Old Mar 16, 2013, 10:40 AM
Test is offline
Find More Posts by Test
Joined Jan 2009
Problem 1430 TP Charger
Hi,
I have one problem with one of my TP 1430 charger (actual software 2.6IR):
I charged a 10 s 4500 battery pack with 1 c (4,5 A). After about 50 minutes the charger is about 0,60 A charging; cells about 4,19 V. But the charger does not stopp !! Charger charging further and further with about 0,6 Amps.
Now I (!!)I stopped charging, pressing ENTER and starting again to charge. 3-4 seconds later the display showed "complete charge" and the cells are showing suddenly 4,24/4,26 volts !
Any idea why the 1430 does not stopp charging the first time ? My dealer alreday changed this "problem 1430" to a new one, but same problem !
My second charger 1430 works ok; I sent serveral mails to TP, but no answer !
Any idea ?
regards
Test
Test is offline Find More Posts by Test
Old Mar 17, 2013, 08:09 AM
Test is offline
Joined Jan 2009
Hallo,
some more info:
I downgrad from 2,6 software to 2,4 software and no problem anymore....
Strange that one 1430 works wirth 2,6 and the other 1430 not; also really strange that TP support does not answer
Regards
Test
Old Mar 17, 2013, 09:54 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Buy FMA, Great chargers and great service. They talk to their customers.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Mar 17, 2013, 10:05 PM
thumper_008 is online now
Find More Posts by thumper_008
Joined Dec 2004
I also have a problem and would be interested to see your individual cell voltages.
I was running software 2,4 and found that the charger took 1hr 50 min on charge and still hadnt balanced a 10S/ 4900 mah battery.
What i discovered was that the last cell had a very low voltage and the second last cell had a very high voltage, The result was such that the balancer couldnt bring the charge to a conclusion.
I went back to my older TP1010C charger and ran thru a number of cycles till the cells came back within tolerance.
I then loaded software 2.6IR but experienced the same problem.
I'm thinking it is a balancing issue within the charger, can you test and report your cell volts to see?
Iam going back to my retailer/distributor.
thumper_008 is online now Find More Posts by thumper_008
Old Mar 18, 2013, 03:10 AM
Test is offline
Joined Jan 2009
Hi,
thank´s for info. As I told: one 1430 with 2.6 software works fine.
The second not with 2.6.
After about 40-50 this charger is charging/balancing with 0,5 A and does not stopp.
All 10 s cells are in the situation shown in display with 4,18/4,19 V. Not more difference. Stopping now chagring, then start charging again directly after 2-3 seconds in display "charging complete" and all cells are showing 4,26/4,27 V.
I can really not understand, that Thunderpower support does not answer; I sent about 5 mails; not any reaction.
I had TP 1010 charger (great), I have TP 820 (great); I have 2 TP power supply (great) and 2 x TP1430.
So I love TP products, but the support for me as actually not good....
Look here from german heli forum:
http://www.rc-heli.de/board/showthread.php?t=216275
the same; with 2.4 working, with 2.6 charging even up to 4,28 V ! AND NO ANSWER FROM TP !
Regards
Test
Old Mar 19, 2013, 02:58 AM
Test is offline
Joined Jan 2009
Hallo,
some info:
meanwhile TP suport answered; they suggested to send charger back if it works with 2.4, but not with 2.6 software. But why one charger is working with 2.6 and the other not ; noboday can say.
Even the third new charger from my dealer does not work with 2.6.
Regards
Test
Old Apr 07, 2013, 04:01 PM
Test is offline
Joined Jan 2009
Hallo,
some new infos:
Meanwhile the 1340, which first was ok, also does not work anymore as it should. So both 1430 are changed to new ones from my dealer; the 2 two 1430 worked about 3 weeks; but than both chargers showed the same problems again.
Overcharging some cells up to 4,28 V; also the charger does not stopp ! The balancing dots in the display are gone etc. (software 2,6). Sometimes nothingin the display.
So next week I will get now charger 5 and 6 ... the last try !
I think - meanwhile I heard from other users - the quality is not more as good as in former times.
Regards
Test
Old Apr 07, 2013, 09:15 PM
USA, GA, Marietta
Joined Aug 2005
Originally Posted by Test View Post
Hallo,
some new infos:
Regards
Test
Maybe you should consider going over to FMA (Revolectrix) chargers. Quality is first class and service, which is rarely needed, is also first class.
Glen
Old Apr 08, 2013, 08:52 AM
Test is offline
Joined Jan 2009
Hi,
got this morning the 2 new TP 1430...; but again
Charger 1 is only charging and charging; not stopping althought cells are 4,24 V.
Charger 2 the same; for more than 2 hours the charger is charging with 0,6 A and cells about 4,19 V. Than suddenly in display cells are going up to 4,28 V !!! I stopped charging; cells checked with lipo checker = from 4,28 V the cells 10S pack.
This was TP 1430 charger Nr. 5 and 6 ! All 6 TP 143o same problems !
Thanks to my dealer to change so many times
But TP quality ???
1010 TP was great, but 1430 ? No go. I do not know what TP is doing, perhaps they changed the producer ?
I have all documented with pictures for my dealer.
TP: please change your quality or the new producer
Regards
Test
Old Apr 09, 2013, 09:21 AM
Test is offline
Joined Jan 2009
Hi,
TP answers that they have calibration iusses and they are working to solve the problems with 1430 chargers.
mmhh... I am really asking if they tested the 1430 before selling.
With TP 820 after latest update, a lot of 820 chargers had big problems; also overcharging cells up to 4,26 V and not stopping charging. Some users went back to old 3.9 version and all we again ok then.
Wish to get back same perfect quality like with old TP 1010 ...
Regards
Test
For Sale Thunder Power TP-425 Charger / TP-205 Balancer cap_sized Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2013 08:06 PM
For Sale Thunder Power 1430 charger NIB bruff Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 28, 2013 01:30 AM
Discussion Tp 1430 fu-corsair Batteries and Chargers 3 Dec 26, 2012 04:51 PM
Apache 1215 Lipo Charger and TP 2c1320: charger problem? mike93 Batteries and Chargers 0 Oct 11, 2005 11:54 PM
Strange Problem with TP, Apache Charger and CC ESC KenP Batteries and Chargers 6 Jun 04, 2004 06:43 PM
