This thread is privately moderated by KatanaGuy, who may elect to delete unwanted replies.
Old Mar 19, 2013, 08:51 PM
KatanaGuy is offline
Find More Posts by KatanaGuy
Design, Build, and Fly
KatanaGuy's Avatar
Pleasant Grove, Utah
Joined Nov 2001
Download
Orange Hawk Source Code
The "Orange Hawk" used my modification of the MultiWii 2.1 opensource flight controller software and hardware architecture. I've polished the code and am attaching it here. The following pages will link to this blog post:
http://diydrones.com/profiles/blogs/...-wing-vtol-uav
http://www.rcgroups.com/forums/showt...2#post24445982
http://fpvlab.com/forums/showthread....ying-Wing-VTOL
Introduction to the Orange Hawk Project (0 min 0 sec)
The attached ZIP file has the following text included with it:
Version 1.0 Released 19 March 2013
This Codebase is for the Orange Hawk VTOL Hybrid, released March 2013.
It compiles in Arduino 1.0 and Processing 1.5.1, using MultiWii 2.1 as the base code.
The Processing library controlP5-0.7.5 is used in the MultiWiiConf utility.
History:
In August 2011, the author, Steve, decided to pursue a life-long goal of making a VTOL dream machine.
The goal was to create an aircraft capable of hovering and VTOL operations, but with the efficiency of
a fixed-wing aircraft. Inspiration for this project came from news clips such as the IAI Panther and
Mini-Panther, presented on YouTube such as this example here:
Panther UAV (2 min 10 sec)
Further, the author has been actively engaged in UAV design and experimentation for 9 years, starting with
electric R/C aircraft at age 13, and had concurrently attempted other ideas for VTOL aircraft.
Also, the efforts of "leadfeather", "cass3825", "foam and tape", "EddieWeeks" and "RCvertt" on the
RcGroups.com VTOL forum were inspirational. Although this group developed code based on MultiWii 1.7/1.8
for their efforts, I decided to forge ahead on my own modification of the more recent 2.1 version and try
to keep things simple. Their code is available in various threads, and a primary version can be found at
http://www.rcgroups.com/forums/showthread.php?t=1523814, or at
http://www.rcgroups.com/forums/member.php?u=56274 , cass3825's blog. I've modified the MultiWiiConf
utility for this code, and have other modifications such as a general purpose mechanism controler started.
The airframe I've constructed, called the "Orange Hawk" design, is a Tricopter Delta Wing with a Bicopter
front cassette assembly, which means that the front motors are actuated independently. Details on
the airframe itself, including the design decision, theory, motor selections, airfoil, and other metrics
are to be detailed in a AIAA Student Conference Paper to be presented at the AIAA Region VI Student
Conference in March 2013, and will be fully detailed after that date.
Information on the Orange Hawk VTOL design can be found at these threads as of 19 March 2013:
Thanks for you interest, and enjoy flying!
-Steve
KatanaGuy is offline Find More Posts by KatanaGuy
Old Mar 19, 2013, 09:41 PM
jjmelo is offline
Find More Posts by jjmelo
jjmelo's Avatar
United States, CA, Burbank
Joined Aug 2012
subscribed! awesome work!
jjmelo is offline Find More Posts by jjmelo
Latest blog entry: Hellbender 122
Old Apr 22, 2013, 02:51 PM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
Wow, this looks so awesome! Do all three motors pivot for fixed wing flight or just the back motor? Either way, I'd love to see this in person. Are you going to sWARm next week?
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Apr 22, 2013, 04:14 PM
KatanaGuy's Avatar
Joined Nov 2001
You bet! I'm going to be there, might even put the O-Hawk up in the fray (within reason).
Old Apr 22, 2013, 04:48 PM
Joined Oct 2006
Thanks, Steve, I wasn't planning on going to sWARm, but you've just given me a very good reason to try my best to make it down there. Good luck if you launch it into the fray.
Old Dec 18, 2013, 09:03 AM
walkingtall is offline
Find More Posts by walkingtall
Joined Dec 2013
i have few doubts
1) why is the tail rotor-prop different than front ones?
2) can I use the yaw mechanism of tricopter design for yaw control of wing in forward flight(after transition)?
3) can i make the same model using KK2.0 board?
walkingtall is offline Find More Posts by walkingtall
Old Dec 18, 2013, 12:39 PM
KatanaGuy's Avatar
Joined Nov 2001
1) The reason that the rear prop is larger is because of the way I've distributed the weight. I intentionally placed about 50% of the vehicle weight on the rear motor, and the remaining 50% is distributed between the front two. As the front two motors are higher Kv, and therefore more efficient in forward flight at high speed rather than static thrust in hover, they have to be loaded much lighter, otherwise, the disc loading is so high that they enter the vortex ring state much like the V-22. The rear motor is optimized for hover only, and is inactive during forward flight.
