Old Mar 08, 2013, 08:48 AM
flyer100 is offline
Find More Posts by flyer100
Joined Mar 2013
Help!
No LED on Eagle Tree Guardian
Has anyone had this problem? Updated to version 1.7 and LED working when connected to the computer but not now it,s installed in the plane. It operates the control surfaces while on the bench but am reluctant to fly it if there is a problem.
Any help appreciated.
Thanks.
flyer100 is offline Find More Posts by flyer100
Old Mar 08, 2013, 01:06 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, if the LED is not doing anything, this normally indicates that the unit is in "NO STABILIZATION" mode. This will happen if a 3 position switch is controlling the mode of the unit, and the switch is in the middle position. Does this explain it?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Mar 08, 2013, 02:10 PM
flyer100 is offline
Joined Mar 2013
Thanks for your reply.It is controlled by a 3 position switch with centre position disabled but there is no LED in any switch position.
Old Mar 09, 2013, 12:17 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hmm. We know the LED is physically working since it blinks correctly when plugged into USB. To confirm, is the behavior you are seeing different when the switch is moved to different positions (i.e., is it stabilizing 2D in one position, 3D in another, etc.)? If not, I am wondering whether the receiver channel is not correctly mapped to the switch, or if the mode switch cable has failed?
Site Sponsor
Old Mar 11, 2013, 03:11 PM
flyer100 is offline
Joined Mar 2013
Disconnected & Reconnected the unit and it is now working as it should (hopefully).
Will fly it in the day or so.
Many thanks,
Paul.
Discussion Eagle Tree Guardian vs. Spekrum AR635 AS3X Wild Bill Radios 16 Aug 07, 2014 03:50 PM
Discussion eagle tree guardian bushpilot05 Radios 2 Feb 24, 2013 03:04 PM
Help! eagle tree guardian bushpilot05 Flight Accessories 1 Feb 22, 2013 12:37 PM
Sold Eagle Tree Guardian 2D/3D stabilizer rickfe101 Aircraft - General - Miscellaneous (FS/W) 0 Feb 12, 2013 12:52 PM
Discussion easystar + osd eagle tree + guardian xipho3 FPV Equipment 1 Jan 04, 2013 11:40 AM
