Old Mar 14, 2013, 12:44 AM
T.D. is online now
Find More Posts by T.D.
T.D.'s Avatar
Vancouver, Canada
2 metre speedwing.
Started this 'wing tonight, it will be a 1 piece 2 metre bagged carbon surface with carbon capped spars.
The cores were CNC wire cut by my building and flying buddy Dale and they came out great. The 'wing uses a modded MH-64 at 26 degrees sweep, -1 degree anhedral and transitional washout of 1.5 degrees. Power will be a HET Typhoon but not sure which yet.
I'm going to build a plywood bagging bench using the plan form of the 'wing including anhedral...lots to do.
I'll post photo's as I go if anyone is interested.
Tony
PS, the name of my 'wing 'Sebess' is a shortened form of 'velocity' in Hungarian and when anglicized is pronounced Shebess.
T.D. is online now Find More Posts by T.D.
Old Mar 14, 2013, 02:08 AM
andrecillo76 is offline
Find More Posts by andrecillo76
andrecillo76's Avatar
Germany, BW, Stuttgart
Joined Oct 2009
Interesting!Is the airfoil constant along the span?
Sure
Andrés
andrecillo76 is offline Find More Posts by andrecillo76
Old Mar 14, 2013, 02:23 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
More I hate the stuff
Winglets at the tips?
Stuart A is offline Find More Posts by Stuart A
Old Mar 14, 2013, 09:40 AM
Knoll53 is online now
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
That is a tiny amount of wing twist.....This thing IS going to be fast. With that speed and wing sweep, you can't have too much carbon. One piece wing solves a lot of problems.
A "plywood bagging bench"? I can't imagine what that would be.
Looks like a cool project Tony. Keep us posted.
Kent
Knoll53 is online now Find More Posts by Knoll53
Old Mar 14, 2013, 05:01 PM
T.D. is online now
T.D.'s Avatar
Vancouver, Canada
Started laying out the tow for the main spar caps, it starts at 4mm in the centre and transitions to 2.5 at the tip...I'm using a derivative of the spar set up in this article from B2 Streamlines:
http://www.rcsoaringdigest.com/OTW/o...uppression.pdf
To achieve the rounding of the spar caps I'll route a channel in the back side of the bagging bench and bag the caps up in there with a squishy plastic plug on top so they will also have the anhedral.
Andrés, the tip section is the MH-64 thickened slightly and lightly blunted at the leading edge...I've had luck with this set up in the past so IMO no sense in changing what works.
Stu, yup tip mounted winglets which will have their main mounting location tied into the end of the spar but most of their mass behind the spar. Did a little modeling on this and it 'might' work out okay.
Kent, I'm hoping for 200+ KPH but who knows? I'll post photo's of the bench set up, it's really simple and makes for an easy/accurate lay up and bagging.
T.D.
Old Mar 14, 2013, 06:06 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
http://www.rcgroups.com/forums/showt...colibri&page=2
This may be of interest.Tow both sides of the hinge line.
Old Mar 14, 2013, 07:01 PM
T.D. is online now
T.D.'s Avatar
Vancouver, Canada
Thanks Stu, I've read that thread a few times. The spar on my 'wing will be 5 or so mm in front of the hinge line with the A-frame set up as shown in the article I linked to...but I am going to add a lighter spar at a point behind the leading edge as I want this 'wing to be as ballistic as possible.
I'd like to say I'm hunkered down over my plan right now but the truth is I'm washing tonight's dinner dishes.
Tony
Old Mar 16, 2013, 01:48 AM
T.D. is online now
T.D.'s Avatar
Vancouver, Canada
Started the spar slots, 9mm wide with a crescent transition at the root for a constant width and tapered thickness carbon cap top and bottom with a +/- 25 degree, 3mm thick carbon cloth shear web between them. I could get away with no shear web at all but the bit of margin the web supplies is worth it IMO.
Thinking of going with 30% tip to 25% root elevons only (no flaps) on the outer 50% of the semi-span...opinions are most welcome on this idea.
T.D.
Old Mar 16, 2013, 09:25 AM
less is more
Knoll53's Avatar
Joined Sep 2006
I'm not quite clear on how you plan on adding shear to your spar. A few more piccies, when the time comes, would be helpful. I like the idea of crossing the spars and connecting them....see attached.
This looks similar the the CO5. IIRC, they used elevons that were 1/3rd the halfspan plus a similar elevator at the root. It would certainly fly with just elevons.
Looking forward to how you plan on attaching the winglets. Many different approaches there.
Kent
Old Mar 16, 2013, 11:45 PM
T.D. is online now
T.D.'s Avatar
Vancouver, Canada
Kent, to achieve the shear webbing I will lay in one side of the tow spar (the top side first) then hot wire a vertical slot in the centre of the bottom spar slot that goes through the core span wise and ends at the pre bagged top tow spar then insert the pre-cured 25 degree bias carbon cloth shear web ...it makes for more work and fiddling but what the hay.
I'll post photo's when I do it...maybe a video if I can set that up.
Tonight I finished sanding the spar slots...what Vernon Hunt calls "ditches". Instead of a forward carbon tow spar I'll lay a full span 5cm root to 3cm tip wide piece of uni against the core in that area when I lay up the 'wing.
Tony
Old Mar 17, 2013, 03:16 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Just wondering if you might be better with a line of tow either side of the hinge?It would add a lot of stiffness to the surfaces
Old Mar 17, 2013, 01:36 PM
T.D. is online now
T.D.'s Avatar
Vancouver, Canada
Good idea Stewart.
I'm going to put a 1K disser on the elevons so tying that into the span wise tow you suggest will be good.
We are finally having some sunshine here so I'm off now to do some 1/12 electric combat.
Tony
Old Mar 20, 2013, 02:22 AM
T.D. is online now
T.D.'s Avatar
Vancouver, Canada
Laid the carbon tow spar caps in tonight, I'll post a photo tomorrow after they come out of the hot box.
Here is a look at the slope version of the finished product, FLZ doesn't really lend itself well to plan form photos' so I laid it out in XFLR5...I like it.
T.D.
Old Mar 20, 2013, 04:29 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Nice!
Old Mar 20, 2013, 02:03 PM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Careful with XFLR5, it is sometimes very optimistic of how far you can bring your CoG. In my experience it happens more often with Fw than with regular planes
EZ
Edwinzea is offline Find More Posts by Edwinzea
Discussion Australian 12 Metre Enthusiasts Viking50 Sailboats 350 Feb 12, 2016 10:15 AM
Build Log 2 Metre Constant Chord Thermal Wing guitarcher Nurflügel 6 Mar 14, 2013 07:51 AM
Discussion speedwings.net rampage ds Flying Wings 3 Jan 24, 2013 08:26 PM
Discussion New releases by flyfly hobby-3 Metre fox , 2.6 Metre ask21 gliders Damian Couzoff Australia 12 Jul 26, 2010 05:11 AM
How far for ground range check? 30 metres? 80 metres? Ben C Electric Plane Talk 8 Jun 20, 2001 03:34 PM
