Old Mar 13, 2013, 09:51 PM
mpollee is offline
Find More Posts by mpollee
United States, MI, Kalamazoo
Joined Aug 2011
Question
Wiring Help
Im interested in building an rc hovercraft. My question is.. How are you guys running 2 separate motors and esc's? I plan on having a lift fan that i can control proportionally via my transmitter. And also a propulsion fan with a separate speed controller. Do i need to use some kind of board such as an arduino, or does it just hook into the receiver? Thanks.
mpollee is offline Find More Posts by mpollee
Old Mar 13, 2013, 11:04 PM
Icero is offline
Find More Posts by Icero
buy, crash, save...
United States, MS
Joined Feb 2013
are you using a car or plane transmitter? if you use a plane, i would set the throttle channel to the vertical lift motors esc and use the elevator channel for the propulsion fan.
Icero is offline Find More Posts by Icero
Old Mar 14, 2013, 09:19 PM
mpollee is offline
Joined Aug 2011
Plane tx/rx. So I can plug both esc's into seperate channels on the Rx?
Old Mar 15, 2013, 08:08 AM
Icero is offline
buy, crash, save...
United States, MS
Joined Feb 2013
yes, just use escs without becs as not to overvolt the reciever. if your escs have becs, you will need to disable one of them.
Old Mar 15, 2013, 08:12 AM
Icero is offline
buy, crash, save...
United States, MS
Joined Feb 2013
it will be tricky to get it to work properly, perhaps you should make the lift fan on a two position switch and put the propoltion fan on the left stick, or throttle.
Old Mar 15, 2013, 02:40 PM
RPM314 is offline
Find More Posts by RPM314
Tailless fly-hard
RPM314's Avatar
United States, NY, Brooklyn
Joined Apr 2012
Why would it be tricky to have it be proportional?
RPM314 is offline Find More Posts by RPM314
Old Mar 16, 2013, 05:23 PM
mpollee is offline
Joined Aug 2011
Yeah im just looking to have one channel lift and one channel thrust. Sounds like i just need to eliminate one bec as to not short out the receiver if im not mistaken.
Old Mar 17, 2013, 12:02 PM
Icero is offline
buy, crash, save...
United States, MS
Joined Feb 2013
Yes you do need to deactivate one bec.
Old May 12, 2013, 01:01 PM
davenglish is offline
Find More Posts by davenglish
davenglish's Avatar
United Kingdom, England, Market Deeping
Joined Dec 2008
Looking at the dates, you've probably got it sorted by now but I had recently had a hovercraft with the same setup.
The lift fan was on the throttle stick with an aircraft ESC (no reverse).
The drive fan was on the elevator stick with a car or boat ESC so it could reverse.
To disable one of the BECs, I removed the positive pin from the plug and tied it back.
davenglish is offline Find More Posts by davenglish
Discussion Help with wiring an H-bridge dmccormick001 DIY Electronics 27 Feb 10, 2013 04:45 PM
Discussion Xieda wiring help needed treff Beginner Training Area (Heli-Electric) 3 Jan 27, 2013 11:32 AM
Help! Lipo 2s balance wiring help please dzgn Batteries and Chargers 3 Jan 26, 2013 10:05 AM
Discussion Wiring/soldering help with 900mhx system pete914 FPV Talk 11 Jan 20, 2013 03:20 PM
Help! need some electronic wiring help abletowinginc DIY Electronics 0 Jan 14, 2013 07:12 AM
