Hoverthings FLIP FPV Quad
Hoverthings has created a very durable multicopter frame designed for low-level sorties.
A durable platform for fpv flying
Hoverthings has created a very durable multicopter frame designed for low-level sorties. The FLIP FPV consists of 3 G-10 plates sandwiched together with aluminum spacers. The arms are made of thick G-10 with slots cut for most popular motors in its size range. The FLIP FPV is available in a number of colors and patterns. As an owner of a camo FLIP FPV, I can attest to its durability. I've had one midair collision with a Flamewheel and 4 unplanned "landings". I've broken many props, trashed a motor, and a vtx antenna, but the frame has come out on top every time.
The FLIP FPV is made in the U.S.A.
Specifications:
  • Price: $100
  • Size: Width 14.5" (375mm) Length 11" (280mm)
  • Diagonal Measurement: (diagonally motor to motor): 450mm
  • Weight: 12 oz. (350g)
Cruisin' with the Hoverthings Flip (1 min 29 sec)
Flip test 2 - a gentle thrashing...(long arm rebuild) (5 min 58 sec)
Old Apr 01, 2013, 12:15 AM
xhover is offline
Find More Posts by xhover
xhover's Avatar
Joined Mar 2012
FPV-Backyard racing Flip-FPV frame (2 min 31 sec)
xhover is offline Find More Posts by xhover
Old Apr 01, 2013, 11:12 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Awesome flying in that video!
wparsons is offline Find More Posts by wparsons
Old Apr 01, 2013, 03:44 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Great Vids!
Thanks for helping me out with my Flip Matt!
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Apr 01, 2013, 08:32 PM
AlanFlorida is offline
Find More Posts by AlanFlorida
AlanFlorida's Avatar
USA, FL, Palm Harbor
Joined Jul 2004
Simply awesome! I love my HoverThings Flip FPV!! Mine was built by WiteSpy and I am amazed how good it performs!! I Have been so very impressed with all of the HoverThings designed Quads!!
AlanFlorida is offline Find More Posts by AlanFlorida
Old Apr 03, 2013, 06:57 AM
spiked3 is offline
Find More Posts by spiked3
United States, WA, Seattle
Joined Apr 2007
So, how do people mount FPV cameras? I see lot's of GoPro footage, but a GoPro has a few milli-seconds latency. Do people just fly with that? I've flown FPV with it, and it wasn't that bad for casual flying, but I'd be a little worried about it for close quarter flying. How do you deal with unreliability of a GoPro? Or do you just go for it and hope? Mine (V2) turns itself off 5 out of 10 times at random. It's not a setting or it would do it all the time. It records only when the footage is unwanted. It's great for capturing boring footage though.
Also what FC board is preferred on the flip? Any success with a KK 2.0 board? I see the first picture with a NAZA - will the NAZA do acrobatics? I've heard to avoid self level mode, but I'm trying to get off that anyhow so that is ok. Is the NAZA ok in manual mode?
8" props preferred over 10"?
More details (any) would be nice in this 'review'.
spiked3 is offline Find More Posts by spiked3
Old Apr 03, 2013, 08:33 AM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
The popular consensus is to use a separate flight camera, like an RMRC540 or RMRC600 and let the gopro just record on its own. The GoPro's video-out quality isn't as good as the flight camera, and you risk having the GoPro shut off.
The pic in the header is my personal FLIP, Im using a NAZA and have not used others. I fly mostly in manual mode. Its very responsive indeed. Never flipped or rolled it though so I cant comment on that aspect. Your choice of prop is dictated by your motors. I will tell you that 10" props get too close to the GoPro for my taste. Im using 9x4.7" props and RCTimer 2212 1000kv motors. Its a solid combo with plenty of power and run time on 3s 4200 MAh.
