Old Jan 07, 2004, 09:02 AM
epilot is online now
Find More Posts by epilot
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Originally posted by Trizza
PS - how was the wax to turn? Looks like it made a good finish.
I'm sure you know the phrase: "Cuts like butter" - well, this "Cuts like wax" ie. very easily.
Graham, not a bad idea actuallyEdited by poster to avoid allegations of having unhealthy interests
Michael
epilot is online now Find More Posts by epilot
Old Jan 07, 2004, 09:30 AM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
Michael, sounds good. Not sure what you're implying with the hot wax though mate, remember this is a family-friendly forum
Trizza is offline Find More Posts by Trizza
Old Jan 08, 2004, 02:21 AM
brucej is offline
Find More Posts by brucej
Good glue is evil
melbourne australia
Joined Sep 2003
just had to try this
i just had to try this idea, raced out and grabbed some candles
here is a pic , it turns ok, but you have to watch the flaws in the wax, will wind up a coil tonight, its so cute i do not want to dip it in the hot water.
brucej
brucej is offline Find More Posts by brucej
Old Jan 11, 2004, 11:23 PM
brucej is offline
Good glue is evil
melbourne australia
Joined Sep 2003
well i got to dipping my wick in the hot water yesterday, and there is a couple of things i discovered.
1. use hot water
2. trim the wax first, keep what you put in the water to minimum
3. use a big container, as the wax floats and when you take the coil out of the water i was ending up with a thin waxy film on it
4. this process makes a very neat and square coil
brucej
Old Jan 12, 2004, 04:06 AM
Littlescreamers is offline
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
Bruce,
You need to clean that lathe! Man that thing is a mess, And can damage the way's from all that grit and oils will make a good lapping compound.
Just my2cents.
But love the project
Scott
Littlescreamers is offline Find More Posts by Littlescreamers
Old Jan 12, 2004, 05:58 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
yes mother
Looks like the dirt is on the bench not the ways, it's only a wee one
Graham Stabler is offline Find More Posts by Graham Stabler
Old Jan 12, 2004, 11:46 PM
brucej is offline
Good glue is evil
melbourne australia
Joined Sep 2003
hi guys i know what you mean about the grit but this lathe is well past its use by date, the bed has worn to an S shape, but it still makes small projects if i use some tricks, and hey if i clean the bench i will never find anything !
brucej
Old Feb 17, 2004, 01:40 PM
Gerhard is offline
Find More Posts by Gerhard
Los Gatos, CA, USA
Joined Nov 2003
Hi All,
I have made a few coils using the method described, but I am having a problem. I am using CA to hold the coil together, and when I let the wax melt (with hot water) there is always a residue of wax on the outside of the coil that seems to be bonded with the CA. It is of course, almost impossible to scrape off without damaging the this wire. Does anyone have any suggestion as to what I may be doing wrong?
regards,
Gerhard
Gerhard is offline Find More Posts by Gerhard
Old Feb 17, 2004, 01:48 PM
j8m8l is offline
Find More Posts by j8m8l
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
I made a batch of these "bobbins" last friday at school. Managed to get down to a 2.5 (ish) inner dia without any metal core.
I will try out this method during the week with some 0.02mm wire from Fill.
Josh
j8m8l is offline Find More Posts by j8m8l
Old Feb 17, 2004, 01:49 PM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
Try switching to one hour epoxy, the wax can be cleaned off with rubber cement thinner, which is similar to film cleaner. Tri-chlor-ethane I believe is the chemical name for the solvent.
Dave
Dave Wulff is offline Find More Posts by Dave Wulff
Old Feb 17, 2004, 05:16 PM
Alfredo Rubio is offline
Find More Posts by Alfredo Rubio
Moderador.
Alfredo Rubio's Avatar
guadalajara, jalisco, mexico
Joined Sep 2002
Yesterday I remember this method to make the coins, because I did it very "artesanal"..... with balsa containers, paper rolls with maskin tape, and grease!!!!!! this method looks great, and I not expent many time!!!!
Thanks Mike
Alfredo Rubio is offline Find More Posts by Alfredo Rubio
Old Feb 17, 2004, 11:24 PM
brucej is offline
Good glue is evil
melbourne australia
Joined Sep 2003
wax on coil
when i made mine i used clear nail polish , not as quick as CA but only takes a few minutes to dry,and does not stick the coil to the wax,
in my post above, i made mention of wax on the coil after melting in hot water, the trick seems to be to trim as much wax off first, and use a LARGE pot of water and give the coil big swirls to wash the wax off, this makes a nice coil.
brucej
Old Nov 28, 2005, 06:43 AM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Thanks Michael for this great idea. Now I will try to make custom coils as well...
Chris
Chris T is offline Find More Posts by Chris T
Old Nov 29, 2005, 03:31 AM
westfw is offline
Find More Posts by westfw
westfw's Avatar
Joined Nov 2004
Crayons might be cheaper than candles, depending on whether you can use
the normal sized crayons. If you've got kids, you've probably got all sorts
of broken crayons around just waiting to be made into coil forms...
BillW
westfw is offline Find More Posts by westfw
Old Nov 29, 2005, 07:21 AM
aerogel is offline
Find More Posts by aerogel
Thanks for the Fish!
aerogel's Avatar
Land of cajuns
Joined Dec 2001
If you have the ability to machine a bobbin out of metal or soft plastic or you could just scratch build one
You can make a Rtv mold out of that bobbin and just poor hot wax into itů
Mini Production line with out all the time spent trying to machine matching bobbins
If you need a high quality wax is needed I suggest machine wax most of the time its comes in blue
aerogel is offline Find More Posts by aerogel
