Old Mar 07, 2013, 11:35 AM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Mini-HowTo
Write-up: Carburetor screw adjustment guides
Another mod to my new-to-me 50cc SBach 342. I wanted to have access to the carburetor adjustment screws without removing the cowl. I'd heard of running guides from the screws to the cowl so I thought I'd give it a try.
First, I found some tubing that would work. In my case, the guide sleeve from some 2-56 Sullivan Gold'n'Rod did the trick. Note that this tubing is not intended to rotate the screw, but to guide the screwdriver.
Next step was to make some exit holes in the cowl. There was one there already when I bought the plane so it was a simple matter to make a second.
The grommets that fit the guide tubes had a 19/64" panel mount diameter, so I enlarged both holes to fit.
Grommets in for a test fit.
grosbeak is offline Find More Posts by grosbeak
Old Mar 07, 2013, 11:41 AM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Cool idea! Thanks for sharing.
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: 1/4 scale J-3 by Hangar 9
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Next, I wanted to see where the tubes come to rest on the cowl when it's put on. In this case, just above the access holes.
I cut the tops off the backs of the grommets and epoxied them in place. And yes, it is a little too much epoxy - thanks for noticing!
Now when the cowl is put on I just need a hook to pop the tubes into the grommets.
There they go!
Old Mar 07, 2013, 11:46 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Now it's just a matter of finding a long enough screwdriver.
I didn't want the tubes to vibrate off of the screws, so I added some heat shrink near the tips - first on each tube to ensure the proper gap between them was maintained, then on both to prevent them from sliding out of the cowl.
I did the same thing at the back...
Then added another layer for a better hold.
Old Mar 07, 2013, 11:48 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Through the inside again.
And once again in the grommets, now black to blend in better.
Old Mar 08, 2013, 02:43 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That is nicely done, very sanitary and clean looking too.
You did a bang up nice job on that.
I usually just went cheap and used a large size soda drink straw from our local convenience stores. I would cut the straw down to size as needed and insert it into a hole to the needle valve to serve as a guide. The screw driver had a small length of brass or aluminum tubing epoxied on the tip to serve as a guide for the needle valve too.
Of course, usually once you had the engine adjusted pretty good, you seldom needed to mess with the needles again. So one could remove the cowl once in a while to tweak things if needed like when there is a major seasonal weather change, etc. Then put it back on.
earlwb is offline Find More Posts by earlwb
Old Mar 09, 2013, 09:16 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Thanks Earl!
Mini-HowTo Write-up: Installing a Bowman ring in a DLE-20 grosbeak Engines 32 Jun 02, 2015 03:58 AM
Help! I may have screwed up with my 9x soccer du25 Radios 4 Feb 11, 2013 11:48 AM
Discussion Write-up: DLE-20 reed valve block mod grosbeak Engines 11 Feb 05, 2013 08:13 AM
Discussion I screwed up big time!!!! anotherdebt Multirotor Electronics 1 Jan 19, 2013 05:52 PM
Discussion .46 carburetor screws - inside motor block is stripped vahn Beginner Training Area (Fuel) 4 Jan 08, 2006 03:00 PM
