Old Apr 02, 2013, 03:06 AM
ed_jza80 is offline
Find More Posts by ed_jza80
Joined Dec 2007
lol, so correct! haha, fits my rctimer motors perfectly though!
3 bolt prop mount.... blagh...
ok Beta revision #1 coming right up! thanks for point it out before i printed it!
cheers
ed
EDIT : Updated to v1.02
http://www.shapeways.com/model/10072...ductBox-search
ed_jza80 is offline Find More Posts by ed_jza80
Old Apr 02, 2013, 05:27 AM
ed_jza80 is offline
Joined Dec 2007
and finally option #1 for more conventional 'hang' mount
(instead of the funky X-member for my frame!)
http://www.shapeways.com/model/10078...2288d58be8aa05
without screws, orings, and motors etc, the complete gimbal weighs 36grams!
again, .stl file directly downloadable from shapeways
edit - just edited it to include the antivibration mount
Old Apr 02, 2013, 05:36 AM
mare22 is offline
Find More Posts by mare22
ma:re
Joined Nov 2012
Originally Posted by ed_jza80 View Post
Ok here's mine...
SkyLight SBG
Opensource 3D Printable Gimbal v1.01
(note - currently BETA... still yet to be held in human hands and tested!)
for use with: Flyduino 2208 Brushless motors
IMU mount-pad dimensions designed for the Alex Mos Controller (23mmx23mm)
Shapeways link:
http://www.shapeways.com/shops/RapidSequence
.stl file is downloadable through the shapeways pages
(ill do it that way, so with updates, and modifications for other mounts etc, the latest file is available with the model. saves trying to keep track of version updates in a thread!)
cost on shapeways is only about €45
(and thats including my large X-member mount)
Exra parts needed
M2 x 10mm screws (x8)
28x1.5mm O-Ring (x2)
Optional Lens Cover: Sternkreuz HW (High Dome, no step) 21.4mm
(i can buy a bunch of wholesale Sternkreuz lens covers, along with a bulk bag of orings if theres enough interest)
https://vimeo.com/63122371
Great stuff, thanks a lot.
How are you going to do isolation? With silicone bobbins between top and bottom?
by the way, the shapeway price for Europe is 58,71 Euros... weird!
mare22 is offline Find More Posts by mare22
Old Apr 02, 2013, 05:52 AM
ed_jza80 is offline
Joined Dec 2007
isolation is already built into my frame, so not something i had to consider for my version.
theres so many ways to mount one of these suckers, that with the second 'hanging' mount that i just posted, i figured id get the basic shape there, and being open source, people can edit it as they please to suit whatever
if folks want an isolated, 'all in one' generic gimbal mount, i could spin that up pretty quickly and throw it into up for opinion
higher euro price = tax maybe?
Old Apr 02, 2013, 06:11 AM
ed_jza80 is offline
Joined Dec 2007
something like this for example...
(edit - just updated my post above with the less generic vibration isolation mount)
double edit - just started a new thread with this gimal version - its heading away from my design, and id rather concentrate on that in this thread
http://www.rcgroups.com/forums/showthread.php?t=1864420
for use with x4 rubber ball isolators...
http://photoshipone.com/shop/index.p...roducts_id=212
Old Apr 02, 2013, 10:50 AM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
How does this work with the go pro 1? The cg will be off?
v00d0o is offline Find More Posts by v00d0o
Old Apr 02, 2013, 12:22 PM
ed_jza80 is offline
Joined Dec 2007
gp2 is much heavier than version 1 from memory. i dont imagine itd be interchangeable. gimbals need to be setup relatively 'camera specific'
cheers
ed
Old Apr 02, 2013, 01:13 PM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
cheers
ed
So, instead of making them fit specific cameras (and motors) why not do what many others are doing and put in slots for mounting so things can be moved around a bit for perfect CoG - especially as the balance on your first one is as yet untested?
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Apr 02, 2013, 01:42 PM
BorisSA is offline
Find More Posts by BorisSA
Austria, Wien, Vienna
Joined May 2011
guys can one of you enlighten me ?
I am in the process of designing a gimbal for DSLR nex to gh3 etc. like alot arround already. Printer parts again etc.
Now having had a zenmuse one of the first gh2 zenmuses and having adapted it for the GH3 i went through a lot of balancing processes, since otherwise the zenmuse dosent calibrate.
No there is a balance point the zenmuse has which all the other gimbals dont seem to have which is like in the video time : 10:10 the pendulum effect.
http://www.youtube.com/watch?feature...&v=jv0Xc67beE0
No need for it ?
Boris
BorisSA is offline Find More Posts by BorisSA
Old Apr 02, 2013, 02:19 PM
countryshooter is offline
Find More Posts by countryshooter
countryshooter's Avatar
United States, NJ
Joined Oct 2011
the gimble I got, I raise the camera plate to get that balance point you have to get the 3 axis balanced as close as possable or you will see in programing graph that the motors are working to keep it level
countryshooter is offline Find More Posts by countryshooter
Old Apr 02, 2013, 03:53 PM
ed_jza80 is offline
Joined Dec 2007
size, simplicity, and generally wide spread use of gopros as an onboard camera makes it an easy choice
that, and i designed mine 'for me' but the files are there for anyone to take, and modify to use as they like... so go nuts and make it as adjustable as you desire.
and the perfect balance is one revision away. not particularly difficult design task
Old Apr 02, 2013, 04:03 PM
tstrike is online now
Find More Posts by tstrike
tstrike's Avatar
United States, UT, Cottonwood Heights
Joined Mar 2012
ed, nice design, one question-can a live out video feed still be used on your design? It looks like the pitch motor blocks access. Thanks!
tstrike is online now Find More Posts by tstrike
Old Apr 02, 2013, 04:15 PM
ed_jza80 is offline
Joined Dec 2007
yeah, thats an overriding bit of feedback ive gotten ill make the ports accessible
cheers
ed
Old Apr 02, 2013, 04:53 PM
Joined Jun 2012
Well, I don't have access to a 3D printer. Nearly bought one just last week, but probably wouldn't make full enough use of it. Plus, the 3 different versions of GoPro 3 (Black, White, Silver) all weigh different amounts and not everyone can splash out on a Black, but as you say, not an issue for you.
I suspect you'll need more than one revision though, as each one will be a guess as you try and zero in on the correct balance, under- and over-shooting it by less each time, so actually an adjustable mounting method would help you.
Old Apr 02, 2013, 06:42 PM
Rod Cole is offline
Find More Posts by Rod Cole
Rod Cole's Avatar
United States, TX, Austin
Joined Jun 2012
I am selling my RusticWave Gimbal kit (in assembled). Please PM if interested. Also have two R416 servos in the box never used.
Rod Cole is offline Find More Posts by Rod Cole
Mini-HowTo Super Simple Gimbal - SSG - KK2.1 & OpenPilot support crezzee Aerial Photography 1668 Feb 11, 2016 03:13 PM
Discussion Do you need something 3D printed. mungral The Builders Workshop 8 Jul 01, 2013 10:19 PM
Discussion Completely 3D printed micro quad frame waterhouse Scratchbuilt Multirotors 4 Mar 12, 2013 03:27 PM
Idea 3D printed Camer Gimbal danielpetrescu Aerial Photography 1 Jan 23, 2013 05:15 PM
Discussion 3D printed quad frame project waterhouse Scratchbuilt Multirotors 3 Jan 22, 2013 06:28 AM
