Old Mar 10, 2013, 08:31 AM
dmrcflyr2 is online now
Find More Posts by dmrcflyr2
Engine man
dmrcflyr2's Avatar
United States, FL, Largo
Joined Feb 2006
Reusing nicked APC props
So I have had a couple of less than perfect landings of late resulting in a prop strike. This has taken the last 1/8 to 5/16 of the end of 3 of my APC propellers.
Does anyone reuse APC props that have been struck? I thought I would even these out, reshape the ends and rebalance.
I have trimmed and reshaped 3 now but I need to get a prop balancer to see how I did.
I obviously would not do this with a wood prop, but an APC I cant see the issue really.
dmrcflyr2 is online now Find More Posts by dmrcflyr2
Old Mar 10, 2013, 10:53 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
I think, as long as you don't need the lil bit of thrust you will loose, then you will be just fine!
whiskykid is offline Find More Posts by whiskykid
Old Mar 10, 2013, 11:36 AM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
If its for sport, sure. Keep in mind that if whatever size your use to using as it gets nicked up, you need to adjust your needle setting as this will make your motor run lean. In Racing, it's a No No.
Dale 813 is offline Find More Posts by Dale 813
Old Mar 10, 2013, 01:11 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
We used to accuse a club member of trimming his props by holding a running engine next to the ground. I've seen as much as a half inch taking off and people still using them.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Mar 10, 2013, 01:14 PM
Engine man
dmrcflyr2's Avatar
Joined Feb 2006
No I am not a racer just a sport flier on a budget. I have my tach with me everyday too, plus I always set my engines on the richer side for safety margin. I care more for my engines than I do the planes they sit in in general.
Old Mar 12, 2013, 08:33 AM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
re-using
I have nicked trimmed and re balanced a number of APC props with never a problem. Just tip nicks though. Brian
BrianSmith is offline Find More Posts by BrianSmith
Old Mar 12, 2013, 11:29 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
For sure always balance your props.
be careful and make sure those around you are not standing along side the props in question, it's possible they can shed a blade.
kerwin50 is offline Find More Posts by kerwin50
Old Mar 12, 2013, 11:56 AM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I've purposefully shortened them,not being nicked, (changed an 11 to a 10,for more ground clearance,in a pinch.
Careful trimming and rebalancing is all that's required.
epoxyearl is online now Find More Posts by epoxyearl
Old Mar 13, 2013, 08:02 PM
DGrant is offline
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
I've seen an APC prop shatter during run-up. The front of the prop was apparently scuffed, and barely noticeable... probably with a hairline crack in the hub zone... the prop threw a blade, and everything left of the airplane was torn off... engine, other half prop, firewall. everything just twisted.. all because the prop had a scuff.. and probable hub damage. I wouldn't do it for a $7.00(or whatever)..prop. No way.
DGrant is offline Find More Posts by DGrant
Sold APC Prop Lot, Electric Props all sizes 32 in all Ifly101 Non R/C Items (FS/W) 1 Jan 27, 2013 02:28 PM
Question Glue spacer rings in APC props? rhodesengr Electric Plane Talk 23 Jan 17, 2013 02:16 AM
Sold 63 APC & QWS Props pnman Aircraft - General - Miscellaneous (FS/W) 1 Jan 14, 2013 01:11 PM
For Sale 5 APC Props shua757 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 06, 2013 08:39 AM
Sold Big prop lots - APC slofly/GWS, APC Thin E, APC/Graupner speed props Dukester Aircraft - Electric - Power Systems (FS/W) 13 May 18, 2009 07:39 PM
