Old Mar 16, 2013, 09:45 PM
ImperaTodd is offline
Find More Posts by ImperaTodd
Joined Mar 2013
Bristol Bay Modification Help
Hi I am a long time lurker first time poster. I recently bought an Aquacraft Bristol Bay boat and while I love the hull I think the deck needs work. I want to remove the glued down parts, like the winch and the entry way on the fore-deck. It is well glued down and was hoping for advice on removing them without pulling up the whole deck. Thanks in advance.
ImperaTodd is offline Find More Posts by ImperaTodd
Old Mar 16, 2013, 09:53 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
United States, MI, West Bloomfield Township
Joined Dec 2004
Give up all hope the deck is a disaster anyway. Putting on some nice planking is easy:
http://m.rcgroups.com/forums/showthr...=bristol+rescu
patmat2350 is offline Find More Posts by patmat2350
Old Mar 16, 2013, 11:47 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
I have done it, BUT, it is not for a beginner. I then had to sand smooth the wood, and redraw the planking lines with a matching art pencil. I was also going to weather the boat when finished! CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Mar 17, 2013, 11:39 AM
redlined_b16a is offline
Find More Posts by redlined_b16a
Joined Jun 2008
I added balsa planking over my deck,never finished it though
I cut the planks in 6" strips
Ill look for pics
Cheap balsa planks laid ontop the original deck
redlined_b16a is offline Find More Posts by redlined_b16a
Old Mar 17, 2013, 02:26 PM
Joined Mar 2013
The balsa planking looks great. What did you use to clear the ornaments off the deck?
Old Mar 17, 2013, 09:59 PM
Joined Jun 2008
Not sure what you mean
I removed everything off of the deck to plank it
As far as glued down parts I just pulled them carefully by hand until the glue gave loose
Grip it and rip it
Maybe an xacto knife would make it clean cuts
Old Mar 17, 2013, 11:01 PM
Joined Mar 2013
That helps a ton thanks!
Old Mar 17, 2013, 11:21 PM
Joined Jun 2008
When I ripped my stuff off it did damage some if the plywood underneath but if your going to plank it,it won't matter much
I love Pats approach more but I was happy with $15 of balsa planks
I choose to stagger my boards too
Old Mar 17, 2013, 11:22 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
A conversion in our club.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Mar 18, 2013, 09:45 AM
Joined Jun 2008
Here's more pics and info on what I done
http://www.scale4x4rc.org/forums/showthread.php?t=53550
Old Mar 18, 2013, 06:37 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Yep, like that balsa planked deck a lot.
I pulled the stuff off my deck, and it did not damage it. It did however, lighten the area when I scrubbed it to remove the dried glue.
Kmot is offline Find More Posts by Kmot
Old Mar 18, 2013, 11:06 PM
Joined Mar 2013
Great work, they look great!
Old May 11, 2013, 11:01 PM
Joined Mar 2013
So I finally started working on my bristol bay and found that is is based on the Gaupner fischkutter and they are based on a WW2 German boat. I was wondering if anyone had or knew where to get plans for a kfk kriegsfischkutter?
Old May 12, 2013, 07:06 PM
rctugger is offline
Find More Posts by rctugger
United States, FL, Sebastian
Joined Feb 2010
Bristol Bay Pixs
I just finished remaking my Bristol Bay this week. Sea Trials today went fine. I would send you some pixs but cant figure out how to get images attached to these replys. What I did was;
-strip the entire deck
-through out the radio, servo, and speed control
-removed shaft/tube and installed 3/16th shaft
-moved pilot hs aft 3 inches
-replanked the entire deck
-dull finished hull
-made a crane out of fwd mast
-installed 2.4 radio, Viper esc, Hicks engine sound module, and BB MG servo
-installed lower rpm 550 motor
-installed 1 1/2 inch brass Rivabo prop
-bought a ton of doll hs size deck items-boxes-pallets-bananas-sacks of grain-barrels of oil-water cooler-deck hand
rctugger is offline Find More Posts by rctugger
Old May 13, 2013, 12:57 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Very nice.
MILLERTIME is offline Find More Posts by MILLERTIME
Bristol Bay Rescue patmat2350 Scale Boats 100 Jul 06, 2015 02:20 PM
Discussion Need some help finding a U-joint that will fit my Bristol Bay. Crazyrcer Scale Boats 6 Jun 05, 2006 04:22 PM
Taking the "Glitching" out of Your Bristol Bay P. Tritle Scale Boats 4 Sep 19, 2005 05:25 PM
hobbico bristol bay gvznwa Scale Boats 1 Jul 11, 2005 04:14 PM
Salmon Cannery, Bristol Bay Alaska Borderbuster Aerial Photography 1 May 17, 2005 11:52 AM
