Old Mar 12, 2013, 04:18 PM
Vernon, CT
Joined Sep 2008
New eLogger incorrect pack voltage
Just installed a new eLogger and latest software. After about 1/2 hour of testing the pack voltage and amperage now show 42 volts and 0.8a. I have a 7.2v pack, receiver and brushed esc connected with the motor disconnected. Before this happened voltage and amps were correct. Is it possible I messed up some configuration parameter or is this a hardware failure?
Any advice will be appreciated.
stanb112 is offline Find More Posts by stanb112
Old Mar 12, 2013, 05:00 PM
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Follow the Trouble Shooting ships at the bottom of the manual .pdf file in regards to voltage and amperage and then check again.
I had a bad eLogger. You can see my thread on it here
http://www.rcgroups.com/forums/showthread.php?t=1846901
Ken Myers is offline Find More Posts by Ken Myers
Old Mar 12, 2013, 06:14 PM
Vernon, CT
Joined Sep 2008
Thanks for the reply, Ken. Unfortunately my voltage is way off, reading 40+
volts for a 7.2v pack so I suspect a component failure. But any more suggestions will be welcome. Stan
Old Mar 12, 2013, 06:46 PM
Vernon, CT
Joined Sep 2008
Fixed!
It works properly now. I uninstalled all Eagle Tree software, deleted all associated files, cleared the registry then reloaded the software. My guess is that something relating to my older car data recorder files was causing the problem. Anyway, I'm happy now. Stan
Sold Spektrum DSMX Telemetry: TM1000, Altimeter, Temp, Pack Voltage kicekilla Aircraft - General - Radio Equipment (FS/W) 3 Jan 13, 2013 11:48 AM
Discussion New OSD shows incorrect voltage? IconFlyer Hoverfly Technologies 20 Mar 05, 2012 03:16 AM
Help! Eagle Tree OSD/elogger V4 voltage/pack input 558th_AV8R Eagle Tree Systems 3 Feb 13, 2012 07:50 PM
Question Does eLogger record individual cell voltage or just total voltage? Neil_SC Eagle Tree Systems 1 Mar 10, 2011 02:37 AM
Discussion New Lipo packs - Cellpro balance taps wired incorrectly ? Al P Batteries and Chargers 11 May 09, 2007 03:46 PM
