Old Mar 21, 2013, 04:16 PM
Sweetrex is offline
Find More Posts by Sweetrex
Addicted to my hobby
Sweetrex's Avatar
United States, NV, Las Vegas
Joined Sep 2009
Major Differences in FASST and S-FHSS
I can't find a discussion (although I'm sure it exists somewhere) about the major differences in the FASST and S-FHSS radio systems by Futaba. One thing I do see is a HUGE difference in pirces on the Rx's and Tx's. Can anyone comment? I'm not a competition level flyer and I don't have planes bigger than maybe the biggest parkflyers and maybe a bit bigger than that or faster than 120mph.
Sweetrex is offline Find More Posts by Sweetrex
Old Mar 21, 2013, 05:03 PM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
The actual RF chips are different. FASST uses the ML2724 (+their own chip for the DSSS modulation), where as S-FHSS uses the CC2500. The CC2500 is the same chip that is used in FrSky/Hitec/Graupner and other systems.
FASST is both DSSS modulation (like DSM2) and FHSS (frequency hopping) - much like DSMX. Where as S-FHSS is just FHSS - like FrSky/Hitec/Graupner systems.
Futaba seems to target FASST (and FASSTest) as their premium system and S-FHSS as a more 'eco' system. However I suspect this is in part to not upset existing users of FASST systems. It would have been commerically suicide, but they could have dumped FASST and moved to S-FHSS without users noticing a difference.
Finally S-FHSS and FASST aren't compatible with one or the other. HOWEVER there are new Futaba transmitters out there that support both FASST and S-FHSS - notably the Futaba 18MZ and 14SG.
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Mar 21, 2013, 08:10 PM
Sweetrex is offline
Sweetrex's Avatar
Joined Sep 2009
Si.
Thank you, Si.
Old Mar 21, 2013, 08:30 PM
Four Stroker is offline
Find More Posts by Four Stroker
Joined Mar 2008
Thanks Simon. I like to have all of the chip specs and FCC reports.
http://www.sparc.uni-mb.si/Sistemida..._Sheet_1_2.pdf
Four Stroker is offline Find More Posts by Four Stroker
Old Mar 22, 2013, 12:47 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Frsky FASST compatibles are using same ML2724 as Futaba and sells for less than $30, so the difference is only in their marketing scheme.
renatoa is offline Find More Posts by renatoa
Old Mar 22, 2013, 06:37 AM
Sweetrex is offline
Sweetrex's Avatar
Joined Sep 2009
So I can use FrSky stuff interchangeably?
Old Mar 22, 2013, 07:45 AM
renatoa is offline
Joined Sep 2007
Not any Frsky stuff, they have two production lines, own ACCST system, and FASST compatibles.
Only the FASST compatibles can be used with a Futaba transmitter.
Old Mar 22, 2013, 09:20 AM
Joined Mar 2008
A clone must use the same chip so that it can clone the firmware.
Old Mar 22, 2013, 09:49 AM
renatoa is offline
Joined Sep 2007
Nope, is not a clone, is a compatible.
And is not necessary to use same chip.
A receiver has two parts: the RF part, a chip called transceiver, and the logic part, which is a microprocessor. Both are consumer chips, without anything secret or proprietary inside, and aren't so new technology as you could believe, mostly are developed between 2003 and 2006.
CC2500 transceiver is used in Hitec, Graupner, Frsky, and nobody call any of them a cloe of the other
What make a system is the FH protocol and decoding scheme, which are programs executed by the microprocessor. You make a clone when you obtain the program from whatever source, either illegal or immoral
When you use a logic analyzer to intercept the dialog between RF part and microprocessor, and create from the scratch another software who does the same thing, this is not a clone, is reverse engineering, and implies a lot more brain than the first. Also, some don't consider this fact as illegal, unless explicitly specified, which is a very fuzzy part if intellectual property.
Old Nov 09, 2013, 04:16 AM
modraude is offline
Find More Posts by modraude
milano italy
Joined Jun 2008
fhss vs dsmx
spectrum analysis
modraude is offline Find More Posts by modraude
Old Nov 09, 2013, 08:47 AM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
Modraude, would you care to comment on the differences as seen in the two spectrum analysis plots????
Or anybody else ???
Airman74 is offline Find More Posts by Airman74
Old Nov 09, 2013, 09:57 AM
modraude is offline
milano italy
Joined Jun 2008
Or anybody else ???
i think that the largest size of spikes and the more homogeneus time distribution on waterfall display of dsmx is the effect of dsss...
i would like that someone can confirm this.. i just measure...
Old Nov 09, 2013, 10:51 AM
DougV is offline
Find More Posts by DougV
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
Not comparing apples to apples there.
A fare comparison would be Speky DSMx with JR DMSS or Futaba’s FASSTest, these are Hybrid systems with wider bandwidth signal (much better)
In fact Futaba’s FASSTest and JR’s DMSS looks very similar on a spectrum analyser.
Doug
DougV is offline Find More Posts by DougV
Old Nov 09, 2013, 11:14 AM
modraude is offline
milano italy
Joined Jun 2008
Doug
so they are similar to the orange dsmx compatible showed on left image?
Old Nov 09, 2013, 02:54 PM
Pippin is offline
Find More Posts by Pippin
Joined Sep 2002
The difference between Futaba S-FHSS and FASST is range. This is due to Tx RF output power and Rx sensitivity.
The Futaba S-FHSS transmitters come with reduced RF output power. The receivers have less sensitivity. "S" might stand for "short" (range).
Ok, here are the numbers.
The popular T14SG in FASST:
P = 16.83dBm (w/o G = 1.5 dBi Antenna Gain)
The 18MZ in FASST:
P = 16.145dBm (w/o G = 1.5 dBi Antenna Gain)
T6J:
P = 15.83dBm (w/o Antenna Gain 2.0dBi)
T8J:
P = 13.242dBm (w/o Antenna Gain G = 2.0 dBi)
Cheers!
Pippin is offline Find More Posts by Pippin
Discussion Major Differences in FAAST & S-FHSS Sweetrex Electric Plane Talk 0 Mar 21, 2013 03:24 PM
Discussion futaba s-fhss 6ch in boat vernon7026 Racing Boats - Electric 6 Mar 09, 2013 02:38 PM
Sold Beautiful Futaba 8JH 8-Channel 2.4GHz S-FHSS Heli Radio System - $200 Warren Aircraft - General - Radio Equipment (FS/W) 2 Jan 10, 2013 01:11 PM
Discussion Reciever Question Futaba 2006 s-fhss 2.4 ghz asusrick Beginner Training Area (Fuel) 2 Jan 06, 2013 12:21 PM
dont see major difference in HB FP and HB Elite FP radcast2 Micro Helis 7 May 02, 2005 09:04 PM
