Old Jan 06, 2004, 12:35 PM
HankF is offline
Find More Posts by HankF
Joined Apr 2000
LiPo cell imbalance: How Long, How much?
There seems to be much concern about cell imbalance especially in series packs. Is there any data that shows how long (how many charges) it takes before you have to rebalance? How much imbalance can be tolerated?
Hank
HankF is offline Find More Posts by HankF
Old Jan 06, 2004, 12:42 PM
uscra112 is offline
Find More Posts by uscra112
Mid-Michigan
Joined Aug 2002
You don't want much if you charge to full capacity every time. Maybe 0.1 volt difference max. Thing is, once they're balanced, they seem to stay this way for a good long time. Only LiPo pack I've had so far that has gone out suffered significant crash damage.
I've charged 3S packs of the old Sony Li-Ion 18650 cells dozens of times and saw no imbalance creep in at all.
Be warned about the crash damage thing, though. The LiPo pack broke loose and hit the back of the motor. Crushed the ends of some of the cells by 1/8". By a cursory check it appeared to be OK. Would take a charge, would discharge as if it were OK. But one of the damaged cells was leaking electrons internally, so that cell started to drop at about 1 volt per day. In a day it would have been sufficiently out of balance to present to opportunity for disaster if I had charged it in that state.
uscra112 is offline Find More Posts by uscra112
Old Jan 07, 2004, 05:03 AM
Suzanne is offline
Find More Posts by Suzanne
Germany
Joined Dec 2001
I'm afraid there seems to be no easy answer.
I have measured many packs, and some are still fine after fifty cycles, while others are way out of balance after only a dozen cycles.
One of the contributing factors is temperature profile across the pack, another is self discharge.
The worst packs I've seen had one cell with higher self discharge rate than the others.
Some people swear that the problem of pack imbalance doesn't even exist, others have lost quite a few packs already due to imbalance / resulting overcharge / ballooning.
So you have four options at this time:
1) ignore the problem and take the risk
2) add center taps, measure your cells frequently and charge individually, when required
3) put LiPo-Balancers in your packs or charging harness
4) use a special system of connectors and cables to charge all cells in parallel (practical for smaller packs only)
Suzanne is offline Find More Posts by Suzanne
Old Jan 07, 2004, 01:24 PM
HankF is offline
Joined Apr 2000
Thanks Suzanne.
It looks like in any case that the cell terminals have to be accessable whether they are center tapped or a balancing circuit is used. It would seem to me that the easiest and cheapest method would to be to use center taps and small sockets like Tanic is using. The center tap wiring and sockets would not have to be heavy since it is not going to carry much current to charge the individual cells.
BTW, I just got a Micro Mark catalog and they are advertizing a Li-ion powered Dremel tool. So Li technology is moving into the power tool business.
Hank
Old Jan 08, 2004, 05:12 AM
Suzanne is offline
Germany
Joined Dec 2001
Hank,
if you use LiPo-Balancers, you do not need center taps.
Old Jan 08, 2004, 07:44 AM
debogus is offline
Find More Posts by debogus
Beaumont ,peoples republic of Kalifornia
Joined Jan 2004
LiPo-Balancers?
What are they and who sells them?
Dave
debogus is offline Find More Posts by debogus
Old Jan 08, 2004, 08:54 AM
uscra112 is offline
Mid-Michigan
Joined Aug 2002
Suzanne's own product.
Old Jan 08, 2004, 11:10 AM
Suzanne is offline
Germany
Joined Dec 2001
Re: LiPo-Balancers?
Dave
Dave,
I have made the schematics and PCB layout available here for everybody to use:
http://www.rcgroups.com/forums/showt...hreadid=157641
If you have any questions on how to build them, just ask and I'll try to help.
Also, if you don't want to build your own, I still have some stock.
Suzanne
Old Jan 08, 2004, 12:01 PM
houfek is offline
Find More Posts by houfek
PittsLover
houfek's Avatar
Ohio
Joined Jul 2003
Now I'm confused. I thought you DID need to have center taps of series packs.....but in post 5 of this thread, Suzanne says:
"if you use LiPo-Balancers, you do not need center taps."
Help !
Jim
houfek is offline Find More Posts by houfek
Old Jan 08, 2004, 02:30 PM
HankF is offline
Joined Apr 2000
Jim: The question is when is a center tap not a center tap? How can you balance a pack without access to each cell's terminals? Maybe I just don't understand Suzanne's method.
Hank
Old Jan 08, 2004, 02:52 PM
uscra112 is offline
Mid-Michigan
Joined Aug 2002
Suzanne's gizmo does have a connection to each cell, but it need not be accessible from outside the pack. Is it a tap? Well, not if you consider external access as defining a tap. Semantics.
BTW I have done a pack with taps, and proceeded to short one against the ESC when I was stuffing the pack into the plane. Plane launched OK. 20 seconds later the ESC burned to a crisp.
At least I think that's what caused it. They were shrink-tube covered, but that must have been cut thru by pressure or vibration or both. Makes Suzanne's solution (i.e no exposed taps) look more attractive.
Test data on 3s Lipo cell imbalance due to heatup of central cell kodel Batteries and Chargers 7 Aug 28, 2004 10:21 AM
Some data on LiPo cell imbalance Suzanne Batteries and Chargers 30 Jan 12, 2004 07:09 PM
LiPo cell imbalance causes what kind of problem ? sheerLuck Batteries and Chargers 2 Jan 02, 2004 07:54 PM
How long do u run your Etec lipo in hornet cp with speed 300 motor yapjy Micro Helis 0 Jun 10, 2003 11:10 PM
How long to charge new LiPo's genenjr420 Batteries and Chargers 4 Apr 25, 2003 07:16 PM
