Mar 12, 2013, 12:00 PM
United States, CA, Laguna Niguel
Joined Jul 2011
Triton Jr
comes in original box 40$ shipped to your door
This is the ElectriFly TRITON Jr. DC Computerized
Charger, Discharger and Cycler from Great Planes.
Ideal for smaller electric flight applications
including airplane and electric heli batteries,
transmitter and receiver batteries and field batteries.
****Now with Slow Charge Capability, see COMMENTS.****
FEATURES: Charges 1-14 Nickel-Cadmium or Nickel-Metal Hydride cells,
1-4 Lithium-Polymer or Lithium-Ion cells (LiPo or Li-Ion),
or 2-12V lead-acid batteries (Pb)
Precision "Zero DeltaV" Peak Detection for NiCd and NiMH batteries
"Constant Current/Constant Voltage" charge method for Pb and LiPo/
Li-Ion batteries
.1 - 5A adjustable Charge Current, limited to 1C rating for LiPo
batteries
.1 - 1A adjustable Discharge Current
Automatically sets TRICKLE Charge Current at 1/20th the Fast Charge
current setting (NiCd/MH only)
Adjustable Discharge Cutoff Voltages for NiCd/MH, pre-set voltages
for Pb and LiPo/Ion
Cycles NiCd and NiMH batteries from 1 to 5 times
Durable membrane touchpad input controls, and very simple
programming menu
Easy to see, 32 character (2x16) LCD with Blue back-lighting that
displays Input and Output Volts, Peak Volts, Average Discharge
Volts, Charge and Discharge Capacity, Currents and Time, and error
messages
Status screen constantly updates Capacity, Battery Voltage, Current,
and Time during use
Audible beeper aids in programming and notifies of function changes
Safety features include Fast Charge Safety Timer, Current Overload
and Reverse Polarity Protection
Small and lightweight, with a rugged extruded aluminum case for
long-lasting durability and excellent heat dissipation
One year warranty
INCLUDES: (1) TRITON Jr.
(1) Instruction Manual
REQUIRES: Charge lead with banana plugs to match your battery pack connector
SPECS: Input Voltage: 11 - 15V DC
Input Connections: Large alligator clips
Number of Outputs: One
Battery Types, # Cells: 1-14 NiCd/MH
1-4 LiPo or Li-Ion (3.6 or 3.7V cells)
2, 4, 6, 8, 10, 12V Pb (2V per cell)
Fast Charge Current: .1-5A NiCd/MH (.1A step, 63W max.)
1C rating LiPo/Li-Ion (63W max.)
Fast Charge Termination: "Zero DeltaV" Peak Detection NiCd/MH
"CC /CV" for Pb and LiPo/Ion
Peak Sensitivity: 8mV fixed NiCd, 5mV fixed NiMH
Peak Delay at Start: 3 minutes fixed
TRICKLE Charge Current: Charge current/20 (NiCd/MH only)
Fast Charge Safety Timer: NiCd/MH 1.5 hours, LiPo and Pb 2 hours
Thermal Cutoff: Not available
Discharge Current: .1-1A (.01 step, 5W max)
Discharge Cutoff Voltage: NiCd/MH .1-16.8V (.1 step)
Pb fixed at 1.8V per cell
Li-Ion/LiPo fixed at 3V per cell
Cycle Count: 1 - 5 Cycles
Battery Memories: One
Programming Controls: Membrane touchpad, four buttons
Display Type: 2 x 16 LCD, Blue backlight
Displayed Info: Input and Output Volts, Peak Volts, Average Discharge
Volts, Charge and Discharge Capacity, Currents and Time, Errors
Audible Indicators: Beeper
Output Connectors: Banana jacks
Case Material: Extruded aluminum
Current Overload: 10A spade fuse
Case Size: 4.7 x 3.6 x 1.2 in (118 x 92 x 30mm)
Weight: 13.1oz (371g)
COMMENTS: *********To Slow Charge NiCd and NiMH Batteries*********
A backup safety timer automatically shuts down the charge process
after a certain time if the charger does not recognize that the
battery has reached full charge. This timer can be shut OFF in the
"Safety Timer On/Off" screen by pressing "BATT TYPE". This will
allow NiCd or NiMH batteries to be slow charged. Leave set to "ON"
when charging lithium batteries. This timer will reset to "ON" each
time power is removed from charger.
