Old Mar 09, 2013, 10:52 AM
pfindeis is offline
Find More Posts by pfindeis
United States, NY, Dexter
Joined Sep 2009
Question
sf501 nitro to brushless gear ratio ?
Going to convert a sf501 nitro to brushless.
Have a thunder power 13.5 sensored motor and a lrp sphere tc esc.
Probably go with 48 pitch gears.
What would be a starting gear ratio / size 48p pinion and spur?
pfindeis is offline Find More Posts by pfindeis
Old Mar 09, 2013, 01:58 PM
z_dad is offline
Find More Posts by z_dad
Kungsangen, Stockholm, Sweden
z_dad's Avatar
Sweden, Upplands-Bro Municipality
Joined Dec 2011
The original primary gearing (motor gear to first) for the SB5 is 21/87, it makes 4,1429 motor revolutions per layshaft revolution.
As long as you have secondary gearing (front chain pulley to rear) fixed to 2,5 (20/50, original sb5) you will end up whith a final ratio at 10,537. This seems to a be very good start for motors 4500-6000kv.
In clear terms: 87/21x50/20 = 4,1429 x 2,5= 10,357
Put in the relevant nubers for your bike to reach the final gearing.
I wouldn't go under 9 total, unless you know your electrics well. Higher than 10,5 makes for less top speed unless you have a very high kv rating.
Hope this helps for starters.
z_dad is offline Find More Posts by z_dad
Old Mar 09, 2013, 02:23 PM
pfindeis is offline
Joined Sep 2009
Yeah i don't understand that math. Sure is a lot easier with online car gearing charts.
Maybe i should reword my post to what size 48p pinion and spur
Thanks though
Old Mar 09, 2013, 05:44 PM
dragbikebam is online now
Find More Posts by dragbikebam
dragbikebam's Avatar
Memphis, TN USA
Joined Apr 2009
you can run the HPI or X-ray 48p spur from 84 to 96. I prefer 90 to 93 with a 22 to 26 pinion. With a 13.5 I would go with a 90/26 to start then go to a 28 pinion if you want more top end..
dragbikebam is online now Find More Posts by dragbikebam
Old Mar 09, 2013, 05:53 PM
pfindeis is offline
Joined Sep 2009
Hey thanks alot
Discussion Gear ratio recomendations needed erikdravn Off-road Cars 1 Feb 28, 2013 08:20 PM
Sold F5D - NEU Motor 1512-1.5D/6.7/1 Gear Ratio Jaguar22 Aircraft - Electric - Power Systems (FS/W) 2 Jan 18, 2013 07:20 PM
Discussion Anyone know the gear ratio on Parkzone P-51 UM? JT2 Electric Plane Talk 1 Jan 09, 2013 11:59 PM
Discussion Anyone here with a brushless converted Nitro NF SF501 ? saucisse Motorcycles 2 Feb 11, 2009 10:03 PM
Discussion Gear ratio calculation on sf501? Junglemaxx Motorcycles 4 Mar 04, 2007 10:27 AM
