Old Mar 19, 2013, 01:22 PM
H2Ohaze is offline
Find More Posts by H2Ohaze
United States, CO, Loveland
Joined Apr 2009
SR.N5 kit or Sirius 600
I'd like to just build from a kit; I'm new to hovercraft but not to RC. I am a bit weak on brushless motors though.
With a separate lift motor, I guess I can go in reverse?
Anyway, my big question is which of these two kits to go with, and which BL motors and esc's to use. Thrust esc F/R proportional and lift esc forward, probably proportional(?). I can use either Lipo or NiMh sub-C size.
The advantages of this one:
http://www.hovercraftmodels.com/SRN5...Hovercraft.htm
are I can buy it in the USA, and it's 16 inches wide. Cons are they are not very responsive to an e-mail question, and they seem to in the past dropped models from their line. Maybe not a good or a bad thing??? They also only discuss brushed motors as coming with the kit, and so far, no info from them as to what BL setup to use.
But here are the motors they use in kit, brushed 400 or 480:
http://hovercraftmodels.com/store/co.../en-us/d9.html
Of course they may be perfectly fine. It's also more of a scale than a racer, I don't know if there is any compromise there.
The Sirius 600:
http://modelhovercraft.co.uk/page13.html
Is 12 inches wide, and I'd have to ship from UK. But it looks like they are adding models to their line (the Sirius is the newest). I have heard they are responsive to questions, and they list BL motors on their site. I have an e-mail in to them now about the lift optional upgrade and what BL motors and esc(s) recommended. Waiting for reply.
H2Ohaze is offline Find More Posts by H2Ohaze
Old Mar 20, 2013, 01:45 AM
jpcwebb is offline
Find More Posts by jpcwebb
MHA webmaster
United Kingdom, England, Reading
Joined Mar 2011
I can vouch for Palaform (the UK company) as I know the owner personally and have bought two kits from him in the past plus know people who have had other models from him and all with good reports. He is a one man band though, so whilst he is very responsive and enthusiastic, he does have a day job, so you may have to wait a few days for a reply. Can't comment on the US models I'm afraid.
jpcwebb is offline Find More Posts by jpcwebb
Old Mar 20, 2013, 05:24 AM
windnsea is offline
Find More Posts by windnsea
Australia, VIC, Bass
Joined Jan 2013
I can recommend brushless motors after years of experience with both.
- hovercraft create lots of dust and spray which causes brushed motors to lose power and wear out, but if you are only going to operate indoors or over clean dry surfaces they're ok
for any given power and size a lighter model performs better so this should guide your choice unless appearance is your main consideration
windnsea is offline Find More Posts by windnsea
Old Mar 22, 2013, 10:30 AM
H2Ohaze is offline
Joined Apr 2009
Good info, thanks. Heard back from Jag on the Sirius 600. Shipping is reasonable, although it goes up in April.
How would I go about selecting BL motors for lift and also one for thrust? Also an esc F/R for thrust and a proportional forward only for lift? What's holding me back here is I'm absolutely clueless as to what to order. If I had some part numbers....
I'm thinking $150 budget total for the two BL motors and escs if that is possible. I think the Sirius fits 400 size brushed motors. I might spend more if absolutely needed. Or maybe the lift esc can be eliminated or?
I have some 3S 2200 Lipos, and some 7 cell sub-C NiMh car packs, some 3000 mah and some 4600 mah.
Old Mar 22, 2013, 12:26 PM
jpcwebb is offline
MHA webmaster
Joined Mar 2011
Jag can recommend some motors for his models, or even supply them though it would be cheaper to buy them locally. I tend to go for high kV rated for the thrust in combination with a reasonably low pitch prop. For the lift fan you don't need an especially fast or powerful motor
Old Mar 25, 2013, 08:12 PM
H2Ohaze is offline
Joined Apr 2009
Thanks for the help. I ordered the Sirius 600 from Jag. He set me up with:
Brushless motor - 1450 rpm/V min. (400 size) for thrust
1400Kv Lift motor for lift
Since I have some 3S 2200 mah 30C Lipos around, they will be connected to these. Also Jag got me a 30 amp F/R esc for thrust and a 20 amp F esc for lift.
Discussion Metal Base Plate T-Rex 600 or HobbyKing HT-600 GT ranger206 Hot Online Deals 0 Feb 08, 2013 09:26 PM
Found 600 or 700 size heli for Multicopter PNP mcashatt Aircraft - Electric - Helis (FS/W) 2 Jan 06, 2013 10:11 PM
Discussion Sirius-ish or Sirius-clone? erikdahlchriste Hand Launch 18 Aug 07, 2009 01:15 PM
Wanted Sirius Charge Pro or Sirius Charge Pro Plus Hoot Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 23, 2006 07:03 PM
Wanted Sirius Pro PLUS or Sirius Pro charger Hoot Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 08, 2006 05:40 PM
