Old Mar 14, 2013, 08:22 PM
rcnutt is offline
Find More Posts by rcnutt
Centerville, In. USA
Joined Jul 2001
new toy!
Just finishing a little indoor plane .It's AUW t is 1 1/2 ounces. I used a brick from a Revell Proto Max heli. The motor is 2 motors geared together from a defunct twin rotor heli. It does not have a rudder It has ailerons, elevator and esc. So It should roll and loop pretty well but no knife edges and hovering probably won't be possible because the motors on it are most likely not strong enough and anyway without a rudder it would be impossible., But I'm thinking it will be kind of fun to fly. Here's hoping. Here are a couple of pics. I may put some wing strakes on it for a little more stability.Not sure if that is a good idea or not. RCNutt
rcnutt is offline Find More Posts by rcnutt
Old Mar 14, 2013, 08:40 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
I'm saving parts to do about the same thing with a V911 brick.
What is your wing span?
Butch777 is offline Find More Posts by Butch777
Old Mar 15, 2013, 05:37 AM
rcnutt is offline
Joined Jul 2001
The winspan is about 22 1/4" measured from aileron tip tp aileron tip. The plane is made from 1 mm and 2 mm foam fron RCFoam. They also have all kinds of CF tubes and rods. The wing and tail is 2mm while the control surfaces are from 1 mm foam. The 1 mm foam comes with a curve in it so I staightened my individual pieces using a hair dryer. Hope that helps. Where did you get your v911 brick from? I have a flyzone triplane a fellow club member gave me but the rx part doen't work .RCNutt
Discussion WL Toys V969, 979, 989, 999 new at Banggood Arr0wHead Mini Multirotors 45 Mar 14, 2016 06:05 PM
Discussion Getting a new toy... RCWorks Life, The Universe, and Politics 26 Feb 19, 2013 01:11 PM
Sold Brand new WL Toys V911 micro heli $40 shipped jriley1974 Aircraft - Electric - Helis (FS/W) 2 Jan 08, 2013 02:29 PM
Sold Three "BRAND NEW" WL Toys V911s For Sale CCbusa05 Aircraft - Electric - Helis (FS/W) 5 Jan 07, 2013 05:04 PM
