Old Mar 09, 2013, 08:02 PM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Question
Ignition and receiver battery mounted together?
A little background...
I have a Slipstream SBach. At the moment the CG is 166 mm aft of the leading edge, but it needs to be at 150 mm (16 mm further forward). The only thing with any weight I can think of to move forward is the receiver battery. Of course, the ignition battery is already up at the front.
This is a basic setup - no IBECs; one battery for the ignition and one for the receiver. I've done some research online and talked to some other RC fliers and I've gotten conflicting information. so...
Question: Can ignition and receiver batteries be mounted in close proximity to one another?
Cheers!
grosbeak is offline Find More Posts by grosbeak
Old Mar 09, 2013, 08:07 PM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Yes. You can tape them together if you like. What size is this Plane ? Sounds like its big enough not to worry about 1/2" or 16mm as you put it.
Dale 813 is offline Find More Posts by Dale 813
Old Mar 10, 2013, 07:41 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
As other guy says - no problem to put together.
You could if you want to increase size of one pack and make it do both jobs - removing the other completely. Connecting it via Y lead ... one to Rx .. other to CD Ignition box.
The ignition pack in fact does not have to be big ... because engine uses CD system ... the demand on battery is remarkably low.
Nigel
solentlife is online now Find More Posts by solentlife
Old Mar 10, 2013, 07:52 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Thanks for the input, guys.
It's a 29% SBach 342 with a DA 50R. And while 16 mm (closer to 5/8", actually) doesn't sound like much I really don't want my hands full with a tail heavy aircraft when I (re-)maiden it this spring.
Here's a diagram of the current setup:
And here's what I thought might work for me:
Old Mar 10, 2013, 03:03 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Great diagram....and yes that position will work!
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Mar 10, 2013, 08:38 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
I had a IBEC on my ignition in my 30% Edge. It was simple. IBEC goes to the RX and I ran a Single A123 2500 mah LIFE battery. I loved it. It had its own kill switch integrated.
Old Mar 13, 2013, 09:48 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
I'd like to keep the receiver battery. My plan would be to run each set of wires down its own side of the fuselage with the only connection a fibre optic link between the ignition cutoff tx and rx... like so:
Old Mar 13, 2013, 11:44 AM
tower flyer is offline
Find More Posts by tower flyer
USA, AR, Austin
Joined Jun 2009
Looks like it well work. I needed a little weight behind the CG , nose heavy, so I stacked Rx and Ing batteries behind servo tray in my big stik.
tower flyer is offline Find More Posts by tower flyer
Sold Tenergy 2000mah NIMH Ignition/Receiver battery packs New Green Fuel Boy Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 27, 2013 08:10 PM
Discussion DA-50 Ignition Battery Recommendations ognolman Giant Scale Airplanes 4 Jan 23, 2013 12:13 PM
Discussion First Gasser - Battery Questions (Ignition/Receiver/Servo) ryanbe15 Fuel Plane Talk 20 Jan 22, 2013 10:17 PM
Sold *SUPER CLEAN* Zenoah G-62 w/Ignition, Muffler & Mount...$174.68 SHIPPED2U! bighank13 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 08, 2013 02:45 PM
BEC and Receiver Battery together? rswenson Electric Plane Talk 5 May 30, 2001 10:00 AM
