Nov 24, 2004, 06:37 AM
Alexandria, VA
Joined May 2004
Hey, Alfa P-51 Ace mechanics,
I'm putting together my Mustang now. While my servo is working the aeilerons fine, the GWS Naro servo is wiggling back and forth in it's slot in the wing. When it moves, the aeileron's travel is not using the full power of the servo, nor are the aeilerons traveling with consistancy.
How do I secure a Naro servo into that slot? There is about 1/8" left open on one side, which I tried to plug with a wedge of balsa, but it still moves a lot. The "edge" of the wing slot that the servo uses to push against is as thin as the wing skin.
Do I need to build some kind of balsa cage that is glued to the inside wing?
I know they say to glue the servo in place, but then you can't rotate the servo out to access the servo arm screw for adjusting the aeileron rods.
Thanks for any help.
Michael