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Apr 03, 2013, 11:28 AM
spiked3 is offline
Joined Apr 2007
Well I can verify the goPro gets too close, many many scuffs and scratches, but the flip fpv frame does not have mounting for a dual configuration. I drilled my own holes and did it anyway and it still sucked. Its made for one cam only and it will only hold one camera comfortably. BTW I'm running the same props and motor, and rc timer SimonKs, but so far the APM controller has been unusable after a pain the butt mounting effort. So I guess I will try the NAZA next, and go back to just a GoPro, it can't get any worse.
apm25 (2 min 5 sec)
Old Apr 03, 2013, 12:09 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Theres plenty of room for the GoPro and a small flight cam to share the same front platform. heres a picture showing them both on there:
Administrator
Old Apr 03, 2013, 12:33 PM
spiked3 is offline
Joined Apr 2007
I guess we have different definitions of 'plenty'. In any case, that is not what the mounting positions are cut for, but if your comfortable with the camera hanging over the edge, then sure, I guess you could. Could you provide a picture of the cameras in that configuration? Where you drilled the FPV cam mount? How you tied the GoPro down, what mounting you used for the GoPro?
Old Apr 03, 2013, 12:50 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Here you go. Easy to drill the camera mount. I'm using a piece of rubber sorbothane under the camera and a woman's hair band to hold the gopro down. The gopro doesn't really hang off much... in no way in danger of falling off.
You can always move the flight camera out more since its bolted down. that will bring the gopro in a bit. But since Ive flown the heck out of mine with no issues, Ill tell you this configuration works just fine
Administrator
Old Apr 03, 2013, 02:07 PM
Moto Moto is offline
Find More Posts by Moto Moto
Herd WarpSquad
Moto Moto's Avatar
United States, AL, Guntersville
Joined Dec 2012
That looks like a nice frame, but why would you want something that may get lost in the woods to be camouflaged? I want day-glo orange or something visible like that to aid in recovery.
Moto Moto is offline Find More Posts by Moto Moto
Old Apr 03, 2013, 02:18 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
eh... choosing a day-glo color to aide in finding it on a hypothetical search and recovery mission didn't really cross my mind when I built it. I mean, to each his own, but I dig the camo and have not dumped anything in the woods yet to where I cant find it.
Administrator
Old Apr 03, 2013, 10:53 PM
spiked3 is offline
Joined Apr 2007
Thanks. I'll modify mine that way. The over under thing didn't work out too well. I see what you mean about moving the FPV cam out a little more. I've got the Lens protection thing (getfpv layerlens) on the goPro, so I'm not sure I can do just like that, but I'll figure it out. Replacement parts for the last disaster arrived today, so off I go.
I had asked about the GoPro mounting before (elsewhere) and never really got an answer. thanks for that pointer - which thickness? I see a bunch of different ones on eBay; http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
BTW I did the exact same color scheme. I have a bunch of the hobby king lost beepers to test to see which one I like, for if it ever gets lost in the woods, but I'm hoping mostly to use soccer goals as pylons and some soccer field racing. So camo is not an issue
edit: nice pics BTW. I recognize the level of effort
https://picasaweb.google.com/1046678...ascades3_30_13
Old Apr 27, 2013, 08:06 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
THE FLIP FPV OF ALL FLIP'S
6S yeah you read right 22.2V Powered Flip FPV
Check it out here for full details and pictures!
http://www.rcgroups.com/forums/showthread.php?t=1879166
flohio117 is offline Find More Posts by flohio117
Discussion Hoverthings FLIP FPV Cralis Multirotor Talk 5016 May 15, 2016 05:58 PM
Off Site "FLIP FPV" frame $85.00 at HoverThings.com thrillkiss Aircraft - Electric - Multirotor (FS/W) 14 Mar 19, 2013 01:13 PM
Discussion HoverThings Scratch & Dent sale "FLIP FPV" frame $85.00 thrillkiss Hot Online Deals 0 Mar 17, 2013 12:10 AM
Found Hoverthings FLIP FPV frame or ARF setup thrillkiss Aircraft - Electric - Multirotor (FS/W) 3 Mar 02, 2013 10:32 AM
Discussion Hoverthings Flip quad. nforbesrc99 Multirotor Talk 3 Jan 11, 2013 08:28 PM
