Old Mar 11, 2013, 10:21 AM
nickwad is offline
Find More Posts by nickwad
Nine inch member
nickwad's Avatar
Thailand, Chon Buri, Bang Lamung
Joined May 2006
QuadH2o Waterproof Quadcopter
Moved from Aquacopters thread
Originally Posted by teamhairball
How much? How soon will you be in production?
We are just putting the prototype together at the moment , But after testing and any tweaks to the design have been carried out we will be taking orders if there is any interest.
We are building the prototype to allow us to fly stress free over water for videoing of beach front properties and boats at sea.
all the 'running gear' is going to be the same as we use in the TBS discoveries.
The' Scarab' is slightly longer and wider motor to motor than the TBS discovery (awesome machine when set up properly) but basically the same arm layout.
We have not finalized the price yet but it will be in the region of $1000.
This will include carbon fibre undercarriage and bubble retaining ring, Bubble and seal, Rear cap and seal , Internal floor for mounting electronics, Battery mounting tray. Mounting hardware for undercarriage and bubble.
The bodies will be painted in a single colour of customers choice (multi colours at extra cost)
I will post more pics and video when we are testing ......Nick
nickwad is offline Find More Posts by nickwad
Old Mar 11, 2013, 10:48 AM
nickwad is offline
Nine inch member
nickwad's Avatar
Joined May 2006
Some pictures, I will take some more tomorrow and post them.
Old Mar 11, 2013, 10:53 AM
MayMayDay is offline
Find More Posts by MayMayDay
ParagonUAV
MayMayDay's Avatar
Canada, BC, Vancouver
Joined Mar 2012
Haha, I'm actually in the process of making one just like this. Very nice. What's your frames weight (nothing installed), and is there an access point other than the front?
Edit: is that price just for the frame??
MayMayDay is offline Find More Posts by MayMayDay
Old Mar 11, 2013, 02:47 PM
hazardpro is offline
Find More Posts by hazardpro
United Kingdom, Worthing
Joined Dec 2012
Wish list if I may
  • Ideally access for 4S battery (s) depending on weight (I presume they go in via the rear hatch?)
  • Fully loaded +8min flight times
  • Bara / Naza compatibility
  • Naza GPS compatibility
  • Internal gimbal of some sort (or space for one)
  • and / or bracket for FPV cam in the 'bubble'
  • "'internal floor' for electrics" - would be great if this can slide in/out via the 'bubble' hatch - eg so you fit everything to the 'internal floor' outside of the frame, then slide it inside once complete...
This thing looks awesome, cant wait to see it develop! Subscribed....
hazardpro is offline Find More Posts by hazardpro
Old Mar 12, 2013, 06:12 AM
nickwad is offline
Nine inch member
nickwad's Avatar
Joined May 2006
Originally Posted by hazardpro View Post
Wish list if I may
4s 3600 fits fine ( also can slide up to 5 inches forward of the rear cap to achieve C of G required my guess it will be around 10 to 15 mm forward of balance point as this aids fast forward flight)
Flight time to be checked when prototype complete should be around 8+ mins as the weight is less than our TBS Discoveries
Baro should be OK with a breather patch again testing needed.
The Naza gps fits inside the raised section of the housing.
We plan to mount the FPV camera on a tilt gimbal inside the housing , the Scarab is really designed for carrying the hero 3 underneath its waterproof case , it will be fixed for a start but we plan to use a tilt/ roll gimbal later.
yes the removable floor is exactly what we have in mind so the electronics can be slid out for access.
Going together tomorrow !
Here are some more pics
Old Mar 13, 2013, 09:14 AM
nickwad is offline
Nine inch member
nickwad's Avatar
Joined May 2006
It alive ! flies well 10 mins 30 on a 3600mah 4s with no go pro in the housing but ballast the same weight as the FPV equipment so should be good for 8-9 mins .
Water testing after a bit of siliconing of wires etc.
The esc's were running at 44-45 degrees with no dome on so we decided to fit them with heat sinks fitted through holes in the housing now running 38 degrees after 10.5 mins with dome fitted not too bad as ambient here was 32 today !
Old Mar 13, 2013, 10:03 AM
Joined Dec 2012
It looks the nuts!
Would like to see a pic/video from FPV cam in the dome when its ready so we can see what the glare is like and also what (if any) vibrations it picks up.
Gopro under is fine. I'm still waiting for someone to come up with a waterproof gimbal
Look forward to more testing results and some videos!
Looks sweat when painted up
Good job.
Doug
Old Mar 13, 2013, 10:47 AM
dr427 is offline
Find More Posts by dr427
Born Again Newb
dr427's Avatar
United States, OK, Oklahoma City
Joined Mar 2013
http://www.jwfishers.com/tov1.htm
The yellow looks like an underwater camera/robot.
Cool design though! The heat sinks are a great idea!
dr427 is offline Find More Posts by dr427
Old Mar 13, 2013, 03:28 PM
Joined Dec 2012
it would be ideal if the Naza light could be seen from the ground (though not essential)
It could actually be placed in view of the fpv cam if it has tilt capabilities (probably doesn't need pan)?
"Baro should be OK with a breather patch again testing needed."
Any idea where this will be fitted? Will they come pre fitted/supplied with kit?
Looking forward to more spec details
ALSO what is the MAX dimensions possible for battery? We run 4S 4000mAh on our TBS's, with FPV and carrying a GoPro you are looking at about 10mins)
Doug
Old Mar 13, 2013, 07:15 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
This looks pretty cool. I would like to have a wire rope isolator between the frame and the GoPro to take out the last bit of vibrations. I put one on my aquacopter and it works great.
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Mar 13, 2013, 07:51 PM
AlanGold is offline
Find More Posts by AlanGold
AlanGold's Avatar
Joined Oct 2012
I'm sure your product is fine but don't you know there already is a line of multirotors called Scarab?
http://www.multiwiicopter.com/package-deals/
AlanGold is offline Find More Posts by AlanGold
Old Mar 13, 2013, 08:14 PM
360walt is offline
Find More Posts by 360walt
Joined Feb 2012
What do you get for $1000
360walt is offline Find More Posts by 360walt
Old Mar 13, 2013, 08:18 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
First post lists what is included.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Mar 14, 2013, 01:25 AM
nickwad is offline
Nine inch member
nickwad's Avatar
Joined May 2006
u
No I didn't know that , thanks for telling me ! We will have to go back to the nickname it acquired during construction " The dead pig' Lol
Any suggestions on a suitable name are welcome ! ( $ 150 discount if we go with your suggestion! )
Nick
Old Mar 14, 2013, 01:28 AM
nickwad is offline
Nine inch member
nickwad's Avatar
Joined May 2006
It has not been finalized yet what will be included but it will be all previously mentioned plus some other parts such as heat sinks etc and the price has not been set yet we are trying to keep it a bit under $1000.
Nick
News The Waterproof Quadcopter! Jim T. Graham Multirotor Talk 2 Feb 28, 2013 01:41 PM
