Old Mar 20, 2013, 01:50 PM
tormodnt is offline
Find More Posts by tormodnt
Norway, Hedmark, Brumunddal
Joined Aug 2012
Question
GLB 20mm Carbon Fiber Center Plate +16pcs Tube Fixtures for 700-1000mm Hexacopter/Oct
Has anyone used this center plate for a hexa build?
http://www.goodluckbuy.com/22mm-carb...ter-frame.html
I just don't understand how the tubes are mounted as a hexa?
I'm looking to upgrade my setup with a frame that have 22mm booms, and a larger centerplate to get a cleaner and stronger build.
I usa a DJI naza so hexa is max, and as described I should be abel to build this as a hexa..
Descriptions:
- This listing Carbon fiber ccenter board is suitable for 22mm Tube
- Material: 3K Carbon Fiber
- Brand:Ares
- Suitable for Octacopter 700-1000mm (depends on the installation of carbon fiber tube)
- Also can applied for Quadcopter and Hexacopter
- With 16 pcs Aluminium tube fixtures as following,you can DIY your own Quadcopter/Hexacopter/Octacopter just need 4-8pcs carbon fiber tube
tormodnt is offline Find More Posts by tormodnt
Old Mar 20, 2013, 03:30 PM
tormodnt is offline
Joined Aug 2012
No one know how this could be done?
Old Apr 21, 2013, 11:27 AM
cirilo is offline
Find More Posts by cirilo
Joined Apr 2013
I got the exact same question. Did you find an answer yet ?
cirilo is offline Find More Posts by cirilo
Old Apr 21, 2013, 11:31 AM
heli001 is offline
Find More Posts by heli001
Triple Tree Aerodrome
heli001's Avatar
Charlotte, NC
Joined Feb 2002
Take two Booms out opposite each other and you will have a Hexa configuration. The difference in spacing will not affect the flight performance. The controller will fly it. If it would not, a Tri copter would certainly, never get off the ground.
heli001 is offline Find More Posts by heli001
Old Apr 21, 2013, 11:32 AM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Technically you can build a hex out of it but your booms won't have even spacing, it'll be a octo with two arms missing. You can't build a hex with the arms all at 60deg using these plates.
Granted is online now Find More Posts by Granted
Old Mar 09, 2014, 12:18 AM
HexaFlexa is offline
Find More Posts by HexaFlexa
HexaFlexa's Avatar
Joined May 2012
I have that frame see my avatar.. There was a thread about a year ago on it I think it was called " Fake cinestar frame "and a few guys did build it as a Hexa with no problem.. I have since down sized a bit and its sitting waiting for a new home if anyone's interested..
HexaFlexa is offline Find More Posts by HexaFlexa
Discussion http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=24759&aff=442138 tommy2toes Multirotor Talk 1 Jan 15, 2013 03:58 AM
Sold Carbon Fiber Bottom Plate for T-rex 450 PRO Helicopter TGKconnectors Aircraft - Electric - Helis (FS/W) 0 Jan 09, 2013 09:48 PM
Sold New 22mm(.87") X 24" Carbon Fiber Tube Rainbow28 Aircraft - General - Miscellaneous (FS/W) 0 Nov 27, 2011 04:06 AM
I need carbon fiber wing tube 22mm (650mm long) rysium Composites Fabrication 5 May 07, 2005 07:21 PM
