Old Jul 25, 2001, 01:14 PM
Jamie- is offline
Find More Posts by Jamie-
London, England
Joined Nov 2000
Do I charge in Parallel or in series if I .....
want to charge 2 150 mah nimh packs at the same time?
I'm tlking about Rayovac 9 volts here that are connected in Parallel for flight and I was hoping I could you the same connection to charge the batteries in between flights.
Any thoughts?
Jamie.
Jamie- is offline Find More Posts by Jamie-
Old Jul 25, 2001, 01:20 PM
asperkins is offline
Find More Posts by asperkins
asperkins's Avatar
Arlington, TX, USA
Joined Jun 2001
I'm assuming that these are actually 8.4v or 7 cells.
If you charge them in parallel charge them like a 7 cell 300 mah battery.
If you charge in series then it will look like a 14 cell 150 mah battery.
If your charger will not do 14 cells then just charge them in parallel. Either way should work.
asperkins is offline Find More Posts by asperkins
Old Jul 25, 2001, 01:51 PM
Jamie- is offline
London, England
Joined Nov 2000
Thats great news. I'll do them in Parallel as I only have a 4 - 8 cell charger on the way.
Jamie
Old Jul 25, 2001, 03:40 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Jamie
I hate to disagree but the rule of thumb is to NEVER, NEVER, NEVER charge in parallel. There is just too much that can go wrong. If the packs don't peak at precisely the same time the one that has peaked will suddenly take on most of the charge current and quickly overheat.
Chris True is offline Find More Posts by Chris True
Old Jul 25, 2001, 03:43 PM
Jamie- is offline
London, England
Joined Nov 2000
Good Point......and its been taken. I'll just charge them one at a time!
Jamie
Old Jul 25, 2001, 03:45 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
This is true in theory, but in practice, if the packs are always used together in parallel and always charged together in parallel you are UNLIKELY to get into trouble. Personally, I wouldn't recommend it.
DaveSawers is offline Find More Posts by DaveSawers
Is a 3S2P three 1S2P in series or two 3S1P in parallel? dw1122 Batteries and Chargers 2 Nov 27, 2003 09:45 AM
AXI 28/14/12 two in series or parallel chrisc Power Systems 1 Jul 13, 2002 08:38 PM
Wiring in Parallel or in Series jimmyray Foamies (Kits) 2 Feb 24, 2002 09:05 AM
Motors in Series or parallel kepople Electric Ducted Fan Jet Talk 1 Sep 27, 2001 01:59 AM
Fans in series or parallel hoser Electric Ducted Fan Jet Talk 5 Jun 20, 2001 05:16 PM
