Old Mar 08, 2013, 08:41 AM
jchtr3a is offline
Find More Posts by jchtr3a
Warbird Fanatic
jchtr3a's Avatar
United States, PA, Coraopolis
Joined Jun 2012
Help!
Split Flaps
I'm installing split flaps on a foam wing. I'd rather have them flush with the wing, not just laying on top. What is the best method to rout out the depth of the flap in the foam? I'm thinking of using a dremel, but I'm unsure of a bit to use, or how smooth the surface will be after routing. Any help or ideas?
jchtr3a is offline Find More Posts by jchtr3a
Old Mar 08, 2013, 09:19 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
I have taken flat sheet aluminum, taped it to the wing, folded the short side over a piece of piano wire (before tapeing to the wing), and ran that back into the fuselage through an aluminum tube, i.e., torque rod. More difficult to explain than do.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Mar 08, 2013, 05:44 PM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
Is the foam sheeted with balsa? If so, just take a soldering iron and carefully melt foam away. Then line the cavity with balsa and build up the flaps, etc.
ARUP is offline Find More Posts by ARUP
Old Mar 08, 2013, 07:10 PM
jchtr3a is offline
Warbird Fanatic
jchtr3a's Avatar
Joined Jun 2012
Possible solution
The wings are all foam. I saw a video where a guy used a dremel with a tile cutting bit to rout out that portion of the trailing edge to just the depth of the flap he was using. (a paint stirer stick I believe). When done the flap closed level/flush with the surface of the wing on the bottom. He made a nice job of it, and the routed portion was nice and smooth, so when the flaps were down, and that upper portion was painted, it looked really nice. Unless I can think of or get a better idea, I think that is the way I will go.
Thanks.
Old Mar 09, 2013, 11:28 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Thanks.
I can vouch for the tile cutter.nice clean finish.
Stuart A is offline Find More Posts by Stuart A
Old Mar 09, 2013, 02:02 PM
jchtr3a is offline
Warbird Fanatic
jchtr3a's Avatar
Joined Jun 2012
Me Too!
Went and got the tile cutter bit--lucky they had it. Just routed out the spots for the flaps---smooth and nice. Paint sticks cut to size and fit like a glove. Now to get some hinges. I have a few HK (4) hatch type hinges that I think will work well, and look the part. Now to rout the spots for the servos.
Need an opinion----I could use a servo reverser on one, or I could just mount them in the same direction. Aesthetically I should use the reverser, but once I tape them over and paint the tape and other horns and clevises they will be all but invisible. Thoughts?
Old Mar 10, 2013, 12:45 PM
metalguy is offline
Find More Posts by metalguy
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
If you can solder, you can just reverse one of the servos. Better to Youtube the instruction. I did it on a Stuka I put together, and it works very well. No reverser required, and they end up like bookends ------Metalguy
metalguy is offline Find More Posts by metalguy
Old Mar 10, 2013, 03:40 PM
jchtr3a is offline
Warbird Fanatic
jchtr3a's Avatar
Joined Jun 2012
Old Eyes
A while back I tried doing that to a couple of old cheapo servos I got from Ebay. Did OK until I had to see the tiny little spots where the wires had to be soldered. My 63 year old eyes just aren't good enough. Bodged them both, so I have given that part of my model building up. I can solder pretty good, but tiny bits are out. Thanks for the suggestion.
Old Mar 10, 2013, 06:25 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
I can relate to that.
Discussion flaps or split flaps on 1100mm XPS FW190 makind Foamies (Scratchbuilt) 0 Nov 11, 2012 04:54 AM
Discussion How to actuate a split flap? Vantasstic The Builders Workshop 3 May 24, 2006 10:05 PM
Split Flaps vs Barn Door Flaps Kevin Murray Electric Plane Talk 7 Nov 10, 2003 06:43 PM
Split flaps for DS plane? bjaffee Dynamic Soaring 16 Jul 09, 2003 12:30 AM
HL Spitfire split flap size and hinge help needed KillerWatt Foamies (Kits) 2 Jun 11, 2002 12:04 AM
