Old Mar 08, 2013, 11:57 AM
dusty14 is offline
Find More Posts by dusty14
United States, NY, Rochester
Joined May 2008
PL6 and/or CP10 1s charge adapters
Hi,
I have a PL6 and a CP10 which I want to use to charge multiple 1s batteries. Probably the CP10 while the PL6 is doing larger batteries. I am tired of all of the little wall wart charges and doing one at a time. Was wondering which would be better on the the CP10 to do parallel or serial and depending on the answer would these work. I am thinking serial as they will all get balanced but I am open to other options.
Serial cable
http://www.ebay.com/itm/Charge-3-1S-...item45fc06887d
Parallel cable (different ends than above I would need the jst to walker adapters)
http://www.progressiverc.com/paralle...rge-cable.html
Keith
dusty14 is offline Find More Posts by dusty14
Old Mar 08, 2013, 01:58 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Parallel. If the pack's state of charge is very different the charger may trigger safety charge. Also in serial you HAVE to populate all of the connectors. In parallel, only charge what you need. See the sticky at the top of this page for more information about 1s and the Powerlabs.
Gregor99 is offline Find More Posts by Gregor99
Old Mar 08, 2013, 02:42 PM
dusty14 is offline
Joined May 2008
Thanks Gregor.
Going with the parallel JST I will also have to get a balance connector to wire into the banana plugs since neither the PL6 or CP10 can just charge through the banana plugs.
Or am I missing something?
Old Mar 08, 2013, 02:51 PM
Gregor99 is offline
Seattle
Joined Sep 2007
The CP10 can charge through the balance leads. But charge rate is limited. Adding a balance cable to a parallel charge cable is all that is needed. You could add both the 9pin and the 6pin so the same cable could be used with either charger. Its little more messy, but its more flexible. Your call.
Old Mar 08, 2013, 03:05 PM
dusty14 is offline
Joined May 2008
I will probably never use it on the PL6 but I might as well put the 9-pin on too just in case something happens to the 10S.
Thanks again.
Old Mar 13, 2013, 02:36 PM
dusty14 is offline
Joined May 2008
Had a couple of extension cables from my old Cellpro 4S that I used the connectors from and soldered the black and red wires to the banana plugs on a parallel battery cable. Works perfectly on the 10S (with the 5 pin to 4 pin adapter) and on the old Cellpro 4S. Now I can get rid of all the wall warts I in my power strip.
Thanks again Gregor.
Discussion Parallel charging/storing 1S on PL6 jtaylor996 Batteries and Chargers 7 Oct 26, 2012 08:19 PM
Wanted Charge adapters to charge 1s 200mah Eflite batteries in parallel MolokaiBoy Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 15, 2012 09:36 PM
Discussion Charging 1S packs using new PL6 and MPA mstlc03 FMA Direct 14 Mar 12, 2012 07:12 PM
For Sale GForce 1s 160 mah lipo for eflight and charge cord adapter bbrown2828 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 06, 2012 11:39 PM
Sold 5x 1S lipo and multi-charge adapter alextronique Aircraft - Electric - Batteries & Chargers (FS/W) 5 Sep 05, 2010 12:00 PM
