Old Mar 09, 2013, 11:43 AM
vernon7026 is offline
Find More Posts by vernon7026
Return of the Warlord
vernon7026's Avatar
United Kingdom, England, Wallington
Joined Aug 2009
c & g of a genesis cat
does any body know what c&g of a genesis cat is.
Thank you
vernon7026 is offline Find More Posts by vernon7026
Old Mar 09, 2013, 11:45 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
I would bet on a typing mistake from cog (center of gravity)...
CornelP is offline Find More Posts by CornelP
Old Mar 09, 2013, 12:21 PM
vernon7026's Avatar
Joined Aug 2009
Oops
lol, meant COG
Old Mar 09, 2013, 03:38 PM
zozer is offline
Find More Posts by zozer
Steps? What steps?
zozer's Avatar
United States, TX, Humble
Joined Jan 2010
Terminology aside it will depend on the boat's weight, prop and speed. Start with the CG 32% forward measured from the sponson transoms - not from the extreme rear of the boat.
zozer is offline Find More Posts by zozer
Old Mar 11, 2013, 09:26 PM
sundogz is online now
Find More Posts by sundogz
Platinum Card Member
sundogz's Avatar
United States, AR
Joined Sep 2007
That works out to be 13-1/4" from the very back of the boat (transom).
sundogz is online now Find More Posts by sundogz
Old Mar 12, 2013, 08:59 PM
zozer is offline
Steps? What steps?
zozer's Avatar
Joined Jan 2010
Okay I guess a terminology lesson is in order, but maybe not. "The very back of the boat" is not the transom. The Genesis hull has an overhang for the rudder mount - the sponson transoms are at least four inches ahead of the "very back of the boat". See the photo below.
Old Mar 17, 2013, 09:08 PM
almaidah is offline
Find More Posts by almaidah
United States, OK, Lawton
Joined Sep 2011
so how would you set your batteries do you center them on the 13 1/4 line or do you set them in front of your line or behind your cog line?
almaidah is offline Find More Posts by almaidah
Old Mar 18, 2013, 01:30 AM
mozzyrocks is offline
Find More Posts by mozzyrocks
Australia, VIC, Blackburn North
Joined Feb 2011
I have a Genesis & never bothered working this out.
I went to the lake ran the boat then brought it in & adjusted the battery position to suit.
Here is the result..........
First run of Genesis after rebuild (0 min 0 sec)
mozzyrocks is offline Find More Posts by mozzyrocks
Old Mar 28, 2013, 10:06 PM
sundogz's Avatar
United States, AR
Joined Sep 2007
Mark the hull (both sides of hatch opening) at 13-1/4" from back. Put batteries in, lift hull at the marks, see which way you need to relocate batteries to get it to balance level. This is a good starting point, you'll be close.
Old Sep 30, 2014, 05:23 PM
Fidelity101 is offline
Find More Posts by Fidelity101
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
So 13.25" from back of boat or start of sponsons?
Fidelity101 is offline Find More Posts by Fidelity101
Old Sep 30, 2014, 08:42 PM
sundogz's Avatar
United States, AR
Joined Sep 2007
The very back of the boat (transom).
Old Oct 04, 2014, 10:07 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I believe Bill runs his cats at about 38% cog from transom. Seems to keep them planted and not so flighty.
scorpion1 is offline Find More Posts by scorpion1
Old Oct 04, 2014, 12:09 PM
Go fast, pull up.
Joined Nov 2008
Mine is hopping along in the water at full throttle and I cannot make it stop. It runs great at half throttle
Genesis (0 min 15 sec)
Old Oct 04, 2014, 03:42 PM
sundogz's Avatar
United States, AR
Joined Sep 2007
Looks like you either need to move the center of gravity forward some and/or adjust the strut. The bottom of the strut should be parallel and level to the bottom of the sponsons (lay it on a table to see this).
Old Oct 04, 2014, 04:02 PM
Go fast, pull up.
Joined Nov 2008
Thank you Sundog. That is where I started with the strut and I have since tried raising it another one eighth of an inch. I have moved the batteries all the way forward and then all of the way back and it doesn't seem to make any difference regarding the hopping in the water… Maybe the batteries do not weigh enough to make a difference
Sold Zenoah G-62 r/c ignitions conversion $200 shipped sagomon Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 05, 2013 10:06 AM
Yippee! Genesis Cat & Saga Cat Vids F1 madness Racing Boats - Electric 50 Mar 02, 2011 11:57 AM
Discussion Genesis cat or Apparition now future project fighter cat Shannon87 Racing Boats - Electric 47 Feb 21, 2011 10:57 PM
Discussion Aristo-cat C.G. question coosbaylumber Modeling Science 3 Aug 16, 2008 03:01 PM
Help! Quiet & Electric Flight Pushy Cat C.G.????? superscott Pusher Prop Jet Models 2 Jul 12, 2007 02:31 PM
