Old Mar 10, 2013, 05:46 PM
FR4-Pilot is online now
Find More Posts by FR4-Pilot
That's Pretty Neat!
FR4-Pilot's Avatar
Joined May 2009
Help!
PowerPanel Display - Strange Behavior ...
Hello,
New elogger v4 customer here. I have the elogger V4, Power Panel, and brushless RPM sensor.
I'm noticing the RPM value displayed on the Power Panel for headspeed/prop is bogus, while the value logged and graphed is correct. If I change to display motor RPM on the Power Panel it appears correct.
Century Swift 16 Helicopter, 800kV motor, 8 Poles, 12T pinion 96T main gear, 8:1 ratio - all setup in the Eagle Tree Data Recorder on my PC.
eLogger Application version 10.44
eLogger V4 Firmware version 1.21
FR4-Pilot is online now Find More Posts by FR4-Pilot
Old Mar 10, 2013, 06:23 PM
That's Pretty Neat!
FR4-Pilot's Avatar
Joined May 2009
I have some more info regarding this issue on the Power Panel:
If I choose to display "RPM" (motor RPM) AND "Propeller RPM (Headspeed)" only then will Propeller RPM (Headspeed) display correctly.
And, if I choose to display "Electric Motor Current" AND "Milliamp Hours" only then will Milliamp Hours display correctly.
I'm finding that Propeller RPM and Milliamp Hours do not display correctly unless RPM and Electric Motor Current are also being displayed.
Is this normal? Can't I just display Propeller RPM (Headspeed) and Milliamp Hours without also displaying the other two? I didn't see any requirements like this in the manual ... (?)
Thanks!
-John
Old Mar 11, 2013, 06:59 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi John,
I do apologize - it looks like there's a bug with that with the powerpanel. I've reported that to our software developer for investigation.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Mar 12, 2013, 09:24 AM
That's Pretty Neat!
FR4-Pilot's Avatar
Joined May 2009
Thank you very much for looking into this Hopefully it can be fixed by a simple firmware update.
I do have a work around:
I only need to see page 1 and want to see Pack Voltage, HeadSpeed RPMs, Cumulative Milliamp Hours, and Current Draw. Luckily, having Current Draw displayed allows the Milliamp Hours to display correctly. But, I also need to display Motor RPMs somewhere (but no more room on page 1), so I do that on page 2, and set the "change-pages" option to switch pages when a temp probe is disconnected and re-connected. Since I don't have a temp probe installed, only page 1 is displayed so that seems to work for now.
I can also let the pages cycle automatically using the 2 second setting, but I prefer the single page display, for now anyway.
Thanks again,
-John
Old Mar 23, 2013, 09:06 PM
That's Pretty Neat!
FR4-Pilot's Avatar
Joined May 2009
Here's how my install is going so far - I built a little platform to mount it in my Swift helicopter. I can't wait until spring really gets here
Old Apr 09, 2013, 05:43 AM
That's Pretty Neat!
FR4-Pilot's Avatar
Joined May 2009
mAH don't match ?
I'm really liking my eLogger & LCD PowerPanel, but I've noticed something and have to ask.
Cumulative mAH: The PowerPanel appears to report a lower cumulative mAH value than what is logged and graphed.
For example (and is typical), one of my last flights resulted in the following:
PowerPanel: 1543mAH
eLogger Data & Graph: 1609mAH
Any clue as to what's happening here?
-John
Old Apr 09, 2013, 08:14 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi John, small differences can show up due to the way the two modes process the incoming data, but that's a larger difference than I would have expected. Just to confirm, for the PC displayed readings, are you displaying only one session of data, or are multiple sessions being displayed?
Site Sponsor
Old Apr 09, 2013, 09:46 PM
That's Pretty Neat!
FR4-Pilot's Avatar
Joined May 2009
Single session. I had to save each session (from a multi-session capture) to disk separately, then load them, one at a time, otherwise the cumulative mAH continues from one flight to the next, at least that's what I noticed when looking at the charts.
Sold Eagle Tree - eLogger V3 and Power Panel Display monjo Aircraft - General - Miscellaneous (FS/W) 3 Dec 31, 2010 10:40 PM
Sold Eagle Tree V3 eLogger - Power Panel & RPM Sensor Highfly! Aircraft - General - Miscellaneous (FS/W) 0 May 26, 2010 12:20 PM
Sold Eagle Tree elogger v3 setup. power panel, rpm, altim. $100 shipped Splix Aircraft - General - Radio Equipment (FS/W) 3 May 04, 2010 04:59 PM
Sold Eagle Tree eLogger V3 w/mem upgrde, 10hz GPS V4, OSD Pro, Power Panel and Brushless divemasterphil Aircraft - General - Miscellaneous (FS/W) 9 Apr 21, 2010 12:57 PM
Sold Eagle Tree eLogger v3, LCD Power Panel, Brushless RPM sensor - $65 shawn595 Aircraft - Electric - Power Systems (FS/W) 5 Nov 08, 2009 05:11 PM
