Old Jan 02, 2004, 09:41 PM
KnimRod is offline
Find More Posts by KnimRod
Gravity Tester
KnimRod's Avatar
Central Michigan
Joined May 2003
Need some painting advice for my Micro-V canopy
I've attached a picture of my VE-X with it's newly painted Micro-V canopy. It looks pretty good but the finish isn't all that shiny. The first mistake I made was that I used lexan paint from the LHS wihich I later found out is meant to be painted on the inside of the lexan because the finish is flat. The outside was painted as recommended in the Micro-V instructions. The flames were painted by a friend and there is a very light coat of clear over it all. The paint is all laquer. What I need is advice to shine it up a bit. Can I simply put on a healthy coat of clear enamel? The concern is that the dark windscreen will become milky. Any ideas?
Lance
KnimRod is offline Find More Posts by KnimRod
Old Jan 02, 2004, 10:22 PM
buzzsaw 46 is offline
Find More Posts by buzzsaw 46
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
You could try buffing it out with an automotive polish?
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Old Jan 02, 2004, 10:58 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Yes, you can paint enamel over it with no problems. Just not the other way around.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jan 03, 2004, 01:00 AM
KnimRod is offline
Gravity Tester
KnimRod's Avatar
Central Michigan
Joined May 2003
Thanks Fred, I remember that about enamel. Does ne1 have a suggestion for a brand of paint? Any special prep work needed? Also, should it be a single heavy coat, single light coat, several light coats, etc? After cetting this far with it, I don't want to risk ruining it. Thanx.
Lance
Yippee! My new Micro V canopy came today FrankW Electric Heli Talk 14 Oct 20, 2003 03:35 PM
I need some advice for my cp1300 packs mauiguy99 Batteries and Chargers 2 Aug 25, 2003 07:23 AM
Micro V Canopy or other canopies for Voyager E? Astro30 Electric Heli Talk 14 Jun 11, 2003 12:26 AM
Need Power Setup Advice For My Alliance herbalist Power Systems 3 Jan 10, 2003 01:02 PM
FS/T NIB Micro-V canopy for E-Voyager JoeR Aircraft - Electric - Airplanes (FS/W) 0 Nov 21, 2002 06:59 AM
