Old Mar 12, 2013, 09:04 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
edf fan/cylinder to outlet diameter ratios
Not sure if I'm asking this question correctly, but I'm beginning to indulge in EDF foamies, and want to know how the diameter of the outlet (actual tube in rear of the fuse) compared to the fan or the edf unit diameter is designed. I've done a rudimentary search on this forum, but haven't found anything I can use, yet. A tutorial on the EDF setup would be great!
springer is online now Find More Posts by springer
Old Mar 13, 2013, 12:02 AM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
im sure there is something here on it ...just may not have the right words for the search. try exhust fsa or tail pipe fsa . normally we run 90% to 80% exhust outlet size to the fan size. so it should be smaller than the fan shroud.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Mar 13, 2013, 12:14 AM
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Here's a thread about FSA, Fan Swept Area, I asked about a while back. The wiser folks kindly educated me!
Fan Swept Area
(Love your Avatar animation, btw!)
xmech2k is offline Find More Posts by xmech2k
Old Mar 13, 2013, 12:19 AM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Springer,
Search on Clausxpf (inlet/exhaust duct basics) for all the info you can handle. Also check out the builds in the Scratch Built and Micro EDF Forums. Also, look for Air Sally for how to make ducts. lmao!!!
ksqm is offline Find More Posts by ksqm
Old Mar 14, 2013, 07:58 AM
treefinder
springer's Avatar
SE MI
Great! Thanks for the tips & leads! I got some reading to do.
Old Mar 14, 2013, 08:46 AM
treefinder
springer's Avatar
SE MI
Xmech: I went to your thread, and found a wealth of info, thanks! But as usual, it generated more questions. My first intro to EDF is gonna be a DH Venom.(well maybe, if I can figure the propulsion out. The goal is to size it to a single sheet of MPF - onesheeter #13 or #14 (it will make sense if you check my blog)
Anyway, from the other thread, why use fan shroud I.d. instead of actual fan dia. in the FSA calculation? Also, is something like 90% FSA inlet (including half lip radius) to 80% outlet a good general proportion? What happens if the inlet approached or exceeds 100% FSA? Finally, do all these proportions still hold with a split inlet, or are other "accommodations required? (maybe I should do the F86 I was originally considering.......)
Old Mar 14, 2013, 10:18 AM
ksqm is offline
Joined Mar 2009
Aaaahhhhhh! Feel the Force Springer. Come to the Dark Side. Check out this thread. It has a lot of reference links and awesome cad work.
Ksqm
Old Mar 14, 2013, 12:13 PM
xmech2k is offline
xmech2k's Avatar
Joined Jun 2007
Springer, your questions are already way over my head! Someone in that thread I started said a good intake size varies with the complexity of the ducting. He mentioned someones F-86 that had an 80% intake size and was great, but that's a pretty much straight through duct. haven't designed or even built my own edf's yet, I'm still on ARF's, so I just wanted to learn about the whole FSA intake/exhaust ratio thing to see if an exhaust tube could help any of my models or not. Turns out only my Dynam Turbojet (Cessna Citation) is the only one with an oversized exhaust, and might pick up some speed with exhaust tubes. But it's still on my to-do list.
Old Mar 14, 2013, 12:33 PM
treefinder
springer's Avatar
SE MI
Kq thanks for the tip!
xm: they are over my head as well, but I figure there are no dumb questions and the guys on this forum are as cool as those on the scratchbuilt foamies one, so I'll get great answers! I haven't done any ARF's, built a Gentle Lady balsa and monokote when I got back into the hobby in 04, but found the scratch built forum and foam, and haven't done anything else since. now past 70 planes and the addiction is only getting stronger!
Old Mar 14, 2013, 01:23 PM
xmech2k is offline
xmech2k's Avatar
Joined Jun 2007
70 planes!! And my wife thought I was bad with about a dozen! (That she knows of...)
Old Mar 15, 2013, 09:23 AM
treefinder
springer's Avatar
SE MI
It's just a matter of time.....Foam is just too easy to work with!
I downloaded the two spreadsheets and played with them, got the specs of my fan (a hobby king 55mm Aeorc, so not such great shakes, but it pulled out of my hand nicely at 25amps with 3s pack) and started the FSA and inlet/out let tinkering in Sketchup. Looks if I size the plane to the outlet dia, it'll come in at 50" span, which is a bit more than I'd like, so I may have to go non scale on the outlet (). It's gonna be stand way off scale anyway. Just another fun flyer, and have to fit it onto a single sheet of MPF. A nice challenge for packaging and propulsion - gotta keep the old dog learning new tricks!
Sold Clearing out some EDF stuff - 90mm fan, ARC motor, 40mm fan, retracts realdeal Aircraft - Electric - Jets (FS/W) 13 Feb 06, 2013 03:33 AM
Question EDF fan size vs. exhaust outlet size fyter889 Electric Ducted Fan Jet Talk 7 Aug 29, 2010 10:22 AM
Discussion Airflow Outlet diameter to use? CSI Electric Ducted Fan Jet Talk 4 Jan 08, 2010 04:00 AM
Discussion Inlet to outlet ratio Bigplumbs Electric Ducted Fan Jet Talk 3 Nov 13, 2009 09:49 PM
Inlet/fan/outlet ratios P_J_Glor Electric Ducted Fan Jet Talk 1 Nov 27, 2002 03:36 PM
