Mar 10, 2013, 04:40 PM
USB driver fail
After installing the Data recorder software.
Following the instructions I connected the Osd pro and the Guardian stabilizer to the V4 logger then connected the usb to 2 different pc's through a hub and not through a hub but both computers show error code 43 for the usb device and the Logger has a constant flashing red light.
If I disconnect the OSD pro and the Stabilizer it simply says it cant find the usb driver.
If i try to start the Data recorder software it wont start and tells me to connect the Logger even if it is connected.
I have run out of options. Anyone got any ideas?
EDIT: just tried it without the stabilizer connected and it seems to be connecting now?
I figured it out i thought the upper row of pins was the lower row!!
So i was putting the gps and the osd in each others pins.
