Old Nov 26, 2001, 03:25 PM
Crash King is offline
Find More Posts by Crash King
Lucas, Texas
Joined Aug 2000
CG on a MM Zagi
I got my MM mounted on the back of my Zagi, but I cannot get the CG right, Did you guys use weight, how did you get the CG forward. Is the MM moved forward, ie clearance between prop and back of wing is less than .5 inch. I put it in the trees because of stability problems yesterday. It sure flies rough with the CG off, it is about where my spar is now and not maneuverable at all.
Advice?
TIA
Crash King is offline Find More Posts by Crash King
Old Nov 26, 2001, 03:28 PM
Zephnorphd is offline
Find More Posts by Zephnorphd
Zephnorphd's Avatar
Spokane, WA
Joined Sep 2001
I had to add a little nose weight. Next project is to cut out the stock tray so I can move the batt further forward.
z
Zephnorphd is offline Find More Posts by Zephnorphd
Old Nov 26, 2001, 03:32 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
United States, WA, Tacoma
Joined Jun 2001
Is your spar installed 8" from the front ?.
8" is also the correct CG, right ?.
William A is offline Find More Posts by William A
Old Nov 26, 2001, 05:37 PM
Patrick H is offline
Find More Posts by Patrick H
Patrick H's Avatar
Longmont Colorado
Joined Sep 2001
motor size
Just bought a MM from tower hobbies. Got the reversed Magnetic Mayhem motor. Seems to be alot fatter than the stock speed 400. Did I get the right one?
Patrick H is offline Find More Posts by Patrick H
Old Nov 26, 2001, 09:39 PM
slowflyer is offline
Find More Posts by slowflyer
Flying slowly along..
Northern Ca.
Joined Dec 2000
I didn't have any probs with the cg on mine, but I don't use the stock battery tray. You can eliminate the front part of the battery tray and just mount a piece of coroplast instead, and velcro to that. Look in the Dreams of a vertical Zagi thread , for a drawing of a simple coroplast battery tray setup.
Yes you have the right motor, the MM is fatter then a speed 400. The quick andd dirty way of mounting it is to just shim under it with balsa and strap it on.
I will get my site up asap with pics and such.---Rob
slowflyer is offline Find More Posts by slowflyer
Where is the CG on a Zagi 3C DennisRB Slope 7 Jun 05, 2005 02:13 AM
Where is CG on a chopped Zagi? Duane Flying Wings 1 Dec 03, 2004 02:09 PM
8x4, 6.5x6.5 prop on MM zagi? DEATHspiral Foamies (Kits) 6 Feb 14, 2002 12:21 AM
8x4 Prop on MM zagi? DEATHspiral Electric Plane Talk 8 Feb 13, 2002 08:00 AM
CG on a Zagi like sloper tenover Electric Sailplanes 1 Oct 21, 2001 08:22 PM
