Mar 09, 2013, 03:31 PM
Space Coast
Joined Oct 2000
A quick look at the HK discussion on this item's product page showed some problems.
For example, check the posts following this one. Look for it by date, I've x'd out his name.
xxxxxxxxxxxx 73 points - 7/22/2012
Ok, so I figured out why these things love to burn out. Other than the fact that there cheap, if you open the case and take out the threaded rod that turns the trunion, check that the trunion moves freely. I had four in a row burn out because the holes on either side, that you put the set screws in, we're too tight. I took a rat tail file and reamed it out just a couple strokes. Don't go too much or you will get side slop.havent burned one out since. I would check them if I were you.
