Old Jan 04, 2004, 08:40 PM
YEAP CHIN POH is offline
Find More Posts by YEAP CHIN POH
Penang, Malaysia
Joined Jun 2002
S400 DH82A Tiger Moth
Penang, Malaysia
It took a while to do this plane. It is based upon a Peter Rake plan given free with Flying Scale Models megazine in 2003.
I modified it a bit to make it more scale and to make the wings detached from the fuselage. On Penang island land is scarce and we do not have that much space where we live.
As can be seen I have completed both the fuse and the lower wing hence I felt it time to get the thread going.
I intend to use a Graupner S400 7.2 V mated with a Pro Maxx 3:1 gearbox.
Can anyone tell me which wooden prop to use?
YEAP CHIN POH is offline Find More Posts by YEAP CHIN POH
Old Jan 04, 2004, 08:44 PM
Penang, Malaysia
Joined Jun 2002
This is a earlier photo
Old Jan 04, 2004, 08:45 PM
Penang, Malaysia
Joined Jun 2002
Another 1. Sorry about the quality. I am new to this sort of thing.
Old Jan 04, 2004, 08:47 PM
Penang, Malaysia
Joined Jun 2002
Sorry about that
Old Jan 04, 2004, 08:50 PM
Penang, Malaysia
Joined Jun 2002
The cockpit detaches to allow swapping batteries (a tip I picked up from someone in this site). Can't imagine having to remove wing, cabanes and LG to swap batteries.
Old Jan 04, 2004, 09:53 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Looks nice. To find a prop, you have to know what direct drive prop would work (probably a 6/4), and multiply the square root of the gear ratio times the old prop diameter. This will give you the new, geared prop diameter that will pull the same amps.
Looks good so far,Yeap. Keep us posted.
Mark
mrittinger is offline Find More Posts by mrittinger
Old Jan 04, 2004, 11:17 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
That looks really nice!
I'll guess at a prop in the 11x6 range, although as long as the ampdraw suits your motor and battery, it shouldn't be overly critical.
tim
tim hooper is offline Find More Posts by tim hooper
Old Jan 04, 2004, 11:42 PM
Penang, Malaysia
Joined Jun 2002
I am really pleased to have gotten 2 replies so far!
I am looking for a wooden prop. 11 X6 does seem large but I only expect it to move around the sky and admire its lines. ANy particular brand. I will have to buy by mail so I wnat to get it right.
Old Jan 05, 2004, 04:08 AM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Yeap,
Since you're using the 7.2 volt motor, I'd recommend a Master Airscrews Electric 10x6 or 11x7 wooden prop. I've had good results using these props on various geared 400 models.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Jan 05, 2004, 08:46 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
On 6v 400 and 3:1 10x7 is sort of ballpark. On 8 cells.
You can try anything from 9x7 up to 12x10 on a 7.2v motor and 8 cells. The smaller props will be more speedy, since RPM will be a little higher. But the bigger props will climb out better.
The 7.2v motor is not really ideal on a 3:1 box unless you can stretch to 3s lipo. Then its nice on 8x6 8x8 or 9x6 or 9x7 sort of props.
Old Jan 05, 2004, 02:57 PM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Hi Vintage1,
Haven't heard from you in a while. Good to see you back.
Jim
JIMA is offline Find More Posts by JIMA
Old Jan 05, 2004, 03:33 PM
hokonghing is offline
Find More Posts by hokonghing
hokonghing's Avatar
Houston
Joined Jan 2002
same plan, different approach, I used depron and strengthened with Balsa wood
hokonghing is offline Find More Posts by hokonghing
Old Jan 05, 2004, 03:36 PM
hokonghing's Avatar
Houston
Joined Jan 2002
I use a Nippy 280 with 10"x4.7 APC SF Prop with8x1050 Kan Cells
Old Jan 05, 2004, 03:37 PM
hokonghing's Avatar
Houston
Joined Jan 2002
last one
Old Jan 05, 2004, 08:06 PM
Penang, Malaysia
Joined Jun 2002
Hi Everyone
I took a break last night.
OK I think I will go along with PR's recommendation of MA 10X6 to 11X7 or anything within that size range.
I know I am thinking ahead of time but does anyone have a program to cut or print the insignia for "ACDC"? I hope to just give it to our local sticker store and get my decal cut or printed.
Still gotta figure out how to do the centre cabanes. I thought of using 2 mm carbon instead of the spruce quoted. I do not have spruce that size and if I desire a scale look it would even be smaller section. My wire bending skill is lousy so I will try carbon.
I am grateful for all the replies and words of encouragement.
"Ho" that is a nice looking Tiger there. What did you do about the carbanes? Did you follow the plan?
Build Log Pat Trittle's 44" DH82a Tiger Moth Build. jamesgood72 Scale Kit/Scratch Built 240 Oct 08, 2007 02:16 AM
Peter Rake DH82A Tiger Moth Mark Winstanley Product Announcements 0 May 12, 2003 12:13 PM
Litestick, Tiger Moth, Wingo NewFlyer_02 Beginner Training Area (Aircraft-Electric) 2 Jul 31, 2001 06:52 AM
Litestick, Tiger Moth, Wingo NewFlyer_02 Electric Plane Talk 2 Jul 28, 2001 11:09 PM
GWS Tiger Moth RMason Scale Kit/Scratch Built 0 Jun 26, 2001 05:21 PM
