Old Mar 07, 2013, 03:35 PM
crvarner24 is offline
Find More Posts by crvarner24
Joined Mar 2013
Question
Epoxy Glue
Does anyone know what the best substitution for epoxy glue would be. Over the years I have become allergic to epoxys.
crvarner24 is offline Find More Posts by crvarner24
Old Mar 08, 2013, 06:54 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Assuming that you are gluing wood to wood, Titebond, or similar brands of wood glue, should do the trick for you.
TomCrump is offline Find More Posts by TomCrump
Old Mar 08, 2013, 02:26 PM
Rudy F is offline
Find More Posts by Rudy F
United States, CA, Sacramento
Joined Nov 2004
Glues for wood
Titebond 3 is very, very waterproof after drying like epoxy. Urethanes (gorilla glue)work very well, but stain your fingers and foam alittle, have a shelf life.
Rudy F is offline Find More Posts by Rudy F
Old Mar 08, 2013, 05:12 PM
machinate is offline
Find More Posts by machinate
machinate's Avatar
Joined Jan 2010
Aliphatic wood glues (Titebond II is preferred) are ideal. They're stronger than all but the most exotic woods, clean up with water, and don't generally cause allergic reactions. Use them for anything and everything, including firewalls (but make sure they're well-braced with wood, because aliphatic doesn't make structural fillets like epoxy can).
CA glues are just as sensitizing as epoxies (but a different allergen), and are generally awful to be around unless you get low-odor types. But they're fairly strong and very fast. They're probably also the best substitute for epoxy when you're laying fiberglass wing root reinforcements.
Urethanes like Gorilla Glue are messy and not quite as strong as aliphatics, but they expand to fill reasonable gaps. They also work magnificently on foam.
Those three are pretty much all I use, in order of preference. I also use epoxy, but only very rarely. Most planes I only mix a single batch, for mounting the firewall, and occasionally for potting blind nuts and barbed hinge points. But the firewall can be done with aliphatic, the nuts with CA, and the hinges can be swapped for a different type or installed with thick CA.
machinate is offline Find More Posts by machinate
Discussion Epoxy vs Hot Glue Gun cloud_9 Beginner Training Area (Aircraft-Electric) 24 Jan 16, 2013 05:50 AM
Epoxy -vs- GWS Glue on P51 - Have you noticed this oddity? mrebman Parkflyers 8 Feb 26, 2003 09:01 PM
GWS glue or epoxy for Tiger Moth ? Al P Parkflyers 13 Mar 09, 2002 08:44 PM
Epoxy or white glue ?? GiantScale Foamies (Kits) 2 Mar 01, 2002 09:51 PM
foam glue / epoxy substitute? cenman Foamies (Kits) 7 Jan 20, 2002 04:54 AM
