for you, based on the RPM you want, and the current you're willing to supply.
Odysis is offline Find More Posts by Odysis
Old Apr 01, 2013, 04:15 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
Have you done throttle calibration with the new YEP ESC? It could be that the ESC dont give you full throttle even with the stick in full position. Check the manual how to do it if you dont know.
Outrunners does usually whant medium to high timing.
MagnusEl is offline Find More Posts by MagnusEl
Old Apr 01, 2013, 11:23 AM
gquiring is offline
Sailplane Mafia
gquiring's Avatar
Joined Jun 2001
I did the throttle calibration, no improvement.
If I go for manual timing, I have no idea what to select. There are options for 0, 6, 12, 18, 24 and 30.
Old Apr 01, 2013, 02:00 PM
gquiring is offline
Sailplane Mafia
gquiring's Avatar
Joined Jun 2001
This turned out to be an interesting result. I set the timing to 18, it was about the same numbers. Then I tried 24 and it was just a few watts more, finally tried 30 and it maxed out at 386 watts which is a far cry from the ~495 I am used to getting with this motor. I finally grabbed my Castle ICE 100 that was not being used and was rather surprised to see the same low ~380 watts.
I then realized the last time I tested my amps/watts was with my old AstroFlight meter, I now use a Turnigy. I found my Astro and the numbers were the same.
So I guess the motor is not functioning right or it's not the one I ordered. They don't print anything on these motors to confirm the model #.
Old Apr 01, 2013, 05:53 PM
Odysis is offline
Joined May 2007
How do you know the motor's not up to par?
The power drawn is determined by what's bolted to it, i.e. the prop/fan/rotor.
Old Apr 01, 2013, 09:05 PM
gquiring is offline
Sailplane Mafia
gquiring's Avatar
Joined Jun 2001
I have the same motor and prop on my other sailplane as I mentioned in the first post. My other sailplane has a Castle ICE controller on it with the same KDA motor and prop. Once I tried the ICE controller on this new sailplane I know it's the motor because it's still not producing 495 watts.
Old Apr 02, 2013, 03:58 AM
Odysis is offline
Joined May 2007
Is it producing the same RPM as your other setup? Potentially they have different kv, or one has a winding or two in the wrong spot which can ruin efficiency, but not affect kv too much?
(i.e. your other motor may be bad if it's producing the same RPM but using more power)
Old Apr 02, 2013, 05:58 PM
gquiring is offline
Sailplane Mafia
gquiring's Avatar
Joined Jun 2001
I checked the RPM's and the new KDA is doing 840 and the old KDA is doing 900. So it's odd, RPM wise it's much closer than the AMPS and WATS show.
Old Apr 02, 2013, 06:02 PM
Odysis is offline
Joined May 2007
even with the power=rpm^3, that doesn't line up. Something's screwy with the motor, and I'd suggest it's the old one.
The new one makes less power, sure, but it sucks a lot less! Go with a slightly larger prop to get the power back to what you want, but with lots more thrust
Old Apr 02, 2013, 06:10 PM
gquiring is offline
Sailplane Mafia
gquiring's Avatar
Joined Jun 2001
The good news in all of this is the YEP ESC is not the problem. I selected YEP because of the 6 amp BEC. It's much cheaper than a Castle ICE.
Old Apr 03, 2013, 07:56 PM
ole38hatt is offline
Find More Posts by ole38hatt
Joined Feb 2009
Glad to see you didn't go back to slimers when you moved South.
Larry K Tri County
ole38hatt is offline Find More Posts by ole38hatt
Old Jun 21, 2013, 10:52 AM
erie_flyer is offline
Find More Posts by erie_flyer
Life is a Hobby
Canada, ON, Delhi
Joined Aug 2012
Just got an HK YEP 60 ESC.
Question about soldering the motor side bullet connectors. The three wires are all the same yellow colour. This would imply that it is not crucial how the three ESC wires are plugged into the three EFlite motor wires which are different colours - red, black, blue.
I have read many times that as long as the the motor is turning in the right direction that the ESC hookup is not crucial. Just reverse wires to get the proper rotation.
Is my assumption correct - ESC to motor connections not crucial as long as motor turning correctly?
Bill
erie_flyer is offline Find More Posts by erie_flyer
Old Jun 21, 2013, 12:00 PM
cryhavoc38 is online now
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Bill
exactly. You have a correct understanding of how brushless motors and esc's work. If the motor is spinning the wrong direction, switch ANY two of the three wires and it will turn the other way.
cryhavoc38 is online now Find More Posts by cryhavoc38
Old Jun 24, 2013, 02:46 PM
Life is a Hobby
Canada, ON, Delhi
Joined Aug 2012
Soldered on the various connectors to the YEP. Didn`t heat shrink the red/blue/black on the motor side until the motor was turning CCW. Then heat shrunk the colours to match the motor colours for future reference.
Bought the Prog Card II with the YEP. Instruction manual is on the HK website. Instructions are like ``Push the buttons until you do it right. If it didn`t work push the buttons again``. Yikes!
Figured I was safe as long as I didn`t push the Enter button. Had to get to level two for the LiPo cell count by pushing the 2 left hand buttons simultaneously. If you are out by a nanosecond the indicator LED won`t flash for level 2. After multiple attempts finally got it flashing.
Now for the non-existent instructions to get to the cell count. Kept pushing the left hand buttons and finally figured out how to get one LED on the cell row and the other LED on the 4 column. Pressed Enter. Got some musical notes so guess it worked.
To verify hooked the YEP to a RX, plugged in a flight battery and heard 4 notes meaning 4 cells.
Now onto mounting the YEP in an airplane. It will go into the new GP F1 Rocket which I have ordered in a Toronto R/C shop. Should have it in a few weeks.
Bill
Sold YEP 45a ESC w/Programming Card JHawk19 Aircraft - Electric - Helis (FS/W) 2 Feb 04, 2013 02:15 PM
Wanted 2 100a yep ESC's garrettt04s Aircraft - Electric - Power Systems (FS/W) 0 Jan 27, 2013 06:48 AM
Help! Reversing direction on YGE/YEP/HiModel 120HV ESC murdnunoc Power Systems 5 Jan 13, 2013 02:14 PM
For Sale YEP - 80amp ESC & ProgCard Blade Crasher Aircraft - Electric - Helis (FS/W) 1 Jan 10, 2013 11:54 PM
Help! HK YEP esc help Blade Crasher Electric Heli Talk 3 Dec 09, 2012 08:13 AM
