Espritmodel.com Heli Air
Old Mar 09, 2013, 08:02 PM
Ivan Dubrov
United States, CA, San Mateo
Joined May 2009
Mountain Models J-3 Cub Build
Finally I got my MM J-3 Cub shipped and delivered!
This would be my second-and-a-half balsa build (first one is House of Balsa Acro Cub 52", first-and-a-half is PuddleBug from Stevens Aero). I will build two wings for it, regular and clipped.
I want it to be a replacement for my HOB Cub which isn't perfect (well, I guess, this one would not be either!).
I plan to put the following electronics into it:
  • HS-5045HB servos for tail and ailerons (want to play with digital servos).
  • Scorpion SII-2205-1900 motor
  • CastleCreations Thunderbird 18 ESC
  • AR600 DSM2 receiver
  • 2S 1300mAh LiPo
I will cover it with AeroFILM (I want more opaque colors).
WFrag is offline Find More Posts by WFrag
Old Mar 09, 2013, 08:11 PM
Ivan Dubrov
Joined May 2009
Now some building stuff!
Well, it turned out that self-jigging puzzle-style technology works really well. I took me about 6 hours total to glue all balsa parts together, hence only one photo at the end. However, you still have to check everything is straight. I made few mistakes (did not notice that part was bent by tension), so had to make few adjustments.
Comparing with my HOB kit building experience I found the following pluses and minuses:
Pluses:
  • Builds very quickly
  • Easier to build straight and square
  • With CA glue you don't have to spend 30 minutes to invent a jig for keeping parts together while glue is setting up.
  • Broken balsa parts are easy to repair — just drop thin CA into it.
Minuses (so far):
  • I find documentation slightly weaker than HOB one
Overall, I have very good impression of the kit so far.
I can't evaluate balsa quality due to lack of experience, but it seems to be fine so far. One part (1/32" balsa) was broken, but it was easy to repair. Laser cuts are good, parts fell off after little bit of flexing the sheet. No over-burnt parts.
Documentation is pretty clear, however it is not ideal. It is sad (to me) how few tiny things make kit less perfect than it could be. Like two parts named the same. Or parts that do not have names at all and you should guess which one you need (true, it is not a toy for 3-year old kids, but I like to have extra confidence while building). Or images I can't see the details in (or even missing the part it supposed to display!).
Old Mar 09, 2013, 11:14 PM
Ivan Dubrov
Joined May 2009
Landing gear waiting for epoxy to cure. Was not too hard to assemble them, but required some patience. Easy to bend in a slightly offset location. Also 1/16" wires are quite hard to cut without special tools, too.
Old Mar 09, 2013, 11:18 PM
Ivan Dubrov
Joined May 2009
Tried fillets blocks fit and found they are slightly smaller than former in front of them (F11). Also, the smaller fillet block have is wider than other two for some reason.
Does that mean I did something wrong or I simply need bigger blocks from scrap balsa? Need to check instruction and plan carefully...
Old Mar 10, 2013, 06:34 PM
Visitor from Reality
United States, IL, Chicago
Joined Dec 1996
Bit of a guess here, and maybe only useful if those fillet blocks are not glued in place. The middle block - take it out, turn it 180 degrees end for end and re- place with it's top front edge lifted up where you can start to shape it. The slope on the end that's at the rear now suggests this, as that slope looks to match that end for end swap.
Hope that helps
D
Dereck is offline Find More Posts by Dereck
Old Mar 10, 2013, 09:29 PM
Ivan Dubrov
Joined May 2009
I don't know what was wrong with the filler blocks. Everything seem to match the plans. I added piece of scrap balsa to them.
Now to the fun part — covering! I decided to cover tail feathers before assembling the wing. Fuselage will be covered after the wing, as suggested in the instructions.
It took me about two hours to cover one of the simplest parts — stabilizer. Even little shrinking of Solarfilm warps the part. After multiple tries to make it straight, it is still not ideally straight, covering is not super-tight, but should be good enough.
Old Mar 16, 2013, 11:15 AM
Ivan Dubrov
Joined May 2009
After few evenings of work tail surfaces are covered. This time I won't make mistake and cover it in "Cub Yellow", as the previous one! Also, for this build I am not using trim covering.
I added two triangles to both sides of rudder to reinforce area where tail wheel is attached, there is a visible bump in covering in that area.
I am happy with SolarFilm so far, although I can't say it is absolutely superior to Monokote (which I used in my first build).
Old Mar 16, 2013, 12:13 PM
Southern California
Joined Feb 2003
Nice progress! Keep the pics coming.
I built one of these a couple of years ago (clipped-wing version) and they fly amazingly well. Unfortunately, I lost it in a dramatic mid-air that crumpled the fuse back to about mid-cabin! The battery plank/hatch design is really nice...the twin hatches make it super easy to position the battery. For that piano wire, I recommend linesman pliers...cheap at Harbor Freight, and they'll go through 1/16 wire without even breathing hard.
--Doug
dk944s2 is offline Find More Posts by dk944s2
Old Mar 16, 2013, 08:32 PM
Ivan Dubrov
Joined May 2009
Thanks!
Today I managed to assemble the whole wing! This kit assembles really quick. Seems like the major part of the build is actually sanding and covering.
On the first picture, wing is assembled without a single drop of glue! I can't tell if I like this technology or not. It builds quick and straightens itself, but all these small parts and tabs are really fragile! I broke few of them.
Also, it seems like dihedral is not 100% symmetric. Not much, but still. I will try to fix this with covering.
Old Mar 16, 2013, 09:52 PM
Joker 53150's Avatar
United States, WI, Muskego
Joined Sep 2012
I've built the MM Lucky ACE and Switchback and the Lucky ACE is exactly like you describe above. The Switchback needed a little extra work to make sure it was aligned properly before gluing, but nothing compared to a Chinese "kit" I recently built. If you simply enjoy creating a quality finished balsa model then certain MM kits like this are a great choice. For those who like to problem-solve and really put some effort into it there are better choices.
I, however, love how well they go together.
Joker 53150 is offline Find More Posts by Joker 53150
Build Log Mountain Models J-3 Cub -- Beta Build buzzltyr Parkflyers 650 May 26, 2013 05:45 AM
Trade World models ARF J-3 cub w/ excell OS .40LA dankar04 Want To Trade 0 Jan 12, 2013 03:19 PM
Discussion Mountain Models J-3 Cub released buzzltyr Scale Electric Planes 12 May 28, 2009 01:06 PM
Sold NIB Mountain Models J-3 Cub with Callie Graphics ClipperBill Aircraft - Electric - Airplanes (FS/W) 1 Oct 18, 2007 03:48 PM
New Product New Mountain Models 1/9 Scale J-3 Cub (48") Mountain Models Product Announcements 0 Nov 30, 2006 08:21 PM
