Old Mar 09, 2013, 03:22 AM
eligri is offline
Find More Posts by eligri
Joined Sep 2012
Help!
HBX Xmissile wierd noise
Hi,
I bought a used HBX Xmissile and it ran great. One day when I was out driving, it got stuck on something and stopped moving. I heard the motor make noise, but the car couldn't move.
It now runs after a new mothergear (the big gear after the motor pinion?) and I tightened the motor (I can fit a piece of paper between the gears).
But there is still one problem: It sometimes makes this nasty noise when accelerating (grinding/screeching noise) and when I go back/forth quickly it makes a clicking/grinding noise.
Sorry if I misspelled something.
Please help me
Ps. Set the last thread to discussion, it has been closed.
eligri is offline Find More Posts by eligri
Old Mar 09, 2013, 07:11 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The big gear is known as a spur gear, was the old one damaged? Can you wobble it around at all? It sounds like another gear (possibly in one of the differentials) is damaged, or the bearing/bushing supporting one is worn.
wparsons is offline Find More Posts by wparsons
Old Mar 09, 2013, 08:31 AM
eligri is offline
Joined Sep 2012
I can wobble the spur gear alittle, is that bad? The old gear was quite worn down, but it is now replaced. The spur gear is plastic and the pinion is metal.
Is there any easy way to check if the differentials are damaged without ripping them apart?
Kinda new to rc:ing, so opening stuff upp takes lots of time
Thanks for replying!
Old Mar 09, 2013, 12:13 PM
eligri is offline
Joined Sep 2012
Also, the wooble isn't because it's bent, it's because the spur gear is alittle loose (actually its the rod going from fwd to the bwd thats loose).
Old Mar 09, 2013, 02:42 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Does it slide in/out, or can it slide closer or further from the pinion gear (gear on the motor)?
Old Mar 09, 2013, 03:03 PM
eligri is offline
Joined Sep 2012
I think it only wobbles (not back-->forth, side-->side)
Help! HBX Wildfire- first Nitro Rc angermgnt Off-road Cars 5 Feb 11, 2013 07:48 PM
Help! 9958 saga and wierdness musechaserpilot Beginner Training Area (Heli-Electric) 2 Jan 29, 2013 01:16 AM
Help! Wierd 0s 91 carb issue Co.Rcflyer Engines 17 Jan 15, 2013 02:34 PM
Discussion HK la noi acasa renatoa Romania 2 Jun 17, 2011 07:45 AM
Discussion Noi more Red baron squardon(sp) gouda Life, The Universe, and Politics 8 Dec 05, 2007 02:17 PM
