Old Mar 08, 2013, 04:51 AM
RotorTalk is offline
Find More Posts by RotorTalk
Joined Mar 2012
Beware LiPo Parallel Charging Boards - fire!!
I was charging 2 x 5000 mAh 50C Turnigy's (each of which was identical in charge state, cell voltages and type/model) with one of these boards using an iCharger 3010B. I smelled burning so disconnected everything and opened up the parallel board. I couldn't believe what I saw:
1.) BLOWN CELL BALANCE TRACK
2.) DRY SOLDER JOINT ON NEGATIVE MAIN
3.) SOLDERING BY MONKEYS:
These are rated at 30Amps but what about the cell balance tracks? - what are they rated at? (or what is assumed by the manufacturer?)
RotorTalk is offline Find More Posts by RotorTalk
Old Mar 08, 2013, 05:16 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
That's why you should be using the FMA MPA board. Every thing is protected by fuses.
http://www.usastore.revolectrix.com/Products_2/MPA_2
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Mar 08, 2013, 07:16 AM
LeSquale is offline
Find More Posts by LeSquale
Switzerland
Joined Feb 2008
That's a pity, but on the other hand for 9$ or so, what did you expected? A Rolls Royce?
The FMA board is around 50$ and I think there is a reason to this. I ordered one 2 days ago, be careful because it doesn't come with the balacing cable to connect the charger to, which must be purchased separately.
LeSquale is offline Find More Posts by LeSquale
Old Mar 08, 2013, 08:42 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
The balance traces are rated for something like 3A typically I think, maybe even only 2A.
grimbeaver is offline Find More Posts by grimbeaver
Old Mar 08, 2013, 09:00 AM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
4A constant with a much higher burst.
Having looked at the board design closer, nice pictures, I can say this board is definately NOT rated at 30A. They should have installed a hard wire along the full lengh of the + and - shown in pictures #2 and 3.
What happened is you were pumping high amps into your packs and these traces got hot, so hot in fact that the Red and Black wires melted off the PCB.
This is a prime example of cheap Chinese knock-off's. They can copy but they do NOT understand everything that went into the original design, a design that everydayflyer originally advised to have this area beefed up to handle up to 30 amps.
What to do? You can easily fix the small burned trace to the balance connectors. Just use a single strand or more of wire from an old balance tap or... and solder it in a daisychain to each connector the trace is burned to. Simple. Done.
The larger traces should have a 16ga wire run the full lengh of this board for the + and - and solder flowed very thickly through the full length of these wires. Then, IMO, strip the insulation back another 1/8" and solder the red and black wires to this trace area, not the connector area, for a more hardy connection.
Rick
rampman is offline Find More Posts by rampman
Last edited by rampman; Mar 08, 2013 at 09:12 AM. Reason: Added more detail after looking closely at picturs
Old Mar 08, 2013, 09:46 AM
United States, MN
Joined Feb 2011
I don't think I've ever seen wire run the lenght. This review has a photo of the front/back of the current gen board from EPBuddy:
https://sites.google.com/site/tjingu...board-micro-v3
Old Mar 08, 2013, 09:55 AM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
It looks like a newbie to soldering made that one, scary! Another good fused board comes from EPBuddy. The Chinese are masters at copying. I have about a dozen watches I bought in Shenzhen that look amazing but only ran for a few weeks..
Harry
Harry H is offline Find More Posts by Harry H
Old Mar 08, 2013, 09:56 AM
Wrice4 is offline
Find More Posts by Wrice4
Blacked out 350z - Texas
Wrice4's Avatar
Joined Nov 2012
Thanks for this post, I have the same parallel board and I will watch mine even closer now when charging 2X5000mah batteries.
Wrice4 is offline Find More Posts by Wrice4
Old Mar 08, 2013, 10:05 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
If Asian factories are trying to use lead-free solder, crappy solder joints are not surprising. Use only "leaded" type 60/40 rosin core solder for home soldering.
E-Challenged is offline Find More Posts by E-Challenged
Old Mar 08, 2013, 10:17 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Garbage In = Garbage Out. You get what you pay for. Buy cheap buy twice.
Ohmic is offline Find More Posts by Ohmic
Old Mar 08, 2013, 11:01 AM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
+1!
Or, buy cheap and then spend some time correcting soldering errors.
This sort of crappy workmanship is systemic to many Asian manufacturers that have zero quality control. For many of these manufacturers, QC is at point of use.
Even more troubling are some of the solder connections on lipoly connectors that I have seen. I've witnessed some solder joints that were so bad that they would most assuredly reflow and open when under a heavy current load. Since I am a crimped APP guy, this is of little concern to me personally but I always recommend that all users remove and resolder all connections that cannot be visually inspected.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Mar 08, 2013, 11:16 AM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Who was that board from? HK? I've been looking at the newer fuse protected model from EPBuddy myself....
-K
kad is offline Find More Posts by kad
Old Mar 08, 2013, 11:52 AM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Who's board is this? If it is not an EP Buddy, then it is a damn good copy of one from the outside. Opening mine up tonight (gen-u-wine EP) to see what they look like.
TTRotary is offline Find More Posts by TTRotary
Old Mar 08, 2013, 12:14 PM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Originally Posted by grimbeaver View Post
I don't think I've ever seen wire run the lenght...
Correct but I don't think he can manufacture a daughterboard PCB like my EP Buddy board in order to triple up on surface area so his best option is to do as I wrote, or, actually replace it entirely with a better quailty board.
Rick
Old Mar 08, 2013, 03:42 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Did you smell burning shortly after connecting the packs, or after the charge cycle has started?
Gregor99 is offline Find More Posts by Gregor99
Sold Misc cleaning, digital tac, lipo charging bag, Air tool , parallel charge cable etc.. Ifly101 Non R/C Items (FS/W) 0 Feb 24, 2013 04:00 PM
Wanted XT-60 parallel charging board Brian VT Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 19, 2013 05:18 PM
Discussion Charging 2 lipos in parallel on one charger cloud_9 Batteries and Chargers 23 Feb 04, 2013 06:54 PM
Question Parallel Charging E-Flite 1C Lipo's thannamhbfp Batteries and Chargers 9 Jan 26, 2013 08:26 AM
Sold Parallel Charge Board for JST-XH, EC3 benaresenferno Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 23, 2013 12:46 PM
