Old Mar 17, 2013, 10:52 PM
joekitch is offline
Find More Posts by joekitch
United States, MA, Shrewsbury
Joined Mar 2013
Simple Large Slow UAV plan
i'm certain something like this exists somewhere but i'm having trouble finding it.
in any case, i have a long term project of building a very long range, efficient UAV.
i'm starting out with building the model itself and flying it traditionally before transitioning into a UAV.
for high efficiency i'm going to need something pretty large, the large size will also make it easier for the uav system to keep it level and make smooth turns and landings.
Slowness (at least, the option of slow flying) would be great for starting off manual piloting. it'll also allow the APM more breathing room for maneuvers.
Simple is because i doubt anything on the market that does what i need will be in any reasonable price range, so i'll probably need to build it from scratch. Scaling up something smaller is totally fine as well.
But who knows, there might be some $60 kit flying wing that has a 6' wingspan somewhere on hobbyking.
joekitch is offline Find More Posts by joekitch
Old Mar 18, 2013, 05:40 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Welcome aboard RC Groups!
If you're stuck on the concept of a flying wing planform for your airplane, I'd consider a delta like the Delta Vortex from BTE.
http://www.btemodels.com/vortex.html
The complete kit is listed as out of stock at the moment, but the major parts and plans are available separately at the Replacement Parts link on same page.
Building using the major parts would also help meet one of stated goals of economy of construction.
If I needed an efficient and stable model UAV airplane, capable of slow flight, a flying wing planform would be my last choice. I'd choose a conventional configured powered sailplane design and never look back.
DT56 is offline Find More Posts by DT56
Old Mar 18, 2013, 11:57 AM
joekitch is offline
Joined Mar 2013
hmm, interesting...i had not even considered a sailplane
to be honest i was looking at a big wing mostly for those first few months of manual flying, nothing says "imposing" like a giant mothership flying around, like this one
MotherShip giant flying wing (0 min 52 sec)
a smaller wing would work just as well for fun i suppose. that tek sumo off hobbyking looked pretty interesting.
The only downside to sailplanes i can see if that they're expensive kits, and scratch building looks very difficult due to the complexity of the wings
Old Mar 18, 2013, 07:07 PM
Zedtwitz is offline
Find More Posts by Zedtwitz
United States, NY
Joined Jan 2012
Have you ever flown a wing before? If not, just get something small like a Popwing and learn on that one. You can get around 60" wings for about $70, but they won't last very long at all.
Zedtwitz is offline Find More Posts by Zedtwitz
Old Mar 18, 2013, 08:11 PM
joekitch is offline
Joined Mar 2013
i have...not actually flown a wing before, no.
i looked into those pop wings. oddly enough they come out almost exactly the same price as the hobby king bonsai's and tek sumo's after shipping. HK is cheap but damn that shipping yeesh
and yeah, i expected 60" wing kits for less than $150 would be super cheap and break immediately, which is why i asked for (maybe) plans instead. EPP would probably work best
Old Mar 18, 2013, 08:21 PM
Zedtwitz is offline
United States, NY
Joined Jan 2012
Here are a few helpful links.
flyingfoam.com
zagi.com
ritewingrc.com
trickrc.com
I made a big 84" EPS wing last year, and turned out to be crap because EPS is terrible, but all of the cores together were under $60 from flyingfoam. EPP is about $8 more per core, and is way better. The thread is somewhere...
Old Mar 18, 2013, 09:08 PM
DT56 is offline
Joined Aug 2005
flyingfoam.com
zagi.com
ritewingrc.com
trickrc.com
What covering did you use for your EPS cores?
Just curious because EPS covered with wood or fiberglass skins has been highly successful for over fifty years. It does not create a flexible type wing like one composed of EPP cores with a flexible skin though.
I agree with the quality of cores from Flying Foam, but have to note my experience was with the company before it was sold to the new owner.
Old Mar 19, 2013, 12:04 AM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
If you're looking for efficiency in a wing platform, I suspect you'd want to go with a planform similar to a ZeZe. The high aspect ratio allows for very efficient flying of the type you'd get from a conventional sailplane, and the rear motor gives you an unobstructed forward view for cameras and things. The only problem is that you'd have to build the airframe yourself since nobody really sells anything like this. Maybe that's not a big deal, but it does look like you're more interested in an ARF-type plane.
Piece is offline Find More Posts by Piece
Old Mar 19, 2013, 01:26 AM
DT56 is offline
Joined Aug 2005
As mentioned by C4H10, a high aspect ratio planform is usually more efficient. There are ways to have the same efficiency without the structural and aerodynamic penalties associated with aft swept chevron planforms. A high aspect ratio plank design like Plankenstein might be worth considering. With a high aspect plank of forward swept trailing edge design, conventional control arrangement of separate elevators and ailerons is possible, allowing advanced control mixing such as speed brake.
Old Mar 20, 2013, 05:16 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Google search brought up this-
http://www.rcgroups.com/forums/showthread.php?t=871832
Plankenstein gets a mention
Stuart A is offline Find More Posts by Stuart A
Old Mar 20, 2013, 05:28 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
http://www.rcgroups.com/forums/showthread.php?t=1562220
Something similar,modify the pod?
Old Mar 20, 2013, 08:23 PM
flyingfrog50 is offline
Find More Posts by flyingfrog50
Joined Oct 2009
try a mother ship
try the mother ship from flyingfoam
https://www.flyingfoam.com/content/mother-ship-0
or for a stable platform nothing can beat a telemaster from hobbylobby
http://www.hobby-lobby.com/telemasters_216_ctg.htm
good flying
later
nich
flyingfrog50 is offline Find More Posts by flyingfrog50
Old Mar 21, 2013, 02:27 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
http://www.rcgroups.com/forums/showthread.php?t=1847954 #14 if shipping doesn't kill it.
Old Mar 22, 2013, 03:02 PM
Joined Oct 2009
building skills
if your needing help building try the queen be
http://headrc.com/air/planes/foam/wing/WR-W996
the queen is slow and gentle platform
later nich
Old Mar 23, 2013, 05:05 AM
Bootstrapper is offline
Find More Posts by Bootstrapper
Evil genius
Bootstrapper's Avatar
Australia, NSW, Macquarie Park
Joined Oct 2007
hmm, interesting...i had not even considered a sailplane....The only downside to sailplanes i can see if that they're expensive kits, and scratch building looks very difficult due to the complexity of the wings
Try this. It's a copy of a 2m Goldberg Gentle Lady. Don't worry about the lack of ailerons; These sailplanes manoeuvre quite well on the rudder and elevator alone - you connect the rudder servo to the aileron channel on your receiver. The Gentle lady is almost 'free-flight-stable' meaning you can concentrate on navigating the model as distinct from flying it.
Bootstrapper is offline Find More Posts by Bootstrapper
Discussion help finding simple pusher/EDF jet plans derpron Foamies (Scratchbuilt) 1 Mar 05, 2013 07:03 AM
Discussion looking for plans for a very simple micro hlg johnwohl Hand Launch 5 Feb 26, 2013 06:22 PM
Discussion large wing span, light, slow flying, indoor wing plans? Steve 0 Nurflügel 26 Feb 26, 2013 01:42 PM
Discussion Reaper UAV Plan Origin ? Eclat UAV - Unmanned Aerial Vehicles 0 Jan 27, 2013 04:46 PM
