Old Jan 03, 2004, 06:47 PM
Joined Dec 2003
easy switch from 2s-3s lipo w/pixi 20???
is there an easy way to switch between a 2s2100 and a 3s2100 with a pixi speed controler? i have the cutoff set for 5volts on the 2s and it is not quick and easy to reset this everytime i switch to the 3s. i know you need it set for 2.5volts per cell, but if i set it for the 3s then i end up with a cutoff of 7.5volts and my 2s is only 7.2volts. there has to be any easy way, doesn't there?
kiteboarder is offline Find More Posts by kiteboarder
Old Jan 04, 2004, 07:09 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Easy was is to reprogram the ESC.
..a
Question Moving From 2S to 3S On My FP Hummingbird...?!? Minimole Micro Helis 71 Sep 07, 2005 05:18 PM
Can I safely use a Feigao w/3s lipo, w/these gears & prop? temacc Power Systems 29 Dec 17, 2004 11:25 AM
FS: Hardly used Kokam 2s 560mah lipo w/jst. TheLost Aircraft - Electric - Airplanes (FS/W) 6 Aug 20, 2004 01:04 PM
FS: Kokam 2S, 3S Lipo Batt and HeCell Charger gwong Aircraft - Electric - Helis (FS/W) 4 May 03, 2004 10:40 PM
what prop and gear for rz300 on 2s and 3s lipo RCZohn Power Systems 2 Nov 04, 2003 09:39 PM
