Old Mar 08, 2013, 04:42 AM
hack_1979 is offline
Find More Posts by hack_1979
Australia
Joined Jul 2011
Crank too long?
This might sound like a stupid question, but here goes!
I've got an OS91 and the threaded end of the crank shaft is too long to fit the spinner combination I want to use. Has anyone trimmed/shortened their crank shaft?
I can see a dremel with cutting disc would provide a neat cut.
Am I being stupid???
Cheers
Hack
hack_1979 is offline Find More Posts by hack_1979
Old Mar 08, 2013, 05:01 AM
Taurus Flyer is online now
Find More Posts by Taurus Flyer
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
Afraid to Hack?
Modify the spinner in the first place!
Taurus Flyer is online now Find More Posts by Taurus Flyer
Old Mar 08, 2013, 05:09 AM
Brutus1967 is online now
Find More Posts by Brutus1967
The Netherlands
Joined Nov 2009
Cheers
Hack
With that engine and a normal prop, usually the threaded end of the crank is protruding less than 5 mm from the nut...
So I have the feeling, your spinnercombination is not suitable for this engine.
I think it is wiser to find a different spinner, in stead of cutting the shaft..
Having said that,, provided you go about it carefully, protect the engine from ingestion of grinding dust, I think it does not really harm the engine if you would shorten the shaft with a Dremel cutting disk. I have done similar jobs without any negative results.
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Mar 08, 2013, 05:56 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That is odd. I would agree with Brutus1967 in that it sounds like the propeller may be too small in pitch or you have too thin of a prop washer or something. Maybe a more thick prop washer or more than one prop washer. Use a prop nut and then use the spinner nut for the spinner.
But people have shortened the crankshaft tip by cutting it off with a dremel cutoff tool before. Do protect the engine from the metal and dust from the cutoff wheel.
earlwb is offline Find More Posts by earlwb
Old Mar 08, 2013, 05:58 AM
Joined Nov 2010
Hack,
I don't know your spinner in detail so in general I see this!
Sometimes drilling a hole can solve the problem.
So show more details please!
Taurus Flyer
Old Mar 08, 2013, 05:59 AM
vic welland is offline
Find More Posts by vic welland
vic welland's Avatar
Valdese NC
Joined May 2004
I would modify the spinner before cutting off the crank.
vic welland is offline Find More Posts by vic welland
Old Mar 08, 2013, 06:32 AM
Joined Nov 2010
To modify a Super Tiger (like) spinner you can extend the threaded hole, if it is a blind nut for example. For this modification the best way to do is using a lathe.
Hack , hack the shaft will reduce the value of the engine!!!
Taurus Flyer
Old Mar 08, 2013, 06:35 AM
surfer_kris is online now
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
I wouldn't touch the crank...
Just put a piece of plywood between the spinner and propdriver.
surfer_kris is online now Find More Posts by surfer_kris
Old Mar 08, 2013, 08:54 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I suspect what his problem is that the special spinner prop nut bottoms out on the crankshaft tip with the spinner, propeller and prop washer he has. What I do is use the engine's prop nut and tighten it all up with it, and then screw on the spinner prop nut and tighten it down. So you have sort of double nutted it then. Usually you wind up having to shorten the screw used to hold the front spinner part on anyway. No big deal cutting a little off with a dremel cut off tool.
Old Mar 08, 2013, 12:05 PM
Valdese NC
Joined May 2004
That's what I thought but didn't want to type that much last night
Old Mar 08, 2013, 09:04 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
Another possibility is he is using both crankshaft nut and the adapter nut. And with that added length, the spinner could be hitting the adapter nut, not the crankshaft. If thats the situation, I would shorten the adapter nut if his engine is a four stroke. And keep using the two piece crankshaft nut. If his OS is a two stroke and the adapter nut is steel, leave off the crankshaft nut and use the adapter nut to tighten the prop.
jjkupinski is offline Find More Posts by jjkupinski
Old Mar 08, 2013, 09:21 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I have gotten creative with using different spinner nuts before. The old classic CB Associates spinner nuts were great for many purposes like this when the regular Tru-Turn or some other spinner nut wasn't quite right. I have had to make them before too, using brass hex rod and drilling and tapping as needed. Where I tapped one end for the crankshaft and the other for the spinner screw.
Old Mar 08, 2013, 09:48 PM
Gooroo is online now
Find More Posts by Gooroo
Joined Sep 2010
"Crank too long?"
(Laughing like Beavis and Butthead) Huh-huh-huh, heh-heh, huh-huh, heh-heh.
Gooroo is online now Find More Posts by Gooroo
Old Mar 09, 2013, 01:19 AM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
I could use a longer crank, myself.
datsunguy is offline Find More Posts by datsunguy
Old Mar 09, 2013, 02:56 AM
The Netherlands
Joined Nov 2009
Originally Posted by Gooroo View Post
"Crank too long?"
Hey Butthead.... huh-huh.... he said "crank".....
Yeh, Hm, heh heh, he said crank, hehe....
Love that show!
Brgds, Bert
Question How long is too long for a free item? pilotavery Trader Talk 15 Mar 07, 2013 07:23 PM
How long is too long for battery wires for Phoenix 60 Xnaron Power Systems 4 May 02, 2011 05:11 PM
Discussion Fuel Shelf Life: How long is Too long? Starguard Fuel Plane Talk 12 May 19, 2006 11:17 AM
the antenna too long...the model is too short... lempert Scale Kit/Scratch Built 7 Apr 15, 2004 04:49 AM
long leads how long is too long? JimF Electric Ducted Fan Jet Talk 2 Jul 08, 2003 01:20 AM
