Old Mar 14, 2013, 01:45 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Washington
Joined Apr 2009
Question
servo tester to control motor
Can a servo tester be used in lieu of a RX to control a brushless outrunner?
The reason I ask is that I picked up a Astro Whattmeter 101 at a swap meet. Searched the net for instructions and came up with the attached instruction sheet.
On page 2 you will see a diagram showing a servo tester being used to operate a motor. It shows being plugged into the ESC.
Normally, one would plug in a battery to the servo tester then a servo into the servo ports. The diagram does not indicate which port is to be used, but I am assuming it would be the servo port.
Here is the instruction sheets with the diagram on page 2.
Tom
tacx is offline Find More Posts by tacx
Old Mar 14, 2013, 05:12 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Yes many of have been doing it for years. Almost everyone who does any motor testing uses something like that instead of messing about with a TX and RX.
Note: that diagram assumes that the ESC has a BEC function to power the servo tester via the ESC lead. If it doesn't then the servo tester will need connecting to the receiver battery too.
Steve
slipstick is online now Find More Posts by slipstick
Old Mar 14, 2013, 06:56 PM
Chatenever is offline
Find More Posts by Chatenever
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
Will it work with a car ESC to run the motor both forward and backward?
Chatenever is offline Find More Posts by Chatenever
Old Mar 14, 2013, 07:20 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Yes. Just be aware that the servo tester must be in the center position for the motor to be stopped. The motor will run in opposite directions as the servo tester is moved away from the center position in each direction.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Mar 14, 2013, 07:36 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Here is my test stand with the servo tester (from Gobrushless.com) in place.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 14, 2013, 09:04 PM
tacx is offline
tacx's Avatar
Joined Apr 2009
Great thanks,
Will save the hassel of hooking up to a rx and using the TX.
But I have one more question. When testing a power setup you usually check the amp draw at WOT. A ESC has to be clibrated to the TXs high and low throttle parameters.
If checking amp draw with a servo tester how does one know if the motor is at WOT?
In other words, does the ESC have to be calibrated to the servo testers high low parameters?
Tom
Old Mar 14, 2013, 10:59 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
The servo tester would be calibrated to the ESC the same way as a transmitter throttle control is. The only difference is that you would be using the servo tester's knob instead of the transmitter's throttle stick.
Larry
Old Mar 17, 2013, 09:06 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Originally Posted by tacx View Post
Great thanks,
Tom
Are you using a Castle Creations ESC (Phoenix, Thunderbird, etc.)? If so those can be calibrated quickly each time they are powered up. And it might be worth trying the same process on other ESCs too:
1 - Set the servo tester to about 3/4 of it's rotation clockwise (that would be about 3/4 throttle)
2 - Connect the ESC to the battery, wait a few seconds (CC ESC will count cells and stop on the partial throttle error and make some tones)
3 - Turn servo tester to full throttle and wait for more tones (CC ESC will set that as full throttle and play the happy tones)
4 - Slowly turn the servo tester CCW until you hear another set of happy tones and then the arming tones (that is zero throttle).
Then I am calibrated and ready to test. CC ESCs will not run the motor backwards (as is suggested above) if you go below zero throttle. In fact I've never seen any ESC that will do that. But I don't have any reversing capable ESCs either. Maybe that is the difference.
Jack
jackerbes is offline Find More Posts by jackerbes
Sold ESKY Multi Servo ECS speed controler tester checker FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 3 Mar 05, 2013 04:13 PM
Sold rc parts, Battery connectors, low voltage buzzers servo tester more ronzer Cars - Trucks and Parts (FS/W) 5 Jan 18, 2013 10:49 PM
Wanted Servo Tester Davidpe Aircraft - General - Miscellaneous (FS/W) 2 Jan 10, 2013 12:24 PM
Mini-HowTo DIY Motor/Servo Tester FF Controller rich smith DIY Electronics 0 Nov 05, 2008 11:32 AM
Servo Tester ccts for motor control steve lewin Control Line 1 Apr 26, 2001 07:40 AM
