This thread is privately moderated by Jack_LaLanne, who may elect to delete unwanted replies.
Old Mar 26, 2013, 05:04 PM
Jack_LaLanne is offline
Find More Posts by Jack_LaLanne
Jack_LaLanne's Avatar
Germany, Berlin
Joined Feb 2009
Build Log
Turnigy 9XR radio and Rangelink transmitter Connection
I received a lot of new stuff including a Turnigy 9XR R/C radio and a rangelink long range system (LRS). The creation of a cable was needed to connect the two:
The 9XR pinout on the module port matches standard JR configuration. Top to bottom: PPM signal, +6V, +BATtery, GrouND, ANTenna (fig. 1).
The Rangelink transmitter must be provided with PPM, BAT and GND. The three pins are not in direct vicinity on the 9Xr end due to the JR configuration. So a servo connector with 3 terminals cannot be used. Since no spare 4 pin connector was available, a novel connector was created from two pre-wired JST plugs (default plug type on some low discharge battery packs). Removing one of the pins and its wires so that the +6V pin on the 9XR module port remained unused resulted in the needed configuration: PPM, none, +BAT, GND. The plugs were trimmed to match and glued together with CA. The wire terminals were soldered to the according wires on the Rangelink R/C transmitter connector providing a plug and play cable (fig 2).
The adapter with JST plug fits well on the rather long 9XR module pins, protecting them from shorts and avoiding unintential removal. The Rangelink transmitter was taped to the 9XR and the module slot was protected using fiber tape (fig 3 and 4).
Jack_LaLanne is offline Find More Posts by Jack_LaLanne
Old Jun 17, 2013, 02:03 PM
auxiliarypower is offline
Find More Posts by auxiliarypower
Joined Apr 2013
Jack you might want to look into something like this for your system. I have a 9XR and a Rangelink system and I can't wait to get my hands on one of theses.
http://www.thingiverse.com/thing:101766
auxiliarypower is offline Find More Posts by auxiliarypower
For Sale Turnigy 9XR Transmitter Mode 2 (No Module) with LiFe battery ckleanth Aircraft - General - Radio Equipment (FS/W) 2 Jun 18, 2015 06:52 AM
Question Rangelink UHF transmitter reciever brian.blackshear FPV Talk 0 Feb 23, 2013 03:04 PM
New Product NEW Turnigy 9XR transmitter....Release LexusFPV FPV Talk 3 Nov 14, 2012 07:48 PM
Discussion NEW Turnigy 9XR transmitter....Release LexusFPV Electric Plane Talk 1 Nov 13, 2012 05:50 PM
