Old Mar 14, 2013, 09:32 PM
RPM314 is offline
Find More Posts by RPM314
Tailless fly-hard
RPM314's Avatar
United States, NY, Brooklyn
Joined Apr 2012
Question
Parkzone gear
Hi, all. I keep hearing that you should not put parkzone ember/vapor gear into anything over 18" wingspan. Is that because of weight, wing area, drag or something else? Thanks in advance.
-RPM
RPM314 is offline Find More Posts by RPM314
Old Mar 14, 2013, 10:27 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
-RPM
Yes....
Basically, you only have so much power available, on the motor, as well as the servos.... You can put it in whatever size plane you want, but anything bigger than about that size might not fly, or fly very poorly...
dacaur is offline Find More Posts by dacaur
Old Mar 15, 2013, 05:29 AM
RPM314 is offline
Tailless fly-hard
RPM314's Avatar
Joined Apr 2012
Which option are you saying 'yes' to, though?
Usually power loading is dictated by weight, but the wingspan rule suggests area. But the area can remain the same while span fluctuates. So it could be a matter of induced drag, but that makes no sense.
Old Mar 15, 2013, 07:44 AM
JRuggiero is online now
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
It's primarily a matter of weight, both power loading and wing loading.
Jim R.
JRuggiero is online now Find More Posts by JRuggiero
Old Mar 15, 2013, 02:06 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
all of them bigger wingspan generally his higher weight as well as more wing area and more drag.... obviously that's not a hard and fast rule, just like anything over 18" wont automatically fly poorly with the brick. Multiple factors come into play, including all the ones you listed. Use common sense, keep the weight around an ounce, and if using a high drag airframe, keep it smaller than you would with something more slippery....
Old Mar 15, 2013, 02:25 PM
RPM314 is offline
Tailless fly-hard
RPM314's Avatar
Joined Apr 2012
You think something like this might work reasonably well?
Old Mar 15, 2013, 03:41 PM
JohnC is offline
Find More Posts by JohnC
Senior Moments...I forgot
JohnC's Avatar
New Hyde Park, NY
Joined Mar 2001
I have vapor receiver but the motor was MO low power motor and gearing 8 to 1 for a Robelan "Walker". Flies fine but no rog. It is bi plane and the wing span is 23 inches. Total weight about 32 grams. It is rudder and throttle.
John
JohnC is offline Find More Posts by JohnC
Old Mar 15, 2013, 05:54 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
about 50 grams AUW is what was the limit of stock for me. the ar6400 with an external ESC opens up alot of ideas. once you add a bigger servo for he alierons (i used hk 2.0 gram servo) you can fly bigger planes. twin stock motors with gws 5030 will net you close to 100 grams static thrust. iv flown 28 inch slow trainers on the ar6400t gear.
nemoskull is offline Find More Posts by nemoskull
Old Mar 15, 2013, 07:35 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
it sure looks light, but its tough to say, with so much wood, i bet its closer to 2 ounces than 1.... My gut says it will work OK, but not great. If you try it, definitely build it lighter than the plans specify, it actually takes a stronger model to deal with rubber band power than slow fly R/C.....
Old Mar 15, 2013, 07:41 PM
RPM314 is offline
Tailless fly-hard
RPM314's Avatar
Joined Apr 2012
Gotcha. I'll see what I can do.
Old Mar 16, 2013, 12:08 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The Ember II / Vapor Bricks only have a 1 amp ESC. 1 amp ESC's mean a 6mm motor. the hottest 6mm (J-3 Cub) will fly about a 40g plane. If you are light with the throttle, you can get away with a Champ wind 8.4mm motor. This will fly 45 g with a Champ motor/gearbox, but you are at the amp limits (if not a little over).
A mustang motor that will fly 55g planes needs a 2 amp esc or the plane will cut out, which sucks. I've built a few of these and just when you are enjoying it, you have a glider.
UNGN is offline Find More Posts by UNGN
Old Mar 16, 2013, 09:27 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
For another data point: I have been flying one of my Ember II's since 2009 with a 7mm motor, 4 to 1 gear box from Hobby King, and GWS4530 prop. No problem with the ESC handling the amperage. As the SS blue and red motors became warn I replaced them with Flyzone motors from the Albatros, Super Cub, etc. These have rpm comparable to the SS blue.
Flew this Ember biplane again this morning before the sun rose within the fog!
CorvetteC5 is offline Find More Posts by CorvetteC5
Sold PARKZONE .15 size motor and NEW landing gear FRDodge Aircraft - Electric - Power Systems (FS/W) 2 Mar 18, 2013 08:51 PM
Found Parkzone T-28 Or T-28D Landing Gear Plates mattyhawk Aircraft - Electric - Airplanes (FS/W) 0 Mar 13, 2013 03:57 PM
Sold NEW Parkzone Extra 300 Parts Fuse Wing Cowl Gear gva1956 Aircraft - Electric - Airplanes (FS/W) 1 Jan 16, 2013 11:54 AM
Discussion Anyone know the gear ratio on Parkzone P-51 UM? JT2 Electric Plane Talk 1 Jan 09, 2013 11:59 PM
Discussion Anyone sucessfully rebuilt the gears in a Parkzone servo? Metal Gears? robj Electric Plane Talk 2 Feb 26, 2009 09:46 AM
