1258MHz & 1280MHz Pico Video Transmitters from ReadyMadeRC.com
Check out these micro video transmitters!
Small but Mighty!
Readymaderc.com has introduced a pair of micro video transmitters that take advantage of the stronger 23 cm band. Including a well-performing dipole antenna, the total weight of these little vtx's is only 3 grams. While frequency selection is limited compared to 5.8GHz, you can expect greater range and signal penetration from 1.2GHz. These transmitters are perfect for micro quads airplanes, and work with any receivers that have 1258 or 1280 channels.
Specifications:
  • Frequency 1258 MHz
  • Power Output: 30-50mW
  • Includes transmitter with integrated dipole antenna
  • Power requirements: 5V, 20mA
  • Weight: 3g including transmitter, antenna, and integrated power/video cable
  • Wiring:
  • Red: 5v
  • Black: Ground
  • Yellow: Video
Learn More Here
Old Mar 26, 2013, 11:57 AM
cactus is offline
Find More Posts by cactus
Micro Fpv=BVLOS around couch
United States, CO, Durango
Joined Sep 2001
Subscribed. I have one of these on order to experiment with a micro quad around my front yard or basement during cold windy days. I am going to pair it with a 3 gram wide angle CMOS 5V camera and power it with a Pololu 5V Step-Up/Step-Down Voltage Regulator weighing less than a gram. I am going to try sharing the input with the flight lipo, but if the line noise is too bad I will use a single UMX 1S 70-120mah battery. My first try will be on the Blade mQX. My biggest concern is the 1280 video stepping on the 2.4 ghz control and reducing range. My second is keeping the weight down. The canopy weighs just over 5 grams, so If I can ditch it for a small mount for the FPV gear I may only be adding 5 grams net.
cactus is offline Find More Posts by cactus
Old Mar 26, 2013, 12:54 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
I want one as well. I foolishly ordered a 5.8GHz micro unit and then saw this little gem after I ordered!
And yes, the noise will be too strong from the integrated esc's. I build one as well and even with a filter, I couldn't get rid of the lines. A separate video lipo solved it for me.
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Mar 26, 2013, 10:16 PM
ueadian is offline
Find More Posts by ueadian
United States, UT, Herriman
Joined Mar 2010
I've used this on my micro hex. Range is pretty decent. I get about 300 feet in an urban enviroment with a stock dipole on the receiver. I upgraded to a patch antenna and can get quite a bit more then that, and much better behind building penetration. Works awesome for my application.
ueadian is offline Find More Posts by ueadian
Old Mar 26, 2013, 10:21 PM
cactus is offline
Joined Sep 2001
Well, in this case a separate 1s 100mah lipo with step up regulator may be better than a filter unless the filter can be built very light but most of the ones I have seen use heavy torrid rings.
Old Mar 27, 2013, 09:12 AM
richgraf is offline
Find More Posts by richgraf
Joined Nov 2004
I think this is just what I've been waiting for. Also looking to use it on a very small Quad like the V959 or maybe even 1SQ.
Rich
richgraf is offline Find More Posts by richgraf
Old Mar 27, 2013, 01:30 PM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
big advance for the ongoing long range micro FPV challenge. maybe 2km or 3km in reach now with AUW of 100g???
got my micro FrSky receiver ready and will add signal amp to it. this vTx and my micro Stryker ...
but then only 50mW. better be a very good antenna - maybe a V if it can be made light enough. I have the tuned patch
must buy now
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old Mar 27, 2013, 02:52 PM
cactus is offline
Joined Sep 2001
I'll be happy if it makes it down my street and back.
Old Mar 28, 2013, 04:06 AM
fly by night
Joined Sep 2011
I have a friend here in town who picked up a 10mW 1280 vTx. He is not heavily into FPV, but he is a very smart dude - I think an electronics engineer. He made his own CP antennas using a SWR meter. He easily achieved 600m clear video on 10mW on a sub-mini sized all-carbon quad. nice
Old Mar 28, 2013, 04:11 AM
Hajile is offline
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Link says 403 forbidden. Readymaderc seems like one of the peopular rc sites but i can't access it. Is the site online?
Hajile is offline Find More Posts by Hajile
Old Mar 28, 2013, 05:28 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Well now we only need some small 1.2 VRx as well.
boopidoo is offline Find More Posts by boopidoo
Old Mar 28, 2013, 08:35 AM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Hmmm. the link works on my end.
Administrator
Old Mar 28, 2013, 08:36 AM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Originally Posted by boopidoo View Post
well now we only need some small 1.2 vrx as well.
lol!
Administrator
Old Mar 28, 2013, 11:52 AM
jorispicooz is offline
Find More Posts by jorispicooz
Joined Dec 2012
a carbon micro qaud? do you have pictures of that??
jorispicooz is offline Find More Posts by jorispicooz
Old Mar 28, 2013, 03:12 PM
fly by night
Joined Sep 2011
found the thread here with his little quad. not micro, but smaller than mini size. He told me he designed it and had all parts laser cut. fine craftsman. This was with Multiwii and it flies great. so small too. And yes, 600m+ with solid video on 10Mw
http://pwrcfs.com/forum/showthread.p...ight=mini+quad
New Product New US Legal 1258Mhz Gear Only @ReadyMadeRC.com h0tr0d FPV Talk 47 Aug 06, 2015 08:34 AM
Discussion New cam for night flying from readymaderc.com G-unit FPV Talk 28 Mar 26, 2015 07:51 AM
Sold ReadymadeRC PICO WIDE 5 volt NTSC camera. G-unit FPV Equipment (FS/W) 4 Jan 28, 2013 08:01 AM
Sold 1.3GHz 300mW Transmitter - CUSTOM READYMADERC US VERSION yosemitez FPV Equipment (FS/W) 6 Jan 14, 2013 01:55 PM
Sold PRICE REDUCED! Lawmate 1280mhz 1W video Transmitter Crist Rigotti FPV Equipment (FS/W) 9 Apr 20, 2011 08:35 PM
