Old Jan 06, 2004, 11:57 PM
kmashima is offline
Find More Posts by kmashima
kmashima's Avatar
San Jose, California, United States
Joined Feb 2002
World Models Velox
Hi Folks
Just got my Velox done last night and tested it for the first time today. Wow! This is a great flying plane. Did some stall tests at full 3D elevator rates. From level flight, I shut off the throttle and pulled back the stick. It nosed up and mushed forward. Very unlike the Funtana 40.
kmashima is offline Find More Posts by kmashima
Old Jan 07, 2004, 12:04 AM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
The finish on the plane is excellent. The parts are outstanding. I particularly like the polished and contoured CF landing gear. It's the nicest I've seen so far and I've bought a lot of them. Also the spinner is excellent with an aluminum back plate and brass adapter to fit perfectly on the motor shaft.
So here's some config info:
Motor - Hacker C50-10L, 6.7:1
Servos - JR DS368s + 2 Futaba 3102s for the elevators
Thunderpower Lipos Tested:
5s3p + 19x10. 20x8, 20x10 AUW approx 8lbs 4 oz less than 55amps
6s3p + 17x10 AUW approx 8lbs 10 oz @58amps
I liked the last config the best. It had a thrust reading of over 10lbs.
While the overall performance was excellent for pattern, the plane needs a bit more thrust for 3D. I will hover, but it needs a bit more to achieve unlimited vertical performance.
Old Jan 07, 2004, 12:11 AM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
The plane flies very straight and is very responsive to the controls. I had my friend Greg S. assemble most of it and it has giant scale hinges to allow very large deflections on all surfaces. Hence the roll rate is very fast. Not as fast as the Funtana but more than you would need 3D.
The plane easily knife edges with no tendancy to pull to canopy or belly. It requires no additional offset to track vertically. The suggested CG seems to be right on. It almost feels a bit tail heavy.
The rudder is pull-pull. The elevator servos were mounted in the rear although the ARF was setup for a forward servo with a yoke push rod.
Old Jan 07, 2004, 12:15 AM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
I think the most impressive test today was the blender. I have a lot of 3D planes that do this but they don't flatten out very well at the end. They tend to be a bit nose high to keep from losing altitude. The Velox snapped perfectly and stop in to a level flat spin. It reminded me of the TOC videos. It was really great.
Below is the battery holder.
Old Jan 07, 2004, 12:21 AM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
So what's the bad news?
2 things -- landing and landing gear.
I had a hard time landing the plane smoothly today. I don't know if was nervousness from having a new plane or what. I had a couple of bouncy landings.
I had one good landing by putting in a ittle spoileron. This helped to allow the plane to be a bit more nose high without stalling. It's the same trick I'm using on my 80" Extra.
I ended up blowing out the landing gear on the 3rd landing -- which was pretty smoot. So the landing gear area needs to be beefed up.
I did a fix at the field and got in another flight. I did the blender on this flight and on the landing made a bad approach and stalled. Pretty much pancaked the plane. Blew out the landing gear some damaged part of the wing. It's all fixable. We have a predicted few days of rain ahead so I gues I will have the time.
Old Jan 07, 2004, 12:26 AM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
Power System
I would like to get a bit more thrust for unlimited vertical without adding more weight. Fortunately, I have a B50-13xl, 5.2 that should do the trick.
I think I will try an 8s2p with a 20x10 prop. Motocalc tends to overestimate amp draw and thrust so I'm hoping this will be in the 40amp peak range. Anyway, another 2lbs of thrust is what I'm looking for.
So I figure I have a pretty even weight trade off:
6s3p + C50L (18 cells)
versus
8s2p + B50XL + heatsink (16 cells)
The latter setup might be a bit lighter. In any case, the plane will be under 9lbs.
-- Kyle
Old Jan 07, 2004, 05:58 AM
a2zprod is offline
Find More Posts by a2zprod
United States, WA, Spokane
Joined Oct 2001
Great looking model Kyle. I'm glad you jumped on the project right away. I will be following this post. Did the carbon gear hold up? Justing failed at the mounting area?
Rob
a2zprod is offline Find More Posts by a2zprod
Old Jan 07, 2004, 08:17 AM
kelvin is offline
Find More Posts by kelvin
Involuntary Beta Tester
Joined Jan 2002
Re: Power System
-- Kyle
Another great conversion. What are the dimensions of this model.
Is that the landing gear that comes with the ARF or is it custom?
I noticed the 2p packs you're thinking of trying. Are you experimenting with Tanic lipos now?
Any chance someone can take a video of this plane? Looks like you're getting ready for MWE. I wish I could come this year .
Kelvin
kelvin is offline Find More Posts by kelvin
Old Jan 07, 2004, 09:01 AM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Beautiful work Kyle...
You are always on the cutting edge of conversions. Looks great!!
Kirby
kepople is offline Find More Posts by kepople
Old Jan 07, 2004, 09:19 AM
rcman is offline
Find More Posts by rcman
rcman's Avatar
Logan, Utah, United States
Joined May 2002
That looks great Kyle
Once again you have done a great job
Are you taking it to MWE this year???
David
rcman is offline Find More Posts by rcman
Old Jan 07, 2004, 09:20 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Very nice Kyle!
You’re the leader when it comes to doing WM conversions.
Kelvin, here’s the link: http://www.theworldmodels.com/para/p...?airplaneid=64
Kyle, your thoughts of the Tai Ji 60 on 20cells?
jrb is offline Find More Posts by jrb
Old Jan 07, 2004, 09:30 AM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
Specs:
Wing Span : 65 in / 1650 mm
Wing Area : 769 sq in / 49.6 sq m
Flying Weight : 8 lb/ 3650 g
Fuselage Length : 57 in/ 1450 mm
Engine Required : 2C 0.61cu in
4C 0.70-0.91 cu in
Old Jan 07, 2004, 09:33 AM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
Thanks everyone for the kind words.
Rob
The CF gear is very nice and very strong. The ply section came out. It needs larger triangle stock to hold it to the formers.
Kelvin
The LG is stock. Will try to video and I DO plan on bringing it to MWE. I have not tried Tanic cells.
It's a 60 size plane so it's about the size of the Aeroworks 60 size Edge 540 that Hacker converted. I think this plane is quite a bit lighter. If you've seen that plane, then you have an idea of how this plane performs.
-- Kyle
Old Jan 07, 2004, 01:27 PM
kmashima is offline
kmashima's Avatar
Joined Feb 2002
Jrb
20 cells on a Tai Ji should work. I've converted the Zen 50 on 16 cells. With Lipos, it would be killer. The Zen with Lipos will be a full pound lighter -- probably just under 7lb AUW.
-- Kyle
Old Jan 07, 2004, 08:53 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Kyle,
I can always count on you to come up with something new and interesting. It seems you have outdone yourself this time.
Great looking airplane and it sounds as if it will become one of your favorites.
I'll be looking forward to seeing it in person at SEFF !
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
The World Models Velox Rev II Lynxman Glow to Electric Conversions 101 Apr 08, 2016 12:30 PM
The World Models Velox Rev II. Lynxman Sport Planes 9 Aug 14, 2005 07:02 AM
World Models Velox 60 Axified with 4130/20 and Gp3300 Magna Sport Planes 12 May 13, 2005 05:10 AM
World Models Velox kmashima Aircraft - Electric - Airplanes (FS/W) 9 Nov 28, 2004 08:59 PM
Velox II World Models flycatch Sport Planes 1 May 27, 2004 02:53 PM
