Joined Feb 2013
It will be nice not to have to hack holes in the cowl for the head. I haven't got my pitts muffler yet, but it looks like I won't have to cut the cowling for the exhaust either. There is already a cutout in the firewall, and I think the exhaust pipes will go through it and exit the bottom of the fuse. The way it looks, the only two holes in the cowl will be one for the glow plug access and one for the extended carb adjust needle. Pretty cool. By tomorrow I will have some photos of the engine mounted. Right now, I am delighted with the start. |
United States, FL, Largo
Joined Feb 2006
Nice. It looks like any 4 stroke would require some modifications, new cowl, etc. to fit right. I don't think they still make 2 liter soda bottles that have that profile on the bottom. I think they are all star shaped. Trying to think if a new, extended cowling had to be made how it could be done.
Joined Feb 2013
Out of curiosity, I checked some plastic one gallon jugs and found every one of them to be smaller in diameter than the kit cowl. Were one of the proper size available it would be straightforward to make an extension. In fact it could be done by making the extension by cutting a ring from the plastic jug, making a cut in it so the extension might have a small gap in it (put the gap on the bottom of the aircraft) then fortifying with glass and cloth. Too late for me though, I already epoxied the mounting ring to the cowl. |
Joined Feb 2013
Next Step: Tail Feathers
The issue with the pitts muffler was delightfully easy to cure. I just cut a 1/8" rectangle (outlined in with marker in the photo), and the Bisson muffler installed perfectly. Did need to drill a hole for the pressure tube from the muffler, but it was a snap.
Joined Feb 2013
A few more shots of the Beaver in progress. The faux radial is taped in place and being glued with silicon adhesive. The side shot shows the location of the fueling valve and cowl hole for glow-plug igniter. Cockpit shots show installed servos (only throttle connected in the views) and aft end of fuel tank.
| Thread Tools | |
| Sold Flyzone DHC-2 Beaver | jbynum1631 | Aircraft - Electric - Airplanes (FS/W) | 6 | Feb 06, 2013 09:28 PM |
| For Sale Flyzone DHC-2 Beaver | jbynum1631 | Aircraft - Electric - Airplanes (FS/W) | 9 | Jan 20, 2013 09:27 PM |
| For Sale Flyzone DHC-2 Beaver | jbynum1631 | Aircraft - Electric - Airplanes (FS/W) | 1 | Jan 11, 2013 07:32 PM |
| Discussion Hobbyking DHC-2 Beaver (Bush Plane) ARF | CrashingDutchman | Parkflyers | 77 | Sep 16, 2010 11:22 AM |
| Discussion DHC-2 Beaver (Bush Plane) STOL EP ARF from Hobbyking | maestros | Scale Electric Planes | 4 | Apr 27, 2010 03:17 PM |