2) The predecessor to the Orange Hawk was a tail pusher design I named the White Hawk. It used a 2-axis gimbal mechanism on the rear motor to both control yaw as a tricopter, and tilt for forward flight. I had the option to control yaw during forward flight when designing that mechanism, but decided otherwise, and so when it was tilted forward, the gimbal was in "gimbal lock", such that the motor was constrained to pointing straight back, no yaw coupling. As to why you would want to control yaw on a flying wing, it is not necessary if the wing has directional stability. Unless you want to initiate a side slip or have sufficient fuselage side area to generate sideways lift.
3) If the KK2.0 is still opensource (which I believe it is. I got my start with multicopter controllers with the KK1.0), then it should be modifiable.
-Steve
Old Dec 21, 2013, 12:29 AM
Joined Dec 2013
Thank you for your reply Steve.
Actually i already ordered 3 NTM Prop Drive 28-30S 800KV / 300W Brushless Motor (short shaft version). Will there be much difficulties in using all 3 same motor-prop?
Old Dec 21, 2013, 12:43 AM
Joined Dec 2013
I asked about the yaw mechanism because i was thinking about a design that will eliminate the alevons and yaw and roll of wing will be controlled by the tail rotor in forward flight( keeping tail rotor in vertical direction only. Not in pusher configuration)
Old Dec 21, 2013, 01:14 AM
KatanaGuy's Avatar
Joined Nov 2001
Ok, I see now.
For the yaw mechanism, that should work: It will require the motor to be kept rotating to some degree, I'd like to see how it turns out.
When I was getting the Orange Hawk's PIDs initially tuned, I placed it on a test stand as shown in this video:
Sneek Peak of the Orange Hawk (1 min 0 sec)
. I brought the vehicle to hover, with the rod participating a little as possible in the physics taking place, merely keeping the aircraft pointed straight basically. All three motors are KDA 20-22L's with APC 10x47 Slow Flight props. I flew the vehicle this configuration in all the first hovering and 50/50 flight tests, and only attempted forward flight once, and only once: In that first forward flight test, I knew the pitch speed would be low, but it was so low that even at full throttle, the aircraft could barely stay airborne and controllable, as the propeller-motor combination easily saturated at max RPM with only ~15 m/s passing through the disc(s). Hence, you can probably use 3 of the same motor, provided that the airframe can produce lift and be controllable at a low velocity. Or, with higher Kv motors, it would fly forward fine, but beware of high disc loading messing up the hover stability. (This is somewhat desired in the aerobatic quadrotor world, providing a smaller prop to the motor, allowing it to spool much faster, but aerobatic quads are pretty light anyway.... I don't know).
Hope this helps,
-Steve
Old Mar 14, 2014, 11:22 AM
rukie is offline
Find More Posts by rukie
rukie's Avatar
Philippines, Central Luzon, Marilao
Joined Jun 2008
HI there, very nice project. I am currently looking at making one myself. But I do want it in the ardupilot or pixhawk. I am not a hard coder though.
Anyway where are you in this project? One question, do you maintain the other features of the 2.1 in this code modification? GPS hold? RTH?
rukie is offline Find More Posts by rukie
Old Mar 18, 2014, 02:14 AM
KatanaGuy's Avatar
Joined Nov 2001
Hi,
Sorry for the delay; I would like to port this to the PixHawk, I've got an APM2.5 that I still need to unbox and get working. It's been hard enough to just maintain the 2.1 MW code, and now they are on 2.5 now! So, whoosh! Engineering it tough! I didn't get the GPS / RTH functions ported, although I'll be they will still work with the vehicle in Hover mode. In Forward flight, I'm still not at that point yet.
-Steve
Old May 09, 2014, 05:46 PM
adil444 is offline
Find More Posts by adil444
Joined Dec 2013
Approach towards APM
How much success have you gained while working on the APM 2.5 or 2.6? at what point you are with your APM?
adil444 is offline Find More Posts by adil444
Old May 09, 2014, 05:58 PM
adil444 is offline
Joined Dec 2013
Hey stephen,
Have you considered the option of using two different APM for the two flight modes (hover and fixed wing)? is it possible to use two different APM on a single platform?
Discussion Reveiver light changing to orange with Country Code 3 Franz2002_01 Xtreme Power Systems 4 Sep 02, 2008 03:24 PM
Discussion Project open source code simulators treehog Simulators 29 Oct 30, 2006 11:48 AM
PHXs Firmware source code for us to fix? Super_Hornet Castle Creations 11 Nov 13, 2005 05:30 PM
Source code for actuators vaughan@world.s Scratchbuilt Indoor and Micro Models 2 Jun 20, 2003 04:14 PM
Does anybody know another source for coded video transmitter/receiver? glockengockel Aerial Photography 28 Mar 17, 2003 07:05 PM
